Looking for Schumacher INC-700A Schematic
  • bob_2020
    • Jan 2025
    • 9
    Have this car charger, not working, not sure what is wrong with it. Display is not coming up.
    I have poked around the board, have not found any glaring defects.
    • Jul 2011
    • 6045
    Please post pictures of all of the boards front and back of the boards
    • bob_2020
      • Jan 2025
      • 9
      Attached are pics of the front and back of circuit board.
      • CapLeaker
        Leaking Member
        • 8214
        The top picture is not any good at all… just blurry. Do some better focused correctly, straight shot, higher resolution pictures.
        • bob_2020
          • Jan 2025
          • 9
          Here is a better one.
          • redwire
            • 3910
            I can see at least one fuse under the gluefest. Vertical F2 by D3 and the transformer. Check the fuse. If it's blown then we look for shorted out parts like Q4, Q3.
            The glue is also cracked on some caps in the C29 cluster (by the current-sense shunts), which means they got prego and likely took the piss. Scrape off the glue and take a look.
            The small black relay looks like for cap precharge so it should click once the DC bus comes up, if there is power on the primary side but I'm not optimistic.
            • bob_2020
              • Jan 2025
              • 9
              Fuse is fine.
              Relay does not click
              Pulled those electrolytics, and checked esr and capacity and all good.
              • redwire
                • 3910
                How many amps output is this rated? I imagine those 5 caps get stressed out and run hot.
                I can't see a primary-side startup resistor, or a small transformer for a small aux switcher to make say 12V to power the primary IC. Somewhere this thing has a LV power supply for that- it must be under the heatsink then.
                Can you post a pic of the backside of the heatsink, to see the parts there.
                • redwire
                  • 3910
                  Second thing I always do with repairs is a visual inspection. With a magnifier and bright light, spend a couple minutes staring at it.
                  I forgot to mention I see some issues with the soldering on the PCB.
                  There's quite a few joints where the solder did not stick, like in the first pic.
                  Another joint looks like it was touched up but way too much heat was used. So the flux is burnt and likely the PCB trace and pad lifted off.
                  You can use a q-tip and IPA to gently clean off the old flux. I think the PCB is damaged there though.
Name:	schumacher bad solder joint01.jpg
Name:	schumacher bad solder joint02.jpg
                  • bob_2020
                    • Jan 2025
                    • 9
                    70 amp output.
                    I included the pic under the heat sink.
                    I see 168v dc out from the rectifier.
                    I have reviewed the two issues you highlighted in the pics.
                    For the first pic, the solder joint is fine, it's just the lighting.
                    For the second pic, overheat issue, I cleaned up the spot and there is continuity between the joint and the trace.
                    • redwire
                      • 3910
                      OK, I see black carbon spit? out of the bridge rectifier D15 on the heatsink. But you measure 168VDC so it's working. Hmmm.
                      I think Q7 TS13005 provides a low voltage for the control IC to start up. I would expect low voltage on its emitter, something like whatever zener D24 is rated for, let's say 15VDC. (168V on the collector tab).
                      Be careful with this board, it's got massive primary caps 8,800uF total can bite if tghey have stray charge. The 220k's should discharge them slowly.
                      • bob_2020
                        • Jan 2025
                        • 9
                        Yeah, when I saw the "black carbon spit" on the rectifier, I thought for sure it was a gonner.
                        For TS13005
                        G = 5.9v
                        D = 118v
                        S = 5.3v
                        D24
                        Anode = 0
                        Cathode = 4.6v
                        • redwire
                          • 3910
                          The bridge rectifier is surely damaged, or an arc from it to something else on the heatsink is what happened here. Of the 4 diodes in it, I can't see they all have survived.
                          For the primary side low voltage regulator, TS13005 NPN (BCE) the voltages look low... unless it's only a 5.3V rail? which is not enough really. It should be 12-15V at least, for the SMPS IC to start up. I can't make out its number A2494? You might have to carefully take voltage readings at each pin of the IC to see what it is doing. The TS13005 might be just overloaded a little and the voltage can't come up there. D24 should have higher voltage I would expect. What is the black relay's coil voltage written on it.
                          • bob_2020
                            • Jan 2025
                            • 9
                            Seems reasonable, though it is putting out 168v?
                            The relay is 12v written.
                            That chip is AZ494CP (on the back side of the large heatsink, right (see pic) ?)
                            Chip voltages:
                            1: 1.7 16: 1.7
                            2: 3.5 15: 3.4
                            3: 0 14: 3.6
                            4: .2 13: 3.6
                            5: 1 12: 4.7 (Vcc)
                            6: 2 11: 4.7
                            7: Gnd 10: 3.5
                            8 4.7 9: 0
                            • redwire
                              • 3910
                              The PWM IC AZ494 does not have enough supply voltage, it should be 12-15V on pin 12 VCC and you measure only 4.7V, I think that power comes from the TS13005.
