Element Power EP-500 BR
  • tleu8472
    • Dec 2011
    • 36
    How would you rate the quality of this PSU? It is relatively inexpensive. Some pics are at: http://www.highpower-tech.com/eng/pr...23154415#award
  • Khron
    • Sep 2006
    • 1350
    • Finland
    Re: Element Power EP-500 BR
    I could only find a review (with internal pics, which is the most relevant part ) of the 600w version from this same series, and there's no real reason to believe this 500w model is much different.
    http://translate.google.com/translat...test-practic/3
    Full complement of Teapo - might be ok for a while, if they're well ventilated. With the secondary caps crammed in-between all the output wiring, that might not happen, though...
    Khron's Cave - Electronics - Audio - Teardowns - Mods - Repairs - Projects - Music - Rants - Shenanigans
    • Tynan Dill
      by Tynan Dill
      Assuming...
      11-22-2024, 01:46 PM
    • PantherDave
      by PantherDave
      Hi all!
      05-29-2024, 02:01 PM
    • GLISIT
      by GLISIT
      01-16-2025, 02:29 PM
      09-06-2024, 05:59 AM
    • meraklinetx
      Asus Z97-a power cycle, no boot no cpu voltage
      by meraklinetx
      Hello, I have an asus Z97-A motherboard and it doesn't start which was working properly before, the problem isn't related by ram, ram slots or psu (I changed all and nothing work), the exact problem is when you switch it on , it starts and after 1 seconds (no boot or display picture) it's off and then on cycle continuously until you power it off from psu also it's responding to the power switch for turning it off if you keep pressing it 3 or 4 seconds (power button pin has 3.3v) , also when you start it with eatx 12v socket connected this is happening (power cycle also all voltages are resetting...
      05-10-2023, 06:08 AM
