PSU Noise on Output Voltage Lines
  • Signal
    • Jul 2007
    • 6
    I've been chasing down an odd problem in which the PSU comes into play.
    I starting looking at the output voltage lines on a scope and noticed some small spikes and even a harmonic with a Enermax Liberty 620W.
    I replaced the PSU with a PPC 610EPS12V and don't see quite the same noise, but still see some suspected variances.
    I realize that the general nature of a switching power supply that a small amount of noise on the output voltage is expected.
    Also, with the PSU connected to the motherboard I assume that the motherboard itself might throw some noise onto the lines as well.
    Also assume that the cap quality and overall design of how they are used also comes into play on smoothing out the noise.
    But how much is considered "normal"?
    Also, if the PSU is rated for a higher wattage output but the system draw is say 30-40% would the efficiency of the power supply affect the amount of noise and voltage stability on the lines?
  • Signal
    • Jul 2007
    • 6
    Re: PSU Noise on Output Voltage Lines
    Apologize for the poor wording above. Got distracted during my edit and can't change it now.
    • Sparky
      High voltage
      • Jan 2007
      • 234
      How much noise are we talking about here? The ATX specs allow for up to 120mV of ripple noise. If you aren't seeing stuff beyond that then I wouldn't worry about it.
      • Signal
        • Jul 2007
        • 6
        The general high frequency noise seems to be within reason (50mv) however I was seeing a harmonic where the hf noise varies into a wave form and hash spikes show up on the Liberty.
        I don't see the harmonic on the PPC, but it still looks like hash spikes are there.
        It's not a digital or LCD type of scope so it's tough to get a picture for an example.
        • linuxguru
          • Apr 2005
          • 1564
          On constant load and constant primary input voltage there should not be any harmonics in the output ripple (units with Active PFC may be an exception).
          However, a PC motherboard is not a constant load - the processor keeps switching into different power-saving states, drive motors keep turning on and off, etc. The PSU's control loop will keep
          adjusting the primary side duty-cycles, etc., and you will see changes in the ripple waveform on the secondary side. Depending on the time-constants in the control loop, the control loop may exhibit ringing (a quick burst of oscillation with overshoot/undershoot, generally considered undesirable) in its transient response to a load change - this may show up as harmonics in the output ripple.
          It's generally inadvisable to modify the control loop - you could end up with further instability leading to oscillations, etc. However, you can try recapping the secondary caps with up to 50% larger low-ESR capacitors and see if the amplitude of the spikes decreases.
          • starfury1
            • May 2006
            • 1256
            The liberties have been known to "blow up"
            (for want of the explanation of the exact nature of how they destroy them selfs and why)
            under heavy load
            there was a review at jonny guru's but I couldn't find it unfortunately
            this may have given you a bit more insight as to what going on with the liberty.
            (they are fairly in depth reviews on psu's)
            from what I read I wouldn't push a Liberty pass 2 3rds of its rated max, at best to be safe
            (there is a post here on popped caps in one driven fairly hard for about a year, oh I see you found it...search here there maybe a few more I think Gal posted about a blown one a while back)
            Me, well linuxguru and a few others round here are far more up with how switchers work
            so I'll leave it to them for the technical comment
            If I may ask whats the "Odd problem" out of curiosity?
            no help but just beware of Liberites...don't know if Enemax corrected what may have been the issues with this model
            Cheers
            BTW I'am using one but at best id say it coasts along in this box
            • Galvanized
              • Mar 2006
              • 468
              I am not saying go out and buy one, but this is what jon over at jonnyguru.com uses to check ripple for the PSU reviews.
              Seem to recall that it costs around $160.
              http://usb-instruments.com/oscillo_stingray.html
              • Tom41
                • Oct 2005
                • 339
                • England
                That's nothing - when measuring the output of an Apple iBook power supply cable, I saw a trace with 'spikes' moving along it. It was as if the trace was a conveyor belt, and the spikes were things on the conveyor belt moving slowly from one side to the other.
