Help with Television Power Supply??
  • w98seeng
    • Apr 2014
    • 19
    I am hoping someone here can give me a bit of advice on the P/S from my LG rear projection TV.
    A friend gave me a 60" LCD rear projection TV that did not work. He said it did work but once in a while it turned off by itself.
    When I plug it in the power LED turns red and the fan comes on. When I try to turn it on, the power LED turns orange and flashes a
    few times and then turns off. I hear a click in the back when the TV turns on and again when it turns off.
    I had the lamp tested at a TV repair shop and it is OK. I took the TV apart to get better access to the inner workings and started looking
    around for a problem.
    The P/S has no bad caps on it or any burn marks. I tested the input voltage on the ballast and it has 1.9vdc coming in (from what I have
    read on the net, it should be 240vdc).
    How can I test the power supply properly to see if it is the problem?
    Thanks,
    Ian
  • CapSwapper
    • Feb 2014
    • 69
    Re: Help with Television Power Supply??
    You need the service manual to see what voltages the PS is suppose to put out. With these older TV's it's best to just change out the module instead of troubleshooting on the component level. If you change the power supply and still no power then its the main board
    • Tynan Dill
      by Tynan Dill
      Assuming...
      11-22-2024, 01:46 PM
      03-31-2024, 02:12 PM
      07-01-2024, 06:34 AM
    • JimBanville
      Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
      by JimBanville
      The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
      I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
      09-13-2023, 07:21 AM
    • CMCM
      Russound CA4 Power Supply Repair
      by CMCM
      Hello Everybody,
      Trying to repair a power supply from a Russound CA4 Multizone Controller (picture attached)
      Russound no longer supports it but were kind enough to provide a schematic of the power supply (pdf attached).
      The outputs marked 12v and 20v are all measuring only 1v.
      The board is clicking, which I think means it is in something called hiccup mode when the flyback transformers switches because of an internal problem or something else on the board Overloading it.
      The capacitors physically look clean (no bludgesor leaks) and...
      07-03-2025, 01:12 PM
