Blown OCZ Fatal1ty 700w, and almost new CWT? 350W PSU
  • Utking
    • Jun 2014
    • 7
    • Norway
    Hi guys!
    First off, I got a problem with a PSU that i got for free, it's an OCZ fatality 700w, what has happened with it, is that the capacitors on the secondary side has blown. (Teapo)
    some more info and pictures here:
    http://www.overclock3d.net/reviews/p...700w_atx_psu/3
    Now i was thinking of replacing them instead of throwing this PSU away.
    the caps i ordered is :
    5x Sanyo 16V 1000uF
    10x Sanyo WG 6.3V 3300UF
    Do you guys think this would work?
    Also i have an old 350w PSU. More accurate this one: https://www.badcaps.net/forum/showthread.php?t=24859
    And i was wondering if i could use it in my server? maybe replace some caps, (Primary) or is this a bad idea? don't want to toast my hdd's :p
    Thanks for all help guys!
  • Behemot
    • 4845
    • CZ
    Re: Blown OCZ Fatal1ty 700w, and almost new CWT? 350W PSU
    The WG is too low ESR, it is intended for motherboard and VGA VRMs. The PSU can start oscillating with them. I have Samxon RS 3300 uF/16 V and Chemi-Con KYA 3300 uF/6,3 V if ya want.
    The CWT is waste of time unless you want to learn on it.
    • Utking
      • Jun 2014
      • 7
      • Norway
      Ok, thx Behemot. i've sent you a pm
      So i should not get low ESR ones? i thought those were the one i wanted :P Is it any bad if i go any higher on the capacity?
      And about the CWT, can i f up my server by using it?
      Thx.
      • Behemot
        • 4845
        • CZ
        Low-ESR, but not ultra-low (motherboard/VGA grade).
        If it is stock, it can do all kinds of harm. But you cannot make it THAT much better. Would be safe with recap for some low-power use so if your server draws 100-150 W, than also the efficiency won't be terrible. Still bad, but not terrible.
        • Utking
          • Jun 2014
          • 7
          • Norway
          I took a look on the capacitors you recommended, but the diameter is a little too big, i think my ones are 22 mm, you think it'll work? It would be great to match those primary caps with the same brand for secondary though
          And they have a greater capacity than the originals, will this make it better at filtering?
          Hmm, I guess i'll toss away the CWT then, do you have any recommendations for a low watt, not too expensive PSU?
          • Behemot
            • 4845
            • CZ
            Diameter is 10 mm, the other spec is height and usually there is room enough…I checked the photos and the caps also seem to be 30 mm height.
            But anyway, can you post pics of yours? It seems to me the one they reviewed at OC3D.net also had some Chemi-Con capacitors on secondary. I am curious if they kept them or swapped all for Teapo and CrapXon in production variant…
            • Utking
              • Jun 2014
              • 7
              • Norway
              Well i took a closer look on this picture :http://www.overclock3d.net/gfx/artic...065955883l.jpg
              And all of mine on the secondary side is green, alas Teapo.
              The ones on primary side is identical as the ones on the picture. with the same rating too.
              • Behemot
                • 4845
                • CZ
                Yeah. Those brown there are NCC, possibly KZE series. Seems like OCZ cheaped the production.
                • Utking
                  • Jun 2014
                  • 7
                  • Norway
                  Bah, sucky OCZ, anyways the PSU is too good to be thrown away, anyways, thanks for all help
                  • RJARRRPCGP
                    • Jul 2004
                    • 6301
                    The KZE series is not known to have problems.
                    ASRock B550 PG Velocita
                    Ryzen 9 "Vermeer" 5900X
                    Arc A770 16 GB
                    eVGA Supernova G3 750W
                    Alienware AW3423DWF OLED
                    • Behemot
                      • 4845
                      • CZ
                      I said it is?
                      • cmlewis89
                        LG 47LB5DF blown power supply board
                        by cmlewis89
                        Hi folks,
                        I'm new to this forum. So my trusty 17-year-old LG 47" LCD recently died. As I was booting it up, I heard a hum followed by a loud bang, sounds of pieces flying around, and loss of power to the unit. Inspecting the PSU, I saw two obvious problems: a blown thermistor (bang + flung pieces) and a visibly bulging main cap. Inspecting as many components as I could with my Fluke MM, I diagnosed that the following components on the "hot side" of the board were also bad: one of the 2 main MOSFETs, main 8A fuse, small cap (25V 47uF) connected to main caps, and a blown...
                        09-03-2024, 07:50 PM
                      • drscoot
                        HP X360 convertible battery blown fuse error, not charging
                        by drscoot
                        HP Modelnumber: 14-dh0061nb​
                        This laptop had a shorted cap on a Vcore section. After replacement is works again. But there is still a battery issue.
                        The battery is HT03XL and with the built-in component test from HP, in the Power section, I get an error: Logic State: Calibration required (20), Charge state: Blown Fuse (42)
                        I have another same battery, also with error: Logic State: Very Weak (70), Charge state: Blown Fuse (42)
                        And a third battery TF03XL (looks identical) with error: Logic State: OK (0), Charge state: Blown Fuse (42)
                        All these 3 batteries are charging...
                        12-15-2023, 05:54 AM
                      • swerg
                        Part selection for possible blown inductor on ASUS GX531-GW-AB76 laptop mobo
                        by swerg
                        Hey everyone,
                        I'm a novice trying to repair my laptop. The LCD screen has an image, but no LED backlight for the image. It also produces an image when connected to an external monitor.
                        I have found what I believe to be a blown inductor labeled "L4502" and "120 Ohm" in the schematics (zoomed in image, blue arrow to blown component). I have included an image of the general area of the mobo and an excerpt from the schematics as well.
                        I am having trouble selecting a replacement component, which I believe to be a 120 Ohm ferrite bead, from the components...
                        06-06-2024, 03:39 PM
                      • MrzPdlch
                        Blown fuses on Gigabyte GTX 980TI 6GB
                        by MrzPdlch
                        Hey everyone,
                        I just went ahead and unscrewed a faulty GTX 980 TI from Gigabyte. What I found beneath the cooler was, as it seems, a common issue of that card. Two blown fuses on the bottom right corner of the card next to a MOSFET.
                        Now my question would be if there is any schematics of that card available to figure out which are the blown components so I can try and replace them together with the mosfet if needed.
                        Find some pictures of the actual GPU together with a picture of how it should look like.
                        I also wonder whther it might be a problem that there...
                        03-10-2024, 04:14 PM
                      • cheeky2
                        Samsung BN44-00262A H37F1-9SS power supply help finding blown value components!
                        by cheeky2
                        This Samsung combined power supply and inverter was replaced a while ago from a Samsung 37inch LE37B530P7W TV. However I would like to repair this one.
                        I have replaced the Mosfets Q1820 and Q1821 ( FDPF7N50U) which were both blown and the fuse FM802S. The schematic for this power supply that is attached doesn't relate to this power supply as the driving transistors and diodes are D1830, D1831, D1832, D1833, Q1811 & Q1810 are nowhere on the schematic!
                        Does anyone know what the components for D1830, D1831, D1832, D1833, Q1811 & Q1810 should be? I ask as I did change the Mosfets...
                        06-15-2025, 05:12 AM
