Dead PSU - Help a beginner, please
  • Per Hansson
    • Jul 2005
    • 5895
    • Sweden
    Re: Dead PSU - Help a beginner, please
    Nah, I haven't found a better source...
    I've bought Samxon caps from Big Pope on this forum though...
    Most of the Swedish sites that will sell caps only sell in large quantities or only to corporate businesses...
    You could always buy from mouser or RS Components but you will need to pay tax on the caps then...
      by momaka
      03-12-2025, 03:42 PM
    • eryjus
      by eryjus
      05-10-2023, 11:21 AM
    • Paxman_Swede
      by Paxman_Swede
      Hello!
      01-14-2025, 09:51 AM
    • captain150
      by captain150
      03-16-2025, 07:34 PM
    • Foetuss
      Gigabyte GA-6OXT :: caps question
      by Foetuss
      Good evening
      I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
      Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
      But I was also suprised about the bigger boys, which are 330µF 25V.
      Could it be they used 25V caps because they were cheaper / available at that time?...
      02-11-2025, 12:22 PM
