Dell (Liteon) PS-6311-1DS 2005 power supply.
  • ron350
    • Feb 2014
    • 296
    Please don't throw rocks I am new to computer power supplies.
    This is a working Dell Liteon PS-6311-1DS out of a Dimension 4700 that was working.
    My question is are there common failure caps in this Power Supply that need to be replaced?
    So far I have found a 22 x 50v reading 3 ohms and a 2.2 x 450v reading 5 ohms and cracked solder joints on the GBU808 bridge rectifier.
    Thanks for any help
    Ron.
  • ben7
    Capaholic
    • Jan 2011
    • 4059
    Re: Dell (Liteon) PS-6311-1DS 2005 power supply.
    Thanks for any help
    Ron.
    Mainly the OST and Ltec capacitors are likely to go bad.
    In general, the caps that are on the secondary side should be replaced, I'm talking about the larger ones, like 1000uF to 4700uF (if there are any that large capacitance wise).
    Also, replace all the capacitors in the 5V standby and the capacitors in around the transformers, between those two heatsinks.
    I had one of these (or at least it was very similar) with both primary side caps bulging a bit, they were OST, so, go figure... replaced them with american made capacitors
    Muh-soggy-knee
    • ron350
      • Feb 2014
      • 296
      Ben7 thanks for the help.
      How can I track down the 5v standby caps?
      • senz_90
        • Aug 2013
        • 328
        • Indonesia
        just follow the +5V STBY cable line reverse back, you will found it.
        "There is no shortcut to be successful. No pain, no gain."
        Best Regards
        Rudi
        Thank You
        • ron350
          • Feb 2014
          • 296
          Thanks senz 90.
          I followed the purple wire and it is marked 5VSB on the board.
          There is only one 470 x 10v cap on that line, that I can see. Guess I will replace all the cps on the board I can.
          • Agent24
            I see dead caps
            • Oct 2007
            • 4952
            • New Zealand
            I recently repaired a Dell\Lite-On PSU, All the OST capacitors were bad except for one and the primaries (and only one of the bad OSTs was slightly bulging!)
            The LTecs were still OK but I would replace them anyway. Two Taicons buried near the heatsink were marginal.
            One thing to note with Dell PSUs, the older models can use a non-standard pinout on the main power connector. See here for Dell vs normal layout: http://www.smps.us/power-connectors.html - bear this in mind if you want to use a Dell PSU with a normal machine! - you will have to re-wire it.
            -David VanHorn
            • senz_90
              • Aug 2013
              • 328
              • Indonesia
              Thanks senz 90.
              Yes, that is the right caps, it is common thing 5VSB has 470uF on their line. right step is you could try to replace them all likes agent24 said except primary caps.
              Best Regards
              Rudi
              Thank You
              • ron350
                • Feb 2014
                • 296
                Agent 24 you are correct.
                I can see two small 2 tan color Taicons on the vertical board between the heat sinks and another hiding in the wire jungle.
                Can I ask how the Ost caps and other power supply caps usually test bad; low value, high esr reading or what?
                • Agent24
                  I see dead caps
                  • Oct 2007
                  • 4952
                  • New Zealand
                  Stroke of luck then! I was talking about a completely different model PSU
                  The ones in mine were all high ESR, I think one also had severely reduced capacitance.
                  -David VanHorn
                  • mockingbird
                    • Dec 2008
                    • 5484
                    I've got a Lite-ON 6301-08A, but it is too different from yours to tell you exactly what caps to change... My unit has all OST RLP series caps. Similarly enough though, I've also got the small 10mm 450V 2.2uF cap near the primaries, but mine is stock UCC KMG series.
                    What you need to do is make a list of all the caps in the PSU in the following fashion:
                    Code:
                    1) xx Volts, xx Microfarads, xx Millimeters Width * xx Millimeters Height, Brand, Series
                    Also, can you post of a pic of the PSU label? I'm curious to see the rail ratings on your model. Mine has two +12V rails, one with 10A and the other 13A. Would love to see the ripple on those rails though, because the 12V rail capacitance is some of the weakest I've seen value-wise.
