VooDoo 5 Old School Gamer
  • Nitwig
    • Apr 2007
    • 58
    Ok, so I repair older machines. Sometimes I will set up a machine for vintage gaming. This machine for example has a voodoo 5 card, 384 MB of ram and a 500 MHZ pentium 3 and it is running windows 98. My question is this: I pulled the old power supply out and replaced it with a newer Antec 350 watt power supply. Will the CPU actually be getting less power than it was from the older Power Supply even though the new power supply is supposedly of higher quality and higher wattage? The old power supply was a Deer, so I know this one is much better. I know that newer Power Supplies skimp on the 5 volt rail. Could this be a problem for the CPU? The voodoo 5 card actually requires a molex connector for extra juice. That is why I wanted to up the wattage to 350 watts. (and of course all Deer Power Supplies should be removed as a matter of fire prevention)
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    Re: VooDoo 5 Old School Gamer
    recap the antec and it will be fine.
    it will be more than adequate.
    • Tynan Dill
      by Tynan Dill
      Assuming...
      11-22-2024, 01:46 PM
      03-31-2024, 02:12 PM
      07-01-2024, 06:34 AM
    • shamsudeen
      Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
      by shamsudeen
      Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
      I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
      i know that in linear power supply the noise will be very low comparing to SMPS supply....
      07-19-2025, 07:14 AM
    • JimBanville
      Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
      by JimBanville
      The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
      I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
      09-13-2023, 07:21 AM