                And to top it all off, when I measured my Mercury PSU in standby, I got a SPEECH waveform appearing as well as the voltage/ripple trace! I can only assume something was acting as a radio receiver and picking up a broadcast of mainly speech. Perhaps it had something to do with the vented cap in the PSU?
                You know there's something wrong when you open your PC and it has vented Rubycons...
                • 999999999
                  • Sep 2006
                  • 774
                  There is no harmonic that matters. Either the unit is staying within ATX specs (against which, motherboards must be designed to operate properly), or it isn't. The secondary concern is if it has a reasonable lifespan remaining or it would be better to pull it and repair (recap?) or replace. Certain signs like brand and model of caps or fan(s) may give hints about what, if any, changes are necessary for best expectation of longer remaining life.
                  • electron_jj
                    Panasonic TH-L42D25A checking the PSU output voltage
                    by electron_jj
                    Hi Everyone, I am new to this forum. I have a Panasonic LED TV which doesnt turn on and is blinking 4 times repeatedly when I turn on the switch. The TV does not respond to the remote control so I had to turn on using the physical switch on the side of the TV. When I turn on the switch the 4 x blinking starts and repeat itself until I turn off the TV. There is a black screen. I turned off the light in the room to check the panel and I think there is no backlight as far as I can tell.
                    I have been inspecting and testing the capacitors and diodes in the power supply board to try to...
                    08-29-2021, 08:13 AM
                    MT3608 Step-Up Converter IC Datasheet
                    The MT3608 is a constant frequency, 6-pin SOT23 current mode step-up converter intended for small, low power applications. The MT3608 switches at 1.2MHz and allows the use of tiny, low cost capacitors and inductors 2mm or less in height.
                    Internal soft-start results in small inrush current and extends battery life.
                    The MT3608 features automatic shifting to pulse frequency modulation mode at light loads. The MT3608 includes under-voltage lockout, current limiting, and thermal overload protection to prevent damage in the event of an output overload. The MT3608 is available...
                    10-07-2024, 05:02 AM
                  • David Miteff
                    NM-D521 rev. 2.0 output voltage on CPU coils seemingly low
                    by David Miteff
                    Hello, guys!
                    As the title says - the board is NM-D521, on the input of the CPU coils I read 1.2-1.3V, which should be normal, but on the output I read around 0.6-0.8V. The laptop bootloops with no picture.
                    As of right now I don't have a thermal camera, so I can't confirm a shorted or partially shorted CPU chip. Do you have any other suggestions as of why the output voltage might drop like that?...
                    12-30-2024, 07:02 AM
                  • Ri5ux
                    Playstation 5 2 Second BLOD, F3501 Voltage Output Question
                    by Ri5ux
                    Hi there, just wondering if anyone out there who has a semi-working or working PS5 board could check the output voltage on F3501's buck converter for me, with and without power. I have 12V on the input, fuse not blown, no output voltage on that IC, with or without power, and no shorts present.
                    Symptom: 2 Second BLOD
                    Testing: All other rails seem present. APU, SSD, South Bridge, and RAM confirmed to be powering up using a thermal camera. Monitoring the current draw of the 12v rail shows a somewhat normal boot cycle of the south bridge. Jumps up to 300ma, and down to 0....
                    09-09-2023, 06:57 PM
                  • labello
                    Power supply Termaltake Smart Se 630w any voltage in output
                    by labello
                    Hello everybody I try to fix thi power supply, I have voltage in bridge rectifier, and also in the large capacitor , so I thought the problem was in the pfc but then I found all mosfet ok(tested out of the circuit so I just moved on in the low voltage and here I found a short of one of the diode rectifier. I'll replaced it already but it's completely dead, I mean any stanby voltage and the other voltage is not present. I don't have oscilloscope to understand if the chip work how can I test it? Thank you for the help 🙏
                    09-09-2023, 12:06 PM
