Sony SLV-E780 Power Supply Issue – Clicking Sound, Need Help Identifying Faulty Component
This topic has been answered.
  • Akuanka
    • Nov 2024
    • 8
    • Swutzerland
    I'm troubleshooting a power supply issue with a Sony SLV-E780 VCR. The device clicks repeatedly but doesn't power up completely. I've already replaced five capacitors, but the problem persists.
    Here's a video link https://photos.app.goo.gl/3Xki6yvCLn67gLX78​ showcasing the sound. Based on your experience, could this be due to a transformer, diode, or another component? Any guidance on what to test or replace next would be greatly appreciated.
    Thanks in advance for your help!
  • Answer selected by Akuanka at 11-24-2024, 05:52 AM.
    R_J
    • 9607
    Check the secondary voltages, are you getting any voltage at all on any of the secondary diodes? You should have +6vdc on PS202 fuse, if not, check for a shorted diode in the secondary.
    You replaced 5 capacitors? I guess you did not replace the bad ones, which ones did you replace? there are location numbers beside each capacitor ie Cxxx , also try replacing C154, C153 & C261, if that doesn't help, replace C253, C202.
    • R_J
      • 9607
      • Akuanka
        • Nov 2024
        • 8
        • Swutzerland
        Hi R-J, thanks for quick reply. I have checked or replaced all electrolithic capacitors, still same issue with tickling sound. Now I wanted to check voltage on secondary but where to check it? I do not see any 2nd fuse, just for 220v. I am attaching photo. thanks in advance. Is that possible to check diodes when they are still soldered to the plate? Sorry, I am beginner in this matter but learn quickly.
        Just checked and there is no ac 220v voltage on the primary fuse which I do not understand why as well as no voltage on secondary. I found 2 contacts showing 6v on the back of pcb
        • Akuanka
          • Nov 2024
          • 8
          • Swutzerland
          Here are more photos
          • R_J
            • 9607
            Check for 220v right at the plug going to the board, maybe your a/c cord is bad? Get the service manual so you can look at the schematic of the power supply.
            The only secondary voltage you will see at CN201 is the D6v standby; to check the other voltages you need to have the power supply connected to the vcr or check the other voltages on the cathode of D251, D252 and D263, on D254 Anode, you can check for negative -12v
            • Akuanka
              • Nov 2024
              • 8
              • Swutzerland
              no, cable is OK since I hear tickling sound. There was also smoke coming from the board last time I connected it to 220vAC. I have taken it out of VCR. So the only way to check diodes is to power it up? Is there a way to check disconnected from AC and in the board or I need to solder them out one by one?
              • R_J
                • 9607
                You can check the diodes with power disconnected using your meter in diode test mode. What smoked? I would find out what smoked and repair that before continuing.
                The ticking sound you hear is likely the power supply trying to start but is seeing a short in the secondary and shuts down and retries
                • Akuanka
                  • Nov 2024
                  • 8
                  • Swutzerland
                  Now I tried to power it again and there is no smoke any longer but still ticking. So is it definitely secondary? PS is one bigger board and on top of that there is smaller board. Is this smaller board secondary circuit?
                  • R_J
                    • 9607
                    Whatever component smoked, likely a resistor that is now open circuit. Just because it is no longer smoking does not mean it fixed itself.
                    • Akuanka
                      • Nov 2024
                      • 8
                      • Swutzerland
                      thanks. Primary or secondary circuit? is secondary on the small board or main PS board? The name of PS is mitsumi sr825
                      • R_J
                        • 9607
                        What did you do to cause the smoke to come out? did you short something? install a capacitor backwards? power supplies do not smoke for no reason
                        check these diodes
                        • Akuanka
                          • Nov 2024
                          • 8
                          • Swutzerland
                          Hi, you were righ. I installed C208 wrongly and C201 is missing completely. By the way do you know the type of C201 in terms of uF and V?
                          • R_J
                            • 9607
                            Here is the service manual C201 is 220µf/16v
                            C208 is off the Power Cont1 pin, having it in backwards should not cause the problem you are having.
                            • Akuanka
                              • Nov 2024
                              • 8
                              • Swutzerland
                              I remember C208 was 470 uF 10V and I dont have such cap so can I put 470 uF 16v instead?
                              • Sisko
                                Onkyo-593 No power and now clicking sound
                                by Sisko
                                Hi all!!
                                Ok just got a Onkyo SKW-593 sub woofer that has no power person told me that it smoked and that his GF let the volume full when she powered off the amp and when he came to turn it on the sub played but then suddenly smoke was coming out, didn't say from where. So opened it up and saw a resistor made of metal (pic) but can't see any writing on metal par so what ever was written on it was burnt. So I'm kinda stuck here with this. I did ask for a repair or schematics in the other group section and waiting for this but I hope someone here might lend me a hand to try and identify...
                                10-03-2025, 02:18 PM
                              • B0r1s
                                Samsung UE49KS7000SXXH - fast clicking sound in standby mode
                                by B0r1s
                                PSU - BN44-00878A
                                Symptoms:
                                The TV turned itself off, and I haven't been able to turn it back on. The standby voltage was unstable and lower than it should be.
                                A weak clicking sound was coming from the transformer.
                                Video with clicking sound:https://www.youtube.com/watch?v=lAduhjNtqCA
                                Progress:
                                After the transformer, I measured four Schottky diodes. DM862C and DM864C diodes readings were 003 in both directions. After detaching them from the circuit and measuring them, DM864C was the shorted one. These Schottky diodes are SB550.I...
                                01-17-2023, 04:58 PM
                              • slimmy182
                                [SOLVED] M1 MacBook Pro clicking sound logic board 5V no power on A2338 820-02020
                                by slimmy182
                                Hello, I bought this Mac from a friend, he said that it simply stop working. The MacBook looks very clean but does not power on, stuck on 5v 0.42A, and sometimes display 5V and 0A (then 0.071A and again 0A).
                                I opened it looking for some problem, it was not touched before for sure and the board is very clena, no spot of corrosion at all from what I can see. Voltage on multimeter of the board off the case it's the same, 5V 0.42A. But then I noticed this "clicking sound" come from the board ( I attached here the audio file).
                                Looking on google I found this:...
                                01-14-2023, 11:55 AM
                              • ChaosLegionnaire
                                by ChaosLegionnaire
                                09-13-2022, 09:02 AM
                              • Solvik
                                XFX XPS 650w 3XS PSU making Ticking/clicking sound
                                by Solvik
                                Hello
                                i have a older powersupply from XFX that makes this wierd electronic ticking /clicking noise. Its not the fan thats making the sound. See video below. Is anyone familiar with what component this sound can come from?
                                All voltages are normal....
                                02-13-2025, 02:43 PM
