Antec Tru430 Fan Control Circuit
  • jbbenson
    • Oct 2006
    • 16
    I had the fun and joy of recapping a True Power 430 this evening. All went well, with the exception of the fan control circuit. Voltages for all lines are well within spec, so that much was a success. However, on powerup something in the fan control circuit let out its magic smoke. Both the header on the board for the internal PS fans, and the two external molex connectors read highly erratic on my DMM. I can't really get a reading for any sort of reference, and I don't have a scope to look at the waveform. Does anyone have experience with that particular part of the circuit and a rough idea what might be wrong? I suspect a transistor or diode has bit the dust based on the smell, though nothing really looks cooked. Its tough to tell with all the wires in the way.
    By the way, thanks to Topcat for the Rubycons!
    Thanks in advance!
  • 999999999
    • Sep 2006
    • 774
    Re: Antec Tru430 Fan Control Circuit
    Is this circuit sophisticated enough that a schematic is needed or it is a pretty basic thermistor sensed, biased transistors with a few resistors for current limiting? Well then again I think some do throw an opamp in or it's an option on some PCBs but left off depending on the features of a particular PSU.
    I suppose it could be coincidence that the fan controller fried right after you'd recapped the PSU, but I wonder if there's more to it, maybe a short? Were you powering multiple particularly power hungry (high current and RPM rating) fans?
    First confirm that the power (voltage) from the mainboard (PSU PCB) is ok.
    Next, look at the last transistor before the output to the fans, trace that back visually on the controller circuit board. Transistors are cheap, I would just replace it with something that can handle more current. Since I don't know what the original is, the replacement isn't so easy either. Get the part # off the present one and look for a replacement with similar hFE but higher current rating.
    It's not likely to be an exotic part, any generic transistor will probably work to some extent give enough current handling capability but the result will differ with hFE value differences of replacement part vs original part (if my guess about what this circuit is like is true, but it may not be). The limitation for reasonable implementation will probably be how much clearance there is below the controller PCB and the lead spacing on the PCB (so you're not hacking out something instead of it looking close to original design mechanically). Or you could just replace with exact same or try to cross reference to a suitable equivalent part that's easy or cheaper to source.
    The other transistor(s) are probably generic 6 cents each parts. You could replace all of them or test each. Presuming they're BJTs, try this.
    http://www.allaboutcircuits.com/vol_3/chpt_4/3.html
    You mentioned diode(s) but I doubt it's a diode that went out. Regardless, practically any DMM has a diode check function.
    If you get stuck, you might put the PCB on a scanner or take a good quality camera picture of both sides for someone to look over.
    • jbbenson
      • Oct 2006
      • 16
      Some more relative information:
      The fan circuit was lightly loaded with only the PSU's two cooling fans connected. I was doing initial testing after the recap. I had plenty of time to kill, so I've pretty much done all the troubleshooting tips you listed. To make a long story short, the failure was (most likely) caused by a stray blob of solder. It had shorted the leads of several components together. It was likely from my desoldering, or tinning the tip on my iron The only reason I even noticed it was because it was more shiny than the solder surrounding it, and it was in an area that I hadn't replaced capacitors.
      Anyways, I started tracing the fan circuit back from the output. I'm no EE, but the first description you gave is probably accurate. I had to remove an inductor temporarily though to actually check part numbers and be able to find and test components.
      The transitor closest to the output is a 2SD880, and upstream of that is a 2SA684. I'm pretty sure the 2SA684 is the culprit. I don't have my test results with me (at work) but I remember a very low voltage drop (.094V or thereabouts) and some other weird results.
      I'm going to go ahead and order the 2SA684 along with some caps for other repairs. I'd like to replace the 2SD880 as well for good measure, but Mouser and Digikey don't stock it. Mouser's suggestion for a suitable replacement is an NTE152. Would this be suitable, or could you recommend something else?
      Thanks!
      • 999999999
        • Sep 2006
        • 774
        At Mouser, 2SD880 -> KSD880
        http://www.mouser.com/search/Product...y512-KSD880Y_Q
        (or RoHS version if you like,)
        http://www.mouser.com/search/Product...key512-KSD880Y
        KSD880 Datasheet,
        • jbbenson
          • Oct 2006
          • 16
          Just thought I would post an update. While preparing to replace the questionable transistors, I found what was left of a resistor that burned completely in half. I just flat could not see it with the components packed in as tightly as they were. Live and learn I guess. Now to try and identify it for replacement. I'd take pictures, but my digital camera died several months ago.
          • Sparky
            High voltage
            • Jan 2007
            • 234
            I used to have a true430 I sold to a friend, he still has it. Maybe next time I'm over at his place I can pop the unit open and see if I can get you the value of that resistor if you haven't found it by then. Can you give a description of where the resistor is? Or maybe go out and replace your camera so you can snap a pic? That would help me find it.
            • jbbenson
              • Oct 2006
              • 16
              I've found the value. Just had to desolder what was left and put it under a magnifying glass to see it. 100 ohm, and I'm guessing 1/8 watt by how danged small it is. Verified against the True380 awaiting new caps too. PCB layout is identical. Off to Frys to try and find a replacement.
