X-360 PSU ( PWM IC not having vcc voltage )
  • SM-Piyes90
    • Feb 2014
    • 120
    • Morocco
    I have recently got my xbox 360 power supply blinking red and no output .
    I opened it up and checked the pwm ic vcc pin , and i got no voltage on it .
    So checked the startup circuit , found a bad resistor , changed it and the unit is still blinking red .
    any one familiar with this issue ?
    Model is HP-AW175EF3P btw
    • 31214
    Re: X-360 PSU ( PWM IC not having vcc voltage )
    does the standby supply work?
    btw, those psu's overheat over time because of dust in them.
    whenever you get one - hold a vac cleaner against the vent holes at one end for a min
    most people dont know they have a fan in them.
    • SM-Piyes90
      • Feb 2014
      • 120
      • Morocco
      Actually before that happens it was a constant orange light with 5 vdc at the 1st output and no 12 v at the 2nd output , and i was able to see the console's 3 RLOD .
      But now after removing and putting back some optoisolators ( for tests) , i get that blinking .
      I guess the blinking means that the standby supply is working .
      • kc8adu
        • Nov 2003
        • 8832
        • U.S.A!
        iirc the light wont blink if 5v stby is dead.
        did you jump red and blue?
        that fires up the main +12.
        most of the consoles are in rough shape now and not worth fixing so i use these power supplies to run radio gear.
        edit.
        now that we know it worked till you messed with it go double check your work.solder shorts reversed/wrong opto,ect.
        • SM-Piyes90
          • Feb 2014
          • 120
          • Morocco
          edit.
          Yes , that's my thoughts too .
          • SM-Piyes90
            • Feb 2014
            • 120
            • Morocco
            Okey am back to my original situation with a constant orange light after resoldering an optoisolator pin, but still no voltage at the PWM ic vcc pin , i have to mention that i have found a 150 ohm resistor that was giving 700 ohms , but things are the same even after the replacements .
            Any thoughts on this dear members ?
              • 31214
              got foto's and the pwm part number.
              • SM-Piyes90
                • Feb 2014
                • 120
                • Morocco
                Its S2153D , i will upload pictures later .
                Thanks in advance stj
                • SM-Piyes90
                  • Feb 2014
                  • 120
                  • Morocco
                  Hi again and sorry for not putting any pictures yet , i am still waiting to get my camera from a friend .
                  Anyways i have searched a bit on some forums and some say that this xbox psu does not output a 12 volts when its disconnected from the xbox console .
                  And also the 12 v rail is activated when the 5 vsb is shorted with ps-on .
                  Any ideas on this ? is it safe to keep 5 vsb shorted with ps-on and see if the 12 v is given ?
                  • SM-Piyes90
                    • Feb 2014
                    • 120
                    • Morocco
                    Ironically i have found that the enable pin was broke .
                    PSU is on now .
                    • Agent24
                      I see dead caps
                      • Oct 2007
                      • 5038
                      • New Zealand
                      Good to hear!
                      -David VanHorn
                        master hoarder
                        • May 2008
                        • 12175
                        Yes.
                        Short PS-ON to 5VSB and the power supply should turn on. No need for a resistor (though I always do it with one just in case ).
                        I have one Xbox brick that has a steady red light or no light at all when plugged in the wall. IIRC, these PSUs had either Samxon or Taicon caps in them (or possibly Ltec), so I wouldn't be surprised if there is a bad start-up cap in the 5VSB circuit.
                          • 31214
                          probably full of dust and a stalled fan.
                            master hoarder
                            • May 2008
                            • 12175
                            Actually no. I got two of them as a set. The one that was packed full of dust was working. This one is clean and not always working. Go figure.
                              • 31214
                              maybe it's not full of dust because it has a bad fan - does the fan have a tacho output that could be used to shut the supply down?
                                HP ProBook x360 Pro x360 Fortis 11 inch G9 Notebook PC Hybrid (2-in-1) Specification for Upgrade or Repair
                                This specification for the HP ProBook x360 Pro x360 Fortis 11 inch G9 Notebook PC Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Pro x360 Fortis 11 inch G9 Notebook PC boardview and Pro x360 Fortis 11 inch G9 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum....
                                09-07-2024, 05:50 AM
                                HP Pavilion x360 Pavilion x360 - 14-dh1000na Hybrid (2-in-1) 14 Specification for Upgrade or Repair
                                This specification for the HP Pavilion x360 Pavilion x360 - 14-dh1000na Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Pavilion x360 - 14-dh1000na boardview and Pavilion x360 - 14-dh1000na schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
                                09-06-2024, 03:30 PM
                                HP ENVY x360 ENVY x360 - 15-dr1011na Hybrid (2-in-1) 15 Specification for Upgrade or Repair
                                This specification for the HP ENVY x360 ENVY x360 - 15-dr1011na Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ENVY x360 - 15-dr1011na boardview and ENVY x360 - 15-dr1011na schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                                09-06-2024, 12:18 PM
