Re: FSP400-60GLN worth fixing?
For the record, that R44 on my chassis is a zero ohm item, i.e it is a circuit link. Got no issues over that side of the board, but would very much appreciate help at the R92 position.
 Half of the computer problems is caused by bad contacts
		 ) Nichicon PW unless the reading in question was taken with its full leads (0.09Ω ESR would be spot-on for a 10mm 1000uF 6.3V PW). In accordance to the datasheet, a 1000uF 10V or 16V PW should not be higher than 0.07Ω or 0.06Ω ESR respectively. "Bad batch"... seems to me that almost all CrapXons have the same manufacturing process flaws so they are bound to fail the same way.
