HP DPS-800GP NO POWER CLICKING SOUND HELP!!!
  • NConstantinou
    • May 2017
    • 335
    • Cyprus
    Dear all,
    i have the above power supply with stb voltage 1v.
    if i connect the small board there is a continious clicking but no output voltages.
    i changed c232 on which i have 3v on main capacitors 330v.
    i also change c501 and c910 but nothing. transistors look ok.
    can someone help!!!!
  • kasfamily
    • Aug 2014
    • 765
    • Russia
    330 V is too low , it should be about 400 V
    • NConstantinou
      • May 2017
      • 335
      • Cyprus
      I am trying to find 270μf 450v capacitors but I found at 420v instead. Would that be ok for testing
      thanks
      • NConstantinou
        • May 2017
        • 335
        • Cyprus
        on the bridge rectifier i get 240v dc and on capacitors 360v.. is that correct!!
        • CapLeaker
          Leaking Member
          • 8183
          Probably not. 240VAC x 1.414 = ~340VDC. You should have closer to 400VDC on the main filter capacitor. If you aren’t getting closer to 400VDC, means you PFC isn’t working. Make sure the PFC works first.
          • NConstantinou
            • May 2017
            • 335
            • Cyprus
            i do have 460v now but does not power on.Disoldering on the board is very difficult. solder does not remove easily even if you apply flux.
            • kasfamily
              • Aug 2014
              • 765
              • Russia
              Something is not real. Show high-quality photos of the board
              • B0r1s
                Samsung UE49KS7000SXXH - fast clicking sound in standby mode
                by B0r1s
                PSU - BN44-00878A
                Symptoms:
                The TV turned itself off, and I haven't been able to turn it back on. The standby voltage was unstable and lower than it should be.
                A weak clicking sound was coming from the transformer.
                Video with clicking sound:https://www.youtube.com/watch?v=lAduhjNtqCA
                Progress:
                After the transformer, I measured four Schottky diodes. DM862C and DM864C diodes readings were 003 in both directions. After detaching them from the circuit and measuring them, DM864C was the shorted one. These Schottky diodes are SB550.I...
                01-17-2023, 04:58 PM
              • slimmy182
                [SOLVED] M1 MacBook Pro clicking sound logic board 5V no power on A2338 820-02020
                by slimmy182
                Hello, I bought this Mac from a friend, he said that it simply stop working. The MacBook looks very clean but does not power on, stuck on 5v 0.42A, and sometimes display 5V and 0A (then 0.071A and again 0A).
                I opened it looking for some problem, it was not touched before for sure and the board is very clena, no spot of corrosion at all from what I can see. Voltage on multimeter of the board off the case it's the same, 5V 0.42A. But then I noticed this "clicking sound" come from the board ( I attached here the audio file).
                Looking on google I found this:...
                01-14-2023, 11:55 AM
              • ChaosLegionnaire
                by ChaosLegionnaire
                09-13-2022, 09:02 AM
              • Solvik
                XFX XPS 650w 3XS PSU making Ticking/clicking sound
                by Solvik
                Hello
                i have a older powersupply from XFX that makes this wierd electronic ticking /clicking noise. Its not the fan thats making the sound. See video below. Is anyone familiar with what component this sound can come from?
                All voltages are normal....
                02-13-2025, 02:43 PM
              • nbnb
                Vizio VO47L FDHTV30A Picture but no speaker audio, clicking sound
                by nbnb
                I have a Vizio VO47L FDHTV30A. The picture works well, but the sound only works through the RCA output jacks. The sound does not work through the internal speakers or the headphone jack. The TV has a rapid clicking sound when the tv is on that occurs about 4 times per second. The clicking sound volume is fairly low and is not affected by adjusting the internal speaker volume level. The clicking occurs whether or not I disable the internal speaker through the Vizio setup menu. The clicking only occurs while the TV is on.
                Any idea what is causing the clicking sound? Any easy way to...
                11-23-2019, 12:03 PM