                              Hard to tell at this point if the rail is overloaded and has sagged down, or the startup regulator is just weak and can't supply enough. The pics need more light and less blurrrrrrr.
                              PWM output E1 Pin 9 I think should not be 0V, so I would look downstream at the gate driver to see if a transistor or power mosfet has shorted.
                              How does Q3 and Q4 (on the heatsink) look for GDS resistances? What is the little DIP-8 part number? It's got a delicate sensor going on top of it.
                              I have seen people use a 9V battery or external PSU to (only) power the SMPS IC to see what gets hot or smokes. No mains to the board though- just powering the IC ans looking to see if the SMPS section is drawing too much current or not.
                              I don't like the black spit out of the rectifier but for now the 168VDC is enough. It could have an open diode but that won't show up until there's load. TS13005 should be getting hot.
                              • bob_2020
                                • Jan 2025
                                • 9
                                Well, I made this situation worse. I was checking if the TS13005 was getting hot. No, barely warm.
                                But, the board slipped and was on top of the cooling fan, which shorted something out, near where the mains come in. It made big sparky.
                                I don't know what damage that caused, quite for the night. Sorry, not sure if it is too far gone now. Arghhh...
                                How does Q3 and Q4 (on the heatsink) look for GDS resistances?.
                                For Q3 & Q4, I measured from Pint 1 (G) 3.2m ohms on Pin 2 (D) & 2.3m ohms Pin 3 (S).
                                55NM6OND
                                https://alltransistors.com/adv/pdfvi...d.pdf&dire=_st
                                I am having trouble figuring out what this is.
                                The numbers on it are:
                                LG387E
                                KFB220
                                Nothing smoked or got hot/warm..
                                • TinkerTron
                                  Schematic vs. Reality: Where Are the Resistors on My Sharp Clock Radio? Model FY-70CH
                                  by TinkerTron
                                  Hey everyone,
                                  I'm currently working on a mid-70s Sharp Electronic Digital Clock Radio, Model FY-70CH. I found the service manual online, printed it out, and have been studying it for a while. My main reasons for tackling this are: (1) I want to learn electronics and figured I'd start with something I had on hand, and (2) I want to fix its issues. Right now, the radio sounds awful, has about 5V DC at the speaker terminals, and the alarm time setting doesn't work. But I'm not asking how to fix these problems.
                                  Instead, here's what's been bugging me so far:
                                  The schematic...
                                  03-06-2025, 02:03 PM
                                • atunguyd
                                  Acer x163w Monitor PSU schematic
                                  by atunguyd
                                  Ii wonder if anyone can help me. I have a Acer x163w monitor which is not powering up. The PSU main capacitor's one leg had completly come off - I replaced it but the PSU is still not outputting DC. I found the monitor in questions service manual here on manuals lib but the schematic in there is a completely different - the schematic shows no mosfet to drive the transformer while the one I have does use a mosfet - also the schematic shows only one optocoupler but mine has two.
                                  The PSU board is labelled FM-20A02-AAA made by APD as per the image below. I am trying to find a schematic for this...
                                  03-05-2025, 02:08 PM
                                • Thetechdude
                                  MSI Ventus RTX 4080 16G Broadview schematic needed
                                  by Thetechdude
                                  Hi guys, I'm working on a MSI Ventus RTX 4080 16G. The GPU has 12v, 5v, however what I assume is the 1.8v rail has 1.1v and what I assume to be PEX is 0v. As you may have guessed already there is no Vmem and no Vcore.
                                  I have looked around in related forum posts for a schematic so Much appreciated if anyone can share a Broadview schematic.
                                  Thanks.
                                  07-15-2025, 11:15 AM
                                • ianpoultonknights
                                  Zenbook Flip 15 UX562AI schematic
                                  by ianpoultonknights
                                  Had one of these come in for repair with a blown battery and a WiFi issue, battery has been replaced with genuine battery (twice) and won't take a charge works fine on AC, WiFi issue gone away. Looking for a schematic so I can trace the charger circuit UM562F is only one I can find, this is the 562AI model.Had a unit come in for repair — 562AI model — with a blown battery and WiFi issue. WiFi fault has cleared, but battery won’t charge despite replacing it twice with genuine parts. Device operates fine on AC power. Suspect charger circuit fault. Only schematic I’ve found so far is for...
                                  06-26-2025, 02:41 PM
                                • Adv10119
                                  Need help please! schematic for LA-9982P rev 3.0 (A02)
                                  by Adv10119
                                  Please help, i need schematic diagram for Dell inspiron 3537 board LA-9982P rev 3.0 (A02). Specific for A02.
                                  I have a one beep with no display problem. Did reprogrammed the bios but no luck. i tried to troubleshoot using rev 3.0 (A08) version schematic and boardview but there's components/rails in the schematic that is none in my actual board, this is why I'm having problem checking every power rail needed if ok. attached is the photo of my actual board.
                                  I'm not sure if A02 and A08 is really different schematic version from each other, but I have to try....
                                  01-31-2024, 01:18 AM
