Re: Opinion about PSU (after recap)
Well, the ESR is not as important sometimes as the capacitance is. Just keep in mind that while the PSU can still work fine with ultra-low ESR caps, the ripple output may be higher due to small oscillations produced by the LC filter output due to the ultra-low ESR.
In general, I suggest two caps of at least 1500 uF caps on the 3.3V rail, same for the 5V rail, and one cap with at least 1500 uF on the 12V rail (but two caps of at least 1000 uF would be better).
It won't die, but if the output filters aren't up to snuff, you can get an unstable computer (I've had an L&C do that). That's why I stress it's so important to make sure that all of the output PI coils are there. With the two 1500 uF 16V caps on the output, I think that would be enough for the capacitance on the 12V rail (well, assuming you will be using those on the 12V rail).
The other thing you need to check is the 12V rectifier since your motherboard does appear to have a P4 12V connector (which means the CPU will be pulling its power from the 12V rail). I suggest a 16A or 20A rectifier rated for 100V or higher (usually something like a STPR1620CT or STPR2010CT since they are most common). Do NOT use 40V or 45V schottky diodes on the 12V rail (i.e. STPR2045CT) - they may not be able to take the high reverse voltage spikes.
A 10A or 12A rectifier will likely run hot. Unfortunately, this is what is most common in L&C PSUs on the output of the 12V rail.
