Norstar - Plus modular ICS NT7B62FA power supply repair
  • CapLeaker
    Leaking Member
    • 8352
    Patient: Norstar - Plus modular ICS NT7B62FA power supply.
    Complaint: Doesn't power up anymore. It did work for a short while, next morning dead?
    U1 (UC2844) Vcc pin jumping up and down between 10V and 15V. Vcc supply resistor 51.1k and capacitor 100uf 40V is o.k., but jet there is nothing coming out on the other end. Secondary is producing nothing, no shorts, nothing visible.
    Replaced U1 (UC2844) with a new one, powered the PSU up on the bench and the LED started to blink faintly. Plugged the PSU card back into the Norstar modular ICS and all is working fine as kind.
    A nice easy Saturday evening repair job. Can't get much easier than that!
    • Jul 2011
    • 6070
    Nice repair
    Did you replace any capacitors
    • CapLeaker
      Leaking Member
      • 8352
      Nice repair
      No, I didn't replace any capacitors, but I did check them on my ESR tester perfectly fine.
        by sam_sam_sam
        03-31-2024, 02:12 PM
        by sam_sam_sam
        07-01-2024, 06:34 AM
      • shamsudeen
        Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
        by shamsudeen
        Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
        I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
        i know that in linear power supply the noise will be very low comparing to SMPS supply....
        07-19-2025, 07:14 AM
      • JimBanville
        Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
        by JimBanville
        The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
        Opened it up and discovered the power supply is making a faint clicking or ticking sound.
        I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
        I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
        09-13-2023, 07:21 AM
