Dell Optiplex 990 psu H240AS-00
  • Gabriel
    • Jan 2010
    • 620
    • Norway
    We have these fail at work from time to time, had to do a teardown.
    All caps are Ltec and and Elite.
    Don't know if the N-channel mosfet STW12NK90Z failed first or the cap.
  • kasfamily
    • Aug 2014
    • 772
    • Russia
    Re: Dell Optiplex 990 psu H240AS-00
    you should check Q51 and R52 and replace C52
    • SteveNielsen
      Retired Tech
      • 2327
      (R25 not R52) I'd be surprised if all three parts aren't shot and probably the transistor took them down. Solid state devices have short failures way more often than resistors and small capacitors do.
      • kasfamily
        • Aug 2014
        • 772
        • Russia
        Sorry, it is R25
        • SteveNielsen
          Retired Tech
          • 2327
          At first my brain read it R52 as well.
          • kasfamily
            • Aug 2014
            • 772
            • Russia
            Hi SteveNielsen ! and i also read upside down
            • SteveReyes
              • Mar 2015
              Any way to get a schematic and part numbers for these components? I'm having a rash of bad power supplies. I'll gladly buy what I need.
                • 31094
                there is a newer version of that supply with PFC that does exactly the same thing,
                the cause is the snubber cap overheating.
                you will need to check the fet, the snubber cap infront of it (it needs to be 2kv, but the original is 1kv) the fuse, the fuseable resistor to it's right,
                some fast rectifier diodes to it's left,
                and the driver circuitry for the fet.
                fet is W12NK90Z from ST
                the rectifier diodes can be replaced by UF4007
                and check the fan while your there.
                • seanc
                  • Nov 2008
                  • 1319
                  This isn't good news :/ I've got quite a few Optiplex 790 and 9010 USFF out there. I presume the PSU is similar, if not the same.
                    • 31094
                    i think 790 is the newer one with pfc.
                    if it is, you will find a vertical pcb behind the fet heatsink that contains the driver circuits and a pair of electrolytics.
                    if those psu's fail, the 8pin driver chip will blow along with a few resistors and diodes etc.
                    also there are a few smd resistors under the main board that will burn.
                    you need to meter *everything* on the small board, and all resistors on the underside of the mainboard.
                    i said in another thread some time ago - these psu's are shit!
                    if you have working ones - upgrade the ceramic cap infront of the fet to 2kv or even 3kv before it fails!
                    • SteveReyes
                      • Mar 2015
                      Thanks. Are there any specific ceramic cap requirements? I was leaning toward .01uf 3kv ceramic. My originals are crispy and I can't see any writing on them at all.
                      I do appreciate all of your input!
                        • 31094
                        let me make a call later, a friend has some spares so i can ask him the value on them.
                        • Rashididrus
                          • Mar 2015
                          • Malaysia
                          Hi.. I also have problem with the same PSU. Can I know the value of the ceramic capasitor since I can't see clearly. What i see is 681k, 1kv.. Is it right? Appreaciate your help. Thanks.
                          • Doc_u
                            • Apr 2009
                            Just had one of these go bad.
                            I can confirm that the cap is marked 681K (top line) and 1KV. (bottom line).
                            The resistor appears Pink in color, bands are Red, Violet, Silver, Gold.
                            Is there anything special I should know when replacing this?
                            Does anyone know the power rating for this part?
                            (I'm assuming it's 1 or 2 watts).
                            Any chance the FET is not bad?
                            • lotec25
                              • Feb 2015
                              • 5
                              I had one of these go bad on me, same issue as above. What a hunk of crap. Lucky the listed value is here for the Ceramic Cap as mine popped into pieces.
                              • lotec25
                                • Feb 2015
                                • 5
                                Here is a pic of the cap in pieces
                                • darkose
                                  • Jan 2017
                                  H240AS-01 version has two identical capacitors at C52 and C11.
                                  Problem is still the same.
                                  • hed190
                                    • Apr 2017
                                    • 12
                                    • Portugal
                                    Hey guys,
                                    I have 3 of these PSU to repair and i have the resistor blown, the transitor mosfet shorted and the fuse blown too, the 681k 1kv Capacitor still good but ill upgrade it to 2kv, and i will try to repair the other components, anyone know what dissipation is that resistor? 1watt? 2 watt? the value is 0,27 Ohm right?
                                    • Mandessa
                                      • Thailand
                                      Hello hed190 I live in the south-east asia country,I have an experience to share with for the H240AS-00 PSU from Dell. For the problem you've asked ,You should also check some components on the board locate on P3xxA Connector behind the Q51(STW12NK09Z). From my experience,components on this board usually damage after the short. I use 470pf 2KV or 680pf 2KV (Blue one) instead of the old one.For R25,I use any value from 0.1 ohm to 0.5 ohm 1W wire wound or metal film type.
                                      • nikgegr
                                        • Aug 2017
                                        • 3
                                        • greece
                                        Hi Guys same problem here also resistor R55 is blown anyone knows the specs for this ?
                                          DELL OptiPlex 3080 OptiPlex 3000 i5-10500T Specification for Upgrade or Repair
                                          This specification for the DELL OptiPlex 3080 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the OptiPlex 3080 boardview and OptiPlex 3080 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
                                          09-12-2024, 02:30 PM
                                          DELL OptiPlex 3050 OptiPlex 3000 i5-7500 Specification for Upgrade or Repair
                                          This specification for the DELL OptiPlex 3050 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the OptiPlex 3050 boardview and OptiPlex 3050 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
                                          09-12-2024, 03:44 PM
                                          DELL OptiPlex 3070 OptiPlex 3000 i3-9100 Specification for Upgrade or Repair
                                          This specification for the DELL OptiPlex 3070 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the OptiPlex 3070 boardview and OptiPlex 3070 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
                                          DELL OptiPlex 3090 OptiPlex 3000 i5-1145G7 Specification for Upgrade or Repair
                                          This specification for the DELL OptiPlex 3090 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the OptiPlex 3090 boardview and OptiPlex 3090 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
                                          DELL OptiPlex 3070 OptiPlex 3000 i5-9500 Specification for Upgrade or Repair
