Dell Ac/Dc adapter not charging
  • kamel
    • May 2011
    • 118
    • TUNISIA
    Dell original adapter 19.5v -3.34A - model : DA65NS4-00 is no longer charging, but it powers up laptop.
    Tried laptop with another adapter, battery charged.
    Opened the adapter, and tracked the middle pin of the connector, found and
    IC 2929 C4381, with "0" voltages on each pin.
    How can I check if the IC is failing, as no datasheet is available on the net ?
    Is there any substitute for the IC ?
    How can I trace further the issue of charging pin failing (no signal output) ?
    Need some diagrams of Dell and hp adapters with 3 pin connectors, can anyone help ?
    thank you
    • 31040
    Re: Dell Ac/Dc adapter not charging
    meter the cable from the connector to the board.
    if it powers the laptop then it works,
    if you go into the bios it probably says "charger not recognised".
    this is a symptom of a broken data wire, or a bad 1wire eeprom.
    http://www.laptop-junction.com/toast...r-id-chip-died
    http://macbookprorepair.net/2011/02/...tery-revealed/
    https://jack380.wordpress.com/2009/0...be-determined/
    http://www.wirelessforums.org/alt-co...hip-58399.html
    this shit just goes on forever if you use a search engine - it's a very big problem!!!
    • kamel
      • May 2011
      • 118
      • TUNISIA
      Sorry, for the late reply.
      As a feed back, it finally turned out to be a failing eprom "2929 C4381", replaced with a Dallas one, recovered from an other faulty dell adapter, it was recognised in the bios and charged laptop.
      I discovered a curious thing after replacement, Bios specified 90W adapter, instead of 65W, it's probably due to soldering an eprom of a 90W adapter in a 65W one.
      Thank you stj for your good contribution.
      • powerrs
        • Apr 2013
        • Brazil
        reviving this post. Could you tell which similar component you used?
        Thks
          • 31040
          it's a 1wire eeprom made by Dallas
          you can use a pic microcontroller to replace it, but you need to program in with the right code for the charger.
          • Grucha98
            Dell Latitude E7440 battery not charging only works on AC Adapter LA-9591P
            by Grucha98
            Hi, i have problem with dell E7440, battery is not charging. Idk all story. Original Dell Adapter broken up (its not give 19V) i guess first ac adapter broken up and it broken charging circuit in laptop. Laptop has clone battery (Green Cell)
            Laptop works on clone adapter, and its not charging battery. Like on photo. I checked mosfets near battery plug. They are not shorted. But on PQ809 and PQ810 are low on diode mode (both 0.25V) I desoldered them and check on bench and they are good both 0.5V on diode mode. I checked only drain - source way. So its board circuit it should be higher,...
            09-09-2024, 11:22 AM
          • Bowline
            by Bowline
            06-11-2025, 10:13 AM
          • flat-earther
            ASUS X54H laptop thinks it's always charging even with charger unplugged
            by flat-earther
            The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
            Windows also shows ''Plugged in'' when charger is not connected.
            This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
            Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
            If I let battery run out and say it has 3% Windows will...
            06-24-2025, 09:32 AM
            DELL Vostro 5471 Notebook 5000 Specification for Upgrade or Repair
            This specification for the DELL Vostro 5471 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 5471 boardview and 5471 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Vostro 5471 Notebook...
            09-06-2024, 07:18 AM
            DELL Vostro 3578 Notebook 3000 Specification for Upgrade or Repair
            This specification for the DELL Vostro 3578 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 3578 boardview and 3578 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Vostro 3578 Notebook...
