Testing monitors that need power packs
  • Amraks
    • Nov 2011
    • 725
    I am after something that will enable me to test monitors I have with out having to buy power packs and waste money if these monitors never go again.
    Any idea's what I can use?
    Re: Testing monitors that need power packs
    Do you have any variable power supply?
    What is the voltage and current requirement for the monitor?
    • Amraks
      • Nov 2011
      • 725
      No I don't have a variable psu
      14v 2.14a
      • Amraks
        • Nov 2011
        • 725
        any suggestions would be good
        Can you get the variable psu with DC plugs?
          The DC plug will be the problem since they are not standardized. You may be able to run it using fully charged car battery, but you will have to find the DC plug.
          • shovenose
            Send Doge Memes
            • Aug 2010
            • 6575
            You could get a universal power adapter designed for laptops. Get one of those with tons of tips. Chances are at least one of the tips will work on most of the monitors.
            • Amraks
              • Nov 2011
              • 725
              Don't mind buying a variable psu.
              I was just thinking they have them kits why not for a variable psu
              • Amraks
                • Nov 2011
                • 725
                I was thinking this but most range from 15v
                • shovenose
                  Send Doge Memes
                  • Aug 2010
                  • 6575
                  I've seen plenty of universal adapters with 14-24V (I think?) which should be enough for most monitors.
                  Besides, a 14V power supply should work for a 13V monitor just as well. And a 24V supply would work for a 25V monitor, if you know what I mean. The tolerances are not that tight anyway.
                  • Amraks
                    • Nov 2011
                    • 725
                    so I could just a dc variable power supply and use the clips?
                    Neg on chassis of monitor positive on the positive side of things?
                    • mariushm
                      • May 2011
                      • 3799
                      Recycle a 19v DC adapter for laptops and then buy one of those LM2576 or LM25** dc converters from eBay : http://www.ebay.com/sch/i.html?_odkw...erter&_sacat=0
                      You can set any voltage between about 1v and input voltage, so you can do 12-14v no problems at all up to 3A.
                      Just forget about the jack, you can just open the monitor and solder the two wires straight to the board.
                      • Amraks
                        • Nov 2011
                        • 725
                        This comes with what I need but Haha the psu is out of my price range at the moment.
                        if i could find them accessory's its got with it I would be happy.
                        http://www.ebay.com.au/itm/312055A-D...item3f3355ef9f
                        • Amraks
                          • Nov 2011
                          • 725
                          I think I have it
                          cable pigtail 5.5x2.1mm jack
                          And
                          5.5x2.1mm Jack to 28 jacks
                          Would be what I am after to run off a variable power supply.
                          • mariushm
                            • May 2011
                            • 3799
                            You can buy the jacks separately, just search for "power jack set mix" in ebay.
                            The power supply in the ebay link is a very cheap and crappy adjustable power supply. I wouldn't recommend it even if you have the money.
                            • Amraks
                              • Nov 2011
                              • 725
                              was thinking the same thing very crappy looking.
                              • Tynan Dill
                                by Tynan Dill
                                Assuming...
                                11-22-2024, 01:46 PM
                              • PantherDave
                                by PantherDave
                                Hi all!
                                05-29-2024, 02:01 PM
                                09-06-2024, 05:59 AM
                                Recap an Adjustable Power Supply DC 0-48 / 0 to 10 A going to use it to charge battery packs
                                I have a 24 volt version of the same type of switching power supply but that one I am relocating to meter module and I might do the same thing with this one but I have to modify an enclosure that is not made for this type of switching power supply in fact I am not sure exactly what type of switching power supply it actually fits because none of one's that I have the screws holes do not line up and not even close but the switching power supply fits in the enclosure
                                So I have take out the switching power supply board out of its enclosure and drill the hole so that it can be mounted...
                                04-14-2024, 05:45 PM
                                HP Pavilion Power 580-187nz Pavilion Power i7-8700 Specification for Upgrade or Repair
                                This specification for the HP Pavilion Power 580-187nz can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Power 580-187nz boardview and Pavilion Power 580-187nz schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                09-12-2024, 02:15 PM
