NZXT C850 connected w EVGA molex cable, 12V pin back feeded to 5V. Anybody has experience in this damages repair?
  • coinwizx
    • Sep 2025
    • 5
    The power supply is 2024 newest version of NZXT C850 modular power supply.
    Cause of damage: I connected EVGA molex cable to the Sata port and test it with a ATX tester. Since the pin out on the EVGA is wrong, result in the 12V pin shorted to the 5V pin, in the 12V back-feeded to the 5v port.
    Damage: Power supply shorted out, shut off itself internally, damaged the 5v or 3v rail or the monitoring circuitry. The self protection circuit shut off the power supply when power up because it detected some abnormal/defect. I waited a few minutes, let it self reset then try to re power up. It try to power up, fan spin up but immediately shut of. When turn on the power switch immediately on a 2nd attemp, it no respon at all, the fan not spin up anymore. Waited a few minutes and try it again, the same behavios happen, fan spin up and shut off on 1st attemp only.
    Help? Seek advice or help from someone who has experience with similar damages or repair this model PSU. What need fix?
  • CapLeaker
    Leaking Member
    • 8340
    Is about same build style than the Corsair one and utilizes a single WT7527V supervisor IC. Probably this is the one that is a little easier to work on than the Corsair.
    https://www.tomshardware.com/reviews...-supply-review
      • 31255
      pictures?
      • coinwizx
        Corsair HX1200 connected w EVGA molex cable, 12V pin back feeded to 5V. Anybody has experience in this damages repair?
        by coinwizx
        The power supply is 2020 Corsair HX1200 modular power supply.
        Damage: Power supply shorted out, shut off itself internally, damaged the 5v or 3v rail or the monitoring circuitry. The self protection circuit shut off the power supply when power up because it detected some abnormal/defect. I waited a few minutes, let it self reset then try to re power up....
        09-15-2025, 12:46 PM
      • coinwizx
        Burned out PSU Corsiar HX1200 and NZXT C850, connected to wrong Molex/Sata cable from EVGA.
        by coinwizx
        Anybody has experience repair PSU burned out due to connect to EVGA molex/sata cables. I know the cable is not compatible (i got them mixed up), but I though i can connect it and use a PSU tested to find out which is the wrong sata/molex cables. As soo as I pluged in the powered molex cable to the PSU tester, the power supply short out, and will not turn on anymore. After the incident, the PSUs (both HX1200 and C850) try to power on and shut itself off immediately. The ATX PSU tester survice the short circult, still working perfectly. Anybody know if it's an easy fix or know which parts...
        09-09-2025, 03:11 PM
      • onix331
        EVGA RTX2070 Weird power stage/I2C issue
        by onix331
        Asking here as a last ditch effort:
        GPU: EVGA RTX2070 Black Edition XC Gaming
        A few weeks ago i noticed a burning electronics smell in my room, after a bit of confusion i realized that the RGB LED light of my GPU was out. Weird.
        I didn't think much of it until i tried to look at the power usage in HWinfo, i then noticed that the entry "GPU Power (Total)" was gone entirely, it would also not boost above 1410Mhz.
        Looking further i noticed that "Performance Limit - Utilization" was always at "Yes". The card did perform mostly...
        05-27-2024, 08:34 AM
      • s_henya
        EVGA GTX750TI BIOS Request
        by s_henya
        Hi guys,
        Got this EVGA GTX750TI 2GB GPU
        MB Bios is beeping when GPU is connected.
        When booting with onboard GPU, MB is booting but the GTX isn't showing in windows device manager.
        I would like to reprogram the bios EVGA 750Ti 2GB non-6pin 82.07.55.00.50
        I searched around but couldn't fins 256kb BIOS like mine.
        Anyone can please assist?...
        05-05-2024, 12:30 PM
      • Rayven
        EVGA GTX760SC Schematic Needed
        by Rayven
        hello everyone , im looking for a schematic file for a gpu card EVGA 760 SC , i already made measurements in many places and all looking good but i want to verificate the mos critics zones and verify routes , im going to atach an a PCB photo and if anyone have the file .fz , .brd or any technical reference please sended to me , i really apreciate any help .
        10-18-2025, 09:15 PM
