ACBel API1PC36 Capacitors Soldering Points
  • kaydee
    • Apr 2024
    Hi there!
    I took my time to identify the soldering points for the capacitors. This should be used as a reference with no guarantee!
    Best,
    kaydee
  • dragon3x
    by dragon3x
    power on.
    Here are some examples :
    switching supply area).
    than 6.3 V.)
    03-21-2025, 02:46 PM
  • kaydee
    ACBel API1PC36 Support needed
    by kaydee
    I recapped the power supply recapping the Power supply with Toasty's sketch (replaced all Shotgun, as well as "Other" caps besides C4+C5+C37). Somehow the PSU turns automatically on when I insert it in the socket. Did anyone else encounter this problem?
    I would be really thankful for some advice.
    Best,
    Koray
    04-29-2024, 10:34 AM
  • slybunda
    AA and AAA battery charger capacitors?
    by slybunda
    hey all, iv got my favourite battery charger here which iv had for many years probably 15 years now or maybe even more. it still works good but thought id open it up to clean the dust out of it, lots of dust inside but now its clean and noticed 4 capacitors inside it and wondered if i should replace them.
    it has inside:
    2 x 47uf 16v caps 105c branded as Su'scon (lol sounds sus to me)
    2 x 470uf 16v LZ105c branded as G.Luxon
    not heard of these brands are they any good?
    iv attached photos of the charger and the board inside for an idea on the type of...
    12-24-2023, 04:41 AM
  • Ady2017
    SMD fuse soldering advice please
    by Ady2017
    Hi all. I need to replace an SMD fuse on my camcorder and this is the first time I have had to do any SMD soldering so your advice would be appreciated. Below is a picture of the board that I am working on and I have highlighted the fuse that needs to be replaced. I managed to zoom in to take this picture but the fuse is really tiny and is sandwiched between other components so this is going to be a new milestone for me. I appreciate that I am going to have to buy a new soldering iron if you could advice on what I need please. I was thinking about putting a big soldering iron across the whole...
    11-07-2025, 12:03 PM
    After all of...
    07-13-2024, 08:14 PM
