Any need to prepare new caps?
  • Logistics
    • Apr 2007
    • 721
    I just got my shipment of Panny FM's to recap my Antec SL350. Is there any need to fire them up before powering on the supply? I am even replacing the biggun 200V main caps so I was wondering if I should solder everything up and go around with a little DC transformer and touch the leads on all the caps to power them up before firing up the supply.
  • PeteS in CA
    • Aug 2005
    • 3579
    • USA, Unsure of Planet
    Re: Any need to prepare new caps?
    Nope. Now, if they were several years old, charging them to their rated voltage through a ~1K resistor for an hour or two is sometimes helpful, but even that may be overly cautious unless you're using them at near their rated voltage and ripple current.
    PeteS in CA
      by momaka
      03-12-2025, 03:42 PM
    • eryjus
      by eryjus
      05-10-2023, 11:21 AM
    • Paxman_Swede
      by Paxman_Swede
      Hello!
      01-14-2025, 09:51 AM
    • captain150
      by captain150
      03-16-2025, 07:34 PM
    • Foetuss
      Gigabyte GA-6OXT :: caps question
      by Foetuss
      Good evening
      I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
      Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
      But I was also suprised about the bigger boys, which are 330µF 25V.
      Could it be they used 25V caps because they were cheaper / available at that time?...
      02-11-2025, 12:22 PM
