BeQuiet! Pure Power 9 CM 700W +5VSB only
  • Nabri
    • Sep 2024
    • 5
    • Portugal
    I’ve been trying my best to repair a power supply I have recently bought, but I’ve had no luck with it as I can’t find any schematics or board views online for this specific model.
    The current issues are as follows:
    if I short the PS_ON pin to ground, a relay will click and the fan will spin for 0.1 seconds, and then nothing else.
    I could not find any blown components or IC’s inside, but measuring all the output pins has led me to a conclusion of sorts, I only have +5VSB and all the other power rails show a very small voltage, like, 0.30V, for example.
    This is my first time attempting to repair a power supply, I have more experience with GPU’s so I’m stumped as to where I’m supposed to be looking and measuring, any help is appreciated!
  • CapLeaker
    Leaking Member
    • 8196
    First thing: Welcome to Badcaps!
    A picture can say 1000 words. Use the attachment function an upload straight shot, high resolution images from top and bottom of the PSU. This will tell a story on how this thing is built.
    From what I gather so far, it sounds like the supervisor IC is shutting everything down. This can be for various reasons. Look at the supervisor IC somewhere in the secondary and see what the part number is (something like WT75xx). I think it is a WT7527.
    Once you got that, pull the spec sheet and go over the pin out. Find the FPOB pin (3) (fault protection output pin) and measure the voltage on it. If this pin is "high" (something like 5V) the supervisor has shut the PSU down and there is some kind of a problem with either one voltage rail on the secondary or all of them. If you want a good read on how to fix a head scratcher, here is an example of mine: https://www.badcaps.net/forum/troubl...300bn7-2-blown
    Do not get too exited poking around in the primary while being plugged into power mains. The power factor correction, boosts the voltage up to 400VDC on the main filter capacitor! Be warned.
    If you measure DC voltages after the bridge rectifier on the primary side of the PSU, your ground point is always the negative terminal on the main filter capacitor.
    Measuring voltages on the secondary (low voltage side) you ground point here is you main ground on this side. Good luck!
    • Nabri
      • Sep 2024
      • 5
      • Portugal
      Thank you for the warm welcome!
      after probing around I found something interesting, the third pin of the IC does indeed measure 5V, I read the thread you linked and I decided to try to short the pin to ground and the relay will click rhythmically, about every 0.5 seconds, which is interesting.
      I did also find that a rail seems to be completely missing, starting from a blue through hole resistor and down to a SMD diode on the back of the PCB near the 240V input, the solder joint looks iffy but that was me previously. If I use my multimeter, I don’t even get a reading, it just remains on 1 in continuity mode.
      • Nabri
        • Sep 2024
        • 5
        • Portugal
        After further testing and another look at the post you linked, I’ve come to the conclusion that the main Teapo 420V 390uf capacitor is completely effed.
        I measured the voltage after turning the power supply on and I got -110V on the high voltage side and after disconnecting it without discharging the cap, it reads… 0V. I’m pretty sure it’s dried up inside as it looks like new outside (besides a teeny tiny bit of bulge on top, but no leaking)
        I’m not very sure though, I’ll order a new one and test it out and see what happens.
        • Nabri
          • Sep 2024
          • 5
          • Portugal
          Confirmed!
          Just desoldered it and got to testing, completely open circuit, even tested a known good capacitor out of circuit just to see if I wasn’t crazy and yep, this one is totally dead.
          So that makes two of us who’ve had issues with Teapo caps, I’ll be adding them to my list of brands to avoid. (I’m pretty sure their lower maximum rated temperature is what causes them to dry out, since power supplies get pretty warm and most people who own a computer always forget to clean out the insides of them, so they get clogged with dust and lint, causing them to run hotter)
          • CapLeaker
            Leaking Member
            • 8196
            Good job! See… power supplies aren't that bad, once you know how to go about fixing it. The snap in caps seems to be a problem. Not saying this is always the case, with the main filter capacitor being bad (I had seen them go totally short too, but that's a rare case), but it can happen and the supervisor doesn't like it and turns the PSU off.
