Anyone ever worked with this supply before? I've got a non working one with no visible burn marks anywhere. Have replaced both startup capacitors with new ones but I'm not getting any power or trickle voltage at all on the imac. Fuse is fine. Can hear it make some noise when plugged into mains.
Apple iMac 21.5 Delta ADP-200DFB Power Supply
Tags: None
Re: Apple iMac 21.5 Delta ADP-200DFB Power Supply
Not much use posting pictures off the internet we need to see YOUR BOARDSPlease upload pictures using attachment function when ask for help on the repair
Assuming...7 Photos -
by sam_sam_samI have wanting to do this project for quite sometime now and I finally found a switching power supply that will work on this desoldering gun station ZD-915 that the original switching power supply took a shit and just was not worth trying to fix it because this switching power is not quite big enough to handle the heater element and the vacuum pump
One note when I tested the switching power supply and the voltage control board I noticed that this desoldering gun heat up much faster than the original switching power supply which I was really surprised by to the point that I might buy... -
This specification for the MSI Delta DELTA 15 A5EFK-008 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the DELTA 15 A5EFK-008 boardview and DELTA 15 A5EFK-008 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...09-07-2024, 03:40 AM
by GentianI have a 5V 55A led Delta power supply with no output. I found this 7 pin IC 901 damaged as in the photo. All other elements look ok. I checked and every other surrounding componets diodes, resistors and capacitors look ok. I have 2 identical power supplies removed from a led wall which have the same defect with this ic burned but not a working one for reference. I founded by measurements that pin 7 goes to positive hot 450V 220uF electrolytic capacitor primary side. Pin 1, 2, 3, 4 connected together to pcb cooper trace. These four pins goes to negative side of 10uF 50V electrolytic capacitor...
by dragon3xHi, this is for troubleshooting and, hopefully, repairing a Delta Power psu
that is still quite new, as it worked OK for some months until it failed.
At the time I was not into power supply electronics; it was put
aside and a new power supply installed inside the computer. Also at the time
power supplies were half the price of today's.
On the PCB there are a D339 and 7500B chips.
I have found that schematics with these 2 chips (see included file).
Does it represent the actual circuit of the MAX-500ATX, I cannot tell.
Some measurements,... - Loading...
