Hello, everyone. My brother has a Gateway computer that was rebooting itself, until it finally wouldn't power up. I replaced the power supply and all was fine for a few days. He said it beeped 3 times and then lost all power again. I didn't want to waist another power supply, so I pulled the board to look for burn spots and didn't find any, however I did find 2 caps with brown stuff on them. My question is, did those caps with the brown stuff cause the second power supply to go bad also or is it possible that the second power supply caused the caps to blow? I am a rookie so any information will be appreciated. Thanks and sorry to bother you guys.
Will bad caps cause a power supply failure?
Re: Will bad caps cause a power supply failure?
The old PSU could have caused the caps on the mobo to start to fail, then later totally went out. You can test the current PSU by shorting the green wire and a black wire on the 20pin connector to power it up, then use a DMM to test the voltages and such. -
Don't power up a PC PSU without a load - some of them don't like it and fail, sometimes in a spectacular way, if ran for more than a few seconds.
Stick an old hard drive or CDROM or something on at least to give it something to run.
I'd be inclined to say the motherboards caps are on the way out - changing the PSU probably just gave them the extra bit of 'ooomhp' to run for a short while. Have you tested the old PSU at all?Comment
Thankyou Harvey and Sparky for getting back with me so soon. Yes I did test the old PSU with a multimeter and got no voltage readings, I also tested with a wire to the green and black pin and it would not supply power to a cd-rom. I just looked for burn marks on the motherboard. When I didn't find any I thought it was just a PSU failure. So I installed the second power supply and it went bad a few days later. Until finding your forumn I didn't know about the possibility of caps going bad. Thats when I found two caps on motherboard that had brown stuff on top of them. After I removed the second power supply, I heard something rattleing inside so I took it apart and found 2 small caps inside just laying there inside the PSU that evidently were blown off and I saw some burn marks where it look like they once was located. The first PSU was bad. I just hope the second used PSU that I installed didn't cause the caps to go bad. I am hopeful that the caps were the reason the second PSU went bad. Also do you think other componets are salvageable? Again thanks for teaching me, I am greatful and love learning.Comment
Do you have another known good working PSU you can use? Just to hook up to the PC real quick to see if it powers on. If it does, then I would recap the mobo and you should be good to go afterwards. Talk to Topcat about replacement caps as he can supply you with what you need.
Glad to be of service
probably the second psu was also almost near its end of life before you placed it in this system. i dont think it was the motherboard that makes the second psu went bad. it will more make sense if the psu that makes the mobo bad. cmiiw..
because the motherboard was powered with bad psus, i worry if it is still okay.. moreover it already has bad caps. as sparky suggestion, try with good psu next time. if it lives up, do a recapping then..days are so short when you actually do something..Comment
Assuming...7 Photos -
by eryjusHello,
Channel: General Capacitor Questions & Issues
by captain150I'm trying to repair two old VCRs, they both have bad caps. One has leaky ones, the other would barely run until I subbed in some caps from another power supply I had laying around (though they are the wrong values). This vcr works for an hour or two, but then the power supply starts whining and the picture gets lines in it. I didn't replace all the secondary caps, so another voltage might still be problematic, or the values I used are too far off.
I've been on mouser and digikey but the options are a bit overwhelming. I just need some new ones that will work. They don't need to be top quality,...-
by sam_sam_samI have been working on this concept for quite some time now with limited success but recently I found a switching power supply that is setup for the voltage that this soldering station needs to operate at however it also needs part of the secondary circuit from the original switching power because you need several voltage rails
I once tried to get a ZD-915 desoldering station to work on a 18 volt battery power supply but unfortunately things did not go well but I did find a work around but I might try this idea again but going at a little differently more about this another time... -
by sam_sam_samThese cheap non brand capacitors at it again
Last night we had a power outage [ long drawn out trying three to come back up before going out completely ] and when I went to turn the DVR camera recorder back today no go 3 bad capacitors ( one capacitor no ESR reading on DVR board the other 3 capacitor on the power supply board over 40 ohm this is not a misprint ) on the external switching power supply and one capacitor on the DVR camera recorder board where the power supply that goes to the hard drive disk is
Well at least I have the cameras back on line I to try the... - Loading...