              • Sparky
                High voltage
                • Jan 2007
                • 234
                If it burned though maybe getting a higher rated resistor might help, like 1/4 W. If it'll fit that is.
                • jbbenson
                  • Oct 2006
                  • 16
                  Yeah, that's what I was thinking too. Of course, it didn't help that I had a solder booger shorting something out which caused the initial problems to begin with.
                  • jbbenson
                    • Oct 2006
                    • 16
                    I finished the repairs and put the PSU back together yesterday. No magic smoke escaped this time!
                    Voltages at the ATX connector:
                    12V @ 12.11V
                    5V @ 5.14V
                    3.3V @ 3.37
                    Measurements were done with only a sacrificial half height 3.5" drive as a load.
                    The fan circuit is now functional with an output voltage of 11.07 when the PSU lightly loaded and at room temperature. Although this is higher than expected, I don't have a working point of reference to see exactly where it should be. The difference is probably in the transistors I substituted. I used a KSD880U in place of a 2SD880U, which is an identical sub. I matched the beta on both. I also subbed an NTE294 for the 2SA684, but I could not determine the beta on the 2SA684. Its a close enough match that I'm not going to bother with it further. Given the fact that these power supplies tend to run a little warm, I'm willing to trade off the extra fan noise for increased longevity.
                    If anyone is curious about where all these parts are located (for modding or whatever), look for the three big chokes on the output side of the PSU. Desolder the middle choke, and and bust out the magnifiying glass. The 2SD880 is the large heat shrink covered transistor that butts up against the 12V output caps. The 2SA684 is in the same general area, but closer to the 5V and 3.3V output caps.
                    The only other thing I'll probably do to this power supply is replace the cooling fans with some nice NMB-MAT Panaflos.
                      1970 Metal Lathe Control Circuit blowing fuses on the 120 volt section failing meager test below 60 mega ohms
                      I was working on this machine yesterday and I now going to use an incandescent lights instead of a fuses to figure out what the issue is with it blowing control voltage rail but this not the only issue the coolant pump failed the meager test as well as the main motor as well this motor has 12 motor wire leads instead of the normal 9 wires
                      This metal lathe has a weird motor setup it has a soft start motor with a “Y” and a delta type of motor winding setup and it is not done in the motor pucker head enclosure it is with four different contactors wired in a configuration I have not...
                      12-29-2024, 07:18 AM
                    • emil_t
                      RTX3090 working fine but fans not spinning
                      by emil_t
                      Hello guys. I have a problem with a PNY XLR8 GAMING RTX3090 graphics card. The problem is that it displays and works fine, but the fans don't spin at all. The problem occurred when someone else removed the fans in order to clean it and broke one of the fan connectors. He replaced it himself and after that, it wasn't working anymore. I guess he damaged something else in the process. What i have done so far: I found 2 capacitors next to the connector that were in a bad shape, he must have touched them with his tools - they weren't shorted, but i replaced them with similar ones from a similar card....
                      04-12-2024, 06:54 AM
                    • CoinCoin88
                      Garage door RX unit (Cardin S38C) does not short relay to send opening signal
                      by CoinCoin88
                      I'm turning to the Badcaps community to help me troubleshoot the radio Rx card from my (old) garage door opener. While I could just ditch that card and replace the whole system, I first would like to understand "why" it suddenly stopped working, because that's just how I am wired...!
                      Some basics: the receiver works on a 30.875 Mhz frequency. Yes, I'm aware this is not in use anymore in a looot of places. It does not use any rolling code, it's just a regular dip-switch code that you have to set up on both the receiver and transmitter. The receiver...
                      09-15-2025, 03:36 AM
                      FP5139D-LF, FP5139DR-LF, FP5139W-LF, FP5139WR-LF, FP5139T-LF, FP5139TR-LF Datasheet
                      BOOST CONVERT CONTROL IC
                      The FP5139D-LF, FP5139DR-LF, FP5139W-LF, FP5139WR-LF, FP5139T-LF, FP5139TR-LF is a boost topology switching regulator control IC for battery-used applications field. The FP5139 includes a totem-pole single output stage for driving NPN transistor or N-MOS, high precision reference (0.5V) for comparing output voltage with feedback amplifier, an internal dead-time control for controlling the minimum duty cycle, programmable soft start with short circuit protection function and logic level control for operating mode or standby mode.
                      FP5139 FEATURES...
                      10-07-2024, 05:15 AM
                    • Astonished
                      Fixing the Charge Circuit of the Batteries of the DC Motor
                      by Astonished
                      Hi friends of electronics
                      What you see in the video and pictures attached is the circuit for charging the batteries of a DC motor.
                      The problem is that this circuit cannot charge the batteries (3 1800mAH NiMH batteries) any more. When the circuit was OK, its green LEDs lit up one at a time to show that the batteries have charged more. But now that the circuit is flawed, LEDs light up as you see in the video and at the same time successive beeps are heard.
                      Please help me fix this circuit.
                      (the datasheet of the IC: https://pdf.datasheet.live/28...
                      01-28-2025, 06:24 AM
