Seasonic S12 (SS-500HT F3) zener
  • Behemot
    • 4845
    • CZ
    I got this PSU which is not working, no stand-by voltage.
    From quick finger-test the PFC is OK, capacitor was charged. I found blown resistor (white gold gold orange orange, no idea what resistance) on +5 V SB and also zener at Vcc for the ICE2A0565G controller. It says it wants 8,5-21 V in datasheet. I am not able to read the value of the SMD zener. It seems like 8 V but that is too low. What would be the best value? There is chemi-con KY 47 uF/25 V cap on the Vcc.
  • Behemot
    • 4845
    • CZ
    Re: Seasonic S12 (SS-500HT F3) zener
    I finally found good photo of this PSU (or PSU with this board) and the resistor is indeed like that: orange, orange, gold, gold, white. That seems to be 0R33 +-9%? Wut?
    • Behemot
      • 4845
      • CZ
      Anybody has any explanation for the resistor? I will jsut stick some zener in, possibly around 15 V, but the resistor is a mystery…
      • Majestyk
        • Nov 2013
        • 96
        I don´t think there´s a white ring for tolerance.
        My suggestion would be
        Orange=3
        Orange=3
        Gold=Multi 0,1
        Gold=Tolerance 5%
        White=Voltage 900V
        It seems to be a MOX (Metal Oxide) resistor that has a special characteristic when disrupting the circuit in case of a short / overload.
        It must be replaced by a MOX type again for continued safety.
        • Behemot
          • 4845
          • CZ
          So you think 3R3 metal oxide? Seems plausible…
            I would use 20V 1/2W Zener so the VCC cannot go above the 21V Vmax of the VCC when the power supply first start-up, that IC is probably running at around 16~18VDC or so.
            That resistor (3.30 Ohms), is one end connected the main cap + and another end is connected to to one of the leg of the SMPS Tranformer for that ICE IC
            • Behemot
              • 4845
              • CZ
              Cool, thanks. But wouldn't be 18-19 V safer?
              • Behemot
                • 4845
                • CZ
                With 20V zener and the 3R3 resistor, I got lightbulb fully on and no stand-by voltage. There still seems to be some short or similar problem…I got 2A0565Z here, do you think it's worth replacing? Maybe the PWM controller itself is shorted internally…if both the resistor and zener are blasted…
                  The 3R3 is blown for a reason, so how is that resistor is connected? What is the resistance reading between the Source pin3 and and the Drain pin4/5, Pin 8 Ground and pin 7 VCC of that ICE2 IC?
                  • Behemot
                    • 4845
                    • CZ
                    Drain to source and Vcc to ground is OK but there is short between source and ground. So either the IC or small TO-92 transistor in there, I detect short between 2 of it's legs as well.
                      Source and Ground resistance will be <1 Ohm for the I sense Resistor circuit, so that is normal. I guess you will have to see what is shorted out that causes the lamp to light up brightly.
                      • Behemot
                        • 4845
                        • CZ
                        Well, the FET inside does not seem to be shorted, that's for sure.
                        The resistor connects high voltage from capacitor to one pad of transformer, that is also connected through ceramic capacitor to some diode. I'll check more components in here tomorrow and take some pics probably…
                          master hoarder
                          • May 2008
                          • 12175
                          The FET may not be, but it's driver inside the chip could be. No way to tell, though. My advice would be to just take out that 3.3 Ohm resistor and see if the light bulb lights up and stays lit again. If it does, the problem is elsewhere.
                          The ceramic capacitor and diode are probably for the snubber network - they clamp down high voltage spikes from the transformer's inductive kick-back when the FET turns OFF.
                          Also, some PFC circuits tend to fool the light bulb trick (or it takes a very long time until the cap charges, and then it goes OFF). Therefore, I suggest you temporarily disable the PFC circuit until you get at least the 5VSB supply running (but also preferably the main PS too). You are on 230 V line, so the lack of PFC won't cause many adverse affects. You can disable the PFC either by removing its MOSFET or by removing the MOSFET's Source resistor (probably another low-Ohm resistor).
                          • caspian
                            What Zener Diodes on a Linear Power Supply
                            by caspian
                            Dear members,
                            I have a linear variable power supply with unknown brand name that I used for voltage injection.
                            Then it failed. I discovered that its transistors (Q1 and Q2) are shorted.
                            In addition, I discovered that its zener diodes are defective.
                            I can replace the burned transistors.
                            But I do not know the model of the zener diodes. the model number is not marked on the zener diodes.
                            Therefore, I cannot replace the zener diodes.
                            I do not want to test the zener diodes in a test circuit to discover their model or value.
                            no schematics are available...
                            05-26-2025, 12:38 PM
                          • Dvsr
                            On M-Audio AV40 active studio speaker's two zener diodes get really hot.
                            by Dvsr
                            Hi. I need help from wiser guys. I am amateur in electronics and can't figure this out by myself.
                            I bought faulty speakers, M-Audio AV40's. Other speaker has all the electronics in it and the other speaker is just passive one powered by the other speaker's amp. Original problem with the speakers was loud buzzing. I figured out that there is something wrong with the capacitors. I went ahead and replaced every electrolytic capacitor on the PCB. The caps are good quality and have the same values as the original ones.
                            After replacing the caps I started testing out the speaker. It seemed...
                            09-10-2025, 10:20 AM
                            Acer Swift SF114-34-P2H0 + Pack Gold Acer 14'' Notebook 1 Specification for Upgrade or Repair
                            This specification for the Acer Swift SF114-34-P2H0 + Pack Gold Acer 14'' Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SF114-34-P2H0 + Pack Gold Acer 14'' boardview and SF114-34-P2H0 + Pack Gold Acer 14'' schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...
                            09-07-2024, 03:10 AM
                            Acer Swift SF114-34-P25P + Pack Gold Acer 14'' Notebook 1 Specification for Upgrade or Repair
                            This specification for the Acer Swift SF114-34-P25P + Pack Gold Acer 14'' Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SF114-34-P25P + Pack Gold Acer 14'' boardview and SF114-34-P25P + Pack Gold Acer 14'' schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...
                            Acer Swift SF114-34-P2H0 + Pack Gold Notebook 1 Specification for Upgrade or Repair
                            This specification for the Acer Swift SF114-34-P2H0 + Pack Gold Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SF114-34-P2H0 + Pack Gold boardview and SF114-34-P2H0 + Pack Gold schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any...
                            09-07-2024, 02:20 AM
