X-360 PSU ( PWM IC not having vcc voltage )
  • SM-Piyes90
    • Feb 2014
    • 120
    • Morocco
    I have recently got my xbox 360 power supply blinking red and no output .
    I opened it up and checked the pwm ic vcc pin , and i got no voltage on it .
    So checked the startup circuit , found a bad resistor , changed it and the unit is still blinking red .
    any one familiar with this issue ?
    Model is HP-AW175EF3P btw
    • 31304
    Re: X-360 PSU ( PWM IC not having vcc voltage )
    does the standby supply work?
    btw, those psu's overheat over time because of dust in them.
    whenever you get one - hold a vac cleaner against the vent holes at one end for a min
    most people dont know they have a fan in them.
    • SM-Piyes90
      • Feb 2014
      • 120
      • Morocco
      Actually before that happens it was a constant orange light with 5 vdc at the 1st output and no 12 v at the 2nd output , and i was able to see the console's 3 RLOD .
      But now after removing and putting back some optoisolators ( for tests) , i get that blinking .
      I guess the blinking means that the standby supply is working .
      • kc8adu
        • Nov 2003
        • 8832
        • U.S.A!
        iirc the light wont blink if 5v stby is dead.
        did you jump red and blue?
        that fires up the main +12.
        most of the consoles are in rough shape now and not worth fixing so i use these power supplies to run radio gear.
        edit.
        now that we know it worked till you messed with it go double check your work.solder shorts reversed/wrong opto,ect.
        • SM-Piyes90
          • Feb 2014
          • 120
          • Morocco
          edit.
          Yes , that's my thoughts too .
          • SM-Piyes90
            • Feb 2014
            • 120
            • Morocco
            Okey am back to my original situation with a constant orange light after resoldering an optoisolator pin, but still no voltage at the PWM ic vcc pin , i have to mention that i have found a 150 ohm resistor that was giving 700 ohms , but things are the same even after the replacements .
            Any thoughts on this dear members ?
              • 31304
              got foto's and the pwm part number.
              • SM-Piyes90
                • Feb 2014
                • 120
                • Morocco
                Its S2153D , i will upload pictures later .
                Thanks in advance stj
                • SM-Piyes90
                  • Feb 2014
                  • 120
                  • Morocco
                  Hi again and sorry for not putting any pictures yet , i am still waiting to get my camera from a friend .
                  Anyways i have searched a bit on some forums and some say that this xbox psu does not output a 12 volts when its disconnected from the xbox console .
                  And also the 12 v rail is activated when the 5 vsb is shorted with ps-on .
                  Any ideas on this ? is it safe to keep 5 vsb shorted with ps-on and see if the 12 v is given ?
                  • SM-Piyes90
                    • Feb 2014
                    • 120
                    • Morocco
                    Ironically i have found that the enable pin was broke .
                    PSU is on now .
                    • Agent24
                      I see dead caps
                      • Oct 2007
                      • 5096
                      • New Zealand
                      Good to hear!
                      -David VanHorn
                        master hoarder
                        • May 2008
                        • 12175
                        • Bulgaria
                        Yes.
                        Short PS-ON to 5VSB and the power supply should turn on. No need for a resistor (though I always do it with one just in case ).
                        I have one Xbox brick that has a steady red light or no light at all when plugged in the wall. IIRC, these PSUs had either Samxon or Taicon caps in them (or possibly Ltec), so I wouldn't be surprised if there is a bad start-up cap in the 5VSB circuit.
                          • 31304
                          probably full of dust and a stalled fan.
                            master hoarder
                            • May 2008
                            • 12175
                            • Bulgaria
                            Actually no. I got two of them as a set. The one that was packed full of dust was working. This one is clean and not always working. Go figure.
                              • 31304
                              maybe it's not full of dust because it has a bad fan - does the fan have a tacho output that could be used to shut the supply down?