                    • ron350
                      • Feb 2014
                      • 296
                      Large capacitors on output side.
                      1-470 x 25v @ 8 x 20mm Ost RLP
                      1-680 x 16v @ 8 x 20mm UCC KY
                      3-2200 x 6.3 @ 10 x 20mm Ost RLP
                      1-2200 x 16v @ 12 x 20mm Ltec LZP
                      1-3300 x 6.3 @ 10 x 25mm Ost RLP
                      • mockingbird
                        • Dec 2008
                        • 5484
                        Thanks for the picture of the label. Looks like your revision is newer than mine, namely because it has more powerful 12V rails.
                        1) 613750
                        2) P12378-ND
                        3) 493-4852-1-ND
                        4) 565-3368-ND
                        5) 1189-1466-ND
                        Please post the rest of the capacitors. All of them must be changed, except for the two large primary capacitors.
                        • ron350
                          • Feb 2014
                          • 296
                          I think this is all of them.
                          On the large output caps why did they use 2200 instead of 3300?
                          1-2.2 x 50v @ 5 x 12mm Taicon VT
                          1-2.2 x 450v @ 10 x 12.5mm Ltec TY
                          1-4.7 x 50v @ 5 x 11mm Taicon VT
                          1-10 x 50v @ 5 x 11mm Taicon VT
                          4-10 x 50v @ 5 x 11mm Ost RLG
                          1-100 x 25v @ 8 x 11mm Ltec LZV
                          1-120 x 16v @ 6 x 11mm Ost RLP
                          1-470 x 10v @ 8 x 12mm Taicon HG
                          1-470 x 35v @ 10 x20mm Ost RLS
                          2-680 x 220v @ 22 x 48mm Elite GM
                          2-1000 x 10v @ 8 x 20mm Ltec LZP
                          1-2200 x 16v @ 12 x 20 Ltec LZP
                          3-2200 x 6.3v @ 10 x 20mm Ost RLP
                          1-3300 x 6.3v @ 10 x 20mm Ost RLP
                          • mockingbird
                            • Dec 2008
                            • 5484
                            Capacitance values in pi filters are based on formulaic calculations. Even if increasing the capacitance were to have any positive effect, the only way to really find out would be to analyze the rail's ripple current under loads and crossloads before and after the modification (In other words, leave it be).
                            1) 1189-1661-1-ND
                            2) P5873-ND
                            3) 565-1597-ND
                            4) 1189-1883-ND
                            5) 1189-1883-ND
                            6) 493-11847-1-ND
                            7) 493-1520-ND
                            8) 493-1493-ND
                            9) P12389-ND
                            10) P12415-ND
                            11) P12378-ND
                            12) 493-8314-ND
                            13) P12354-ND
                            14) 565-3368-ND
                            15) 493-4852-1-ND
                            16) 1189-1466-ND
                            Please double-check my links to make sure I didn't make any mistakes. Don't forget to post results.
                            • ron350
                              • Feb 2014
                              • 296
                              Mockingbird thanks for going to the trouble of giving me the capacitors to order.
                              And thank you to every one that has helped.
                                by sam_sam_sam
                                03-31-2024, 02:12 PM
                                by sam_sam_sam
                                07-01-2024, 06:34 AM
                              • JimBanville
                                Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
                                by JimBanville
                                The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
                                Opened it up and discovered the power supply is making a faint clicking or ticking sound.
                                I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
                                I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
                                09-13-2023, 07:21 AM
                              • CMCM
                                Russound CA4 Power Supply Repair
                                by CMCM
                                Hello Everybody,
                                Trying to repair a power supply from a Russound CA4 Multizone Controller (picture attached)
                                Russound no longer supports it but were kind enough to provide a schematic of the power supply (pdf attached).
                                The outputs marked 12v and 20v are all measuring only 1v.
                                The board is clicking, which I think means it is in something called hiccup mode when the flyback transformers switches because of an internal problem or something else on the board Overloading it.
                                The capacitors physically look clean (no bludgesor leaks) and...
                                07-03-2025, 01:12 PM