            • Nabri
              • Sep 2024
              • 5
              • Portugal
              I have already ordered a replacement and will update once it is soldered in place.
              I hope the problem was this cap, I’ve read online that capacitors measuring open circuit are completely normal, but I’m not sure. I tested a known good smaller cap in continuity mode and saw a value rising until infinity, which is exactly what the bad cap doesn’t do…
              • kotel studios
                FSP300-60GTF - no 5VSB, PS_ON; 5VSB carnage
                by kotel studios
                Finally replaced all of the shorted 4148's and resistors and an blown tl431 on my FSP300-60GTF after 5VSB going crazy and destroying it self. Those components also made the secondary transistors appear shorted (while in reality they weren't).
                Powered it on through my dim bulb tester and they (bulbs) only flash once meaning primary caps are getting charged, but that's it. No 5VSB, PS_ON voltages.
                I am sure I have replaced the components correctly and that there weren't any shorted/blown traces left.
                Any ideas where to go next?
                02-23-2025, 11:47 AM
              • Stanley1843
                PS3 Slim Turns OFF Immediately After Turning ON
                by Stanley1843
                Hi, my PS3 Slim (CECH-3003A) when I connected to 230V the PS3 the indicator of the switch is red and after pressing it the is green (fan spins) for only 10 seconds and then completely off. Some times also is completely off when I connected to 230V.
                On the CN101 connector at the 5VSB pin I measure 0V.
                Without the CN101 connector pluged in the PS3 board (on the fly) I am measuring 5V on the 5VSB on the power supply side.
                On the 5VSB in respect to ground I am measuring 6 Ohm resistance. There is any schematic to find which ICs supplied from 5VSB or any suggestions where l have to...
                12-30-2024, 02:56 AM
              • mrcliem
                CM V700 no +5vsb, ICE2QR4765 low VCC in... Need guidance please...
                by mrcliem
                Hello...
                I got my self a dead CM V700 PSU, with nothing on +5vsb
                I have tried to fix it for the past 2 week, and I'm stuck... so i guess i post it here to get some pointer before i scrap it..
                As you can see in photo, the psu still pretty clean, no visible damage or bulging cap.. when i got it, it still has CM seal on it
                The +5vsb system use ICE2QR4765, I have trace and measure the voltage on ICE2QR4765 and the only voltage reading i got is in VCC 4.8v, Drain 310v and FB 3v.
                I have read the datasheet and and still can not...
                06-29-2023, 08:18 AM
              • Toueno
                Dyson Pure Hot+Cool HP00 - Datasheet needed
                by Toueno
                My Dyson Pure Hot+Cool, model HP00, no longer starts.
                After disassembling and accessing the electronic motherboard, I found that the 16A fuse soldered to the motherboard is dead. I decided to do an electronic shunt to see the reaction, and the Dyson turns on for a few seconds and then turns off.
                It is likely that a voltage control chip or a safety chip is dead, but without the electrical schematics, the repair becomes complicated…
                Thank you in advance for your help.
                Best regards
                08-14-2024, 10:38 AM
              • socketa
                Zalman ZM500-GV stops after 40s and 5VSB drops to 2.5V
                by socketa
                Rescued this one
                Started it up in the computer case, and noticed that it would shut down after about 10s in the BIOS
                Took it out, connected to hard drive and it loses all power on all rails (except for 5VSB) after about 40s or so. (the same result happens without a hard drive connected)
                The 5VSB drops to 2.5V when it 'shuts down'
                And the voltage across the primary cap falls from 335V to 330V at the same moment
                I think that the 5VSB is regulated by an A6069H PWM chip (which was initially dropping to 2.5V even before the the PS-ON was grounded - but it now stays at...
                12-20-2022, 03:06 AM
