30V 3A Powersupply - regulating only to 8V
This topic has been answered.
  • worldofskin
    • Jan 2022
    • 21
    • Slovensko
    Hey guys! i build a 30V 3A powersupply. My friend blown it... He connected cables to the wrong connectors. I changed the op amps, shorted zener diode and a 9014. Now the powersupply works again but only to 6V. When i measured the caps they looked in spec. But after i connected 2200uF cap on the main power rail parallel to the C1 - 3300uf one - output voltage is now regulatable to 8v. Any idea where to look ? or what to do ? R1 and R2 are getting hot. The input of the transformer is 40V after rectifiers. Its a 24V transformer on 230V mains voltage.
  • Answer selected by worldofskin at 02-06-2024, 02:57 AM.
    redwire
    • 3910
    I looked at the voltages and most are OK. The IC's are powered at 44V which is up there.
    I would guess Q1 SS9014 replacement has the wrong pinout or installed wrong - should be EBC. Double check whatever you put in there is NPN. It is probably clamping U2 output at the 8V or so. U2 would also get quite hot.
    Q1 is supposed to conduct only during power on/off to prevent output voltage spikes. You can remove it, run the PSU and see if it works past the 8V. Otherwise U2 is bad.
      • 21002
      Post the full PSU model number,PCB model number and pictures of both sides of the PCB
      • harp
        • Jun 2022
        • 603
        • Planet Earth
        Maybe to put some more information about your friend, what is connected (what kind of load, battery...), where and how (respect to polarity)... I supose that you check everything and any components seems good in spec?
        • redwire
          • 3910
          I recognize the schematic as the infamous "0-30V 2mA-3A" power supply kit board. It's a chinese copy of the Practical Electronics Nov. 1978 design but not using 741's.
          OP if you take voltage measurements on all the IC's pins and post them here, can figure what is wrong. Use the output(-) as multimeter(-) common, and careful not to short stuff out with the (+) probe.
          Make sure the -5.1V rail is working zener D7 should have 5.1V across it. If that rail is not working U2 will get very hot.
          • worldofskin
            • Jan 2022
            • 21
            • Slovensko
            101-92-133
            • worldofskin
              • Jan 2022
              • 21
              • Slovensko
              My friend is a guy for whom i build the PS. Its a graduate project.... What happened is he connected the 24V output from 7824 to one of the connectors for potentiometers - my guess is to the P2.(i connected external disply on the 7824 regulator instead of a fan, and the display has the same connector as the potentiometers) It has blown U2, the 9014, and the 5V zener diode.
              Yes i checked i would say "all" of the components and they seem ok. I know that if they were - the PS would work ... But i am too short for this one.
              • worldofskin
                • Jan 2022
                • 21
                • Slovensko
                Thank all of you for all the replies! Not one teacher of my school could help me! You helped me more than them even now!!
                I replaced all of the OP amps for "LM741CN" - because of the high input voltage. Its still 1V over the max but i think it should work for a little while
                Yes thats exactly right (That it is the chinese powersupply kit). i am sorry for not posting photos of the board. Idk why i didnt.
                Both of the zener diodes have 5.1V across them.
                Measured with the black probe (-) -> on the OUT -
                U1
                1- 5mV
                2- 5.146 V
                3- 5.142 V
                4- 0
                5- 5,2mV
                6- 10,28V
                7- 39,9V
                8- 0
                U2
                1- -5,2V
                2- regulatable from 0 to 2.2V - after 2.2V it drops back to 2.1V
                3- Regulatable from 0 to 10.25V
                4- -5,2V
                5- -5.2V
                6- regulatable from 0 to 7.26V - with the Voltage potentiometer - P1 // output voltage is 6.5V when is this pin 7.2V
                7- 38,9V
                8- 0
                U3
                1- -5.2V
                2- 0V
                3- regulatable from 0 to 1.4V with the Amp potentiometer - P2
                4- -5.2V
                5- -5.2V
                6- 38.9V
                7- 39V
                8- 0V
                • harp
                  • Jun 2022
                  • 603
                  • Planet Earth
                  What is voltages on base q1 q2 q3 q4?
                  Have you check that transistors not shorted, are they heating while power on?
                  Output voltages from psu is... you say 6v... is this regulated, how much current can you pull out without voltage droped?
                  • redwire
                    • 3910
                    • worldofskin
                      • Jan 2022
                      • 21
                      • Slovensko
                      You are the KING!! Thank you so much. Replaced the 9014 and it works!! But it was soldered correctly.... Maybe just a bad transistor...
                      Thank all of you for the replyes! Have a great day!!
                      • survivalbloke
                        Acer Predator Helios 300 - will not power up if battery is CONNECTED
                        by survivalbloke
                        This was a no power initially. Thanks to your help, I discovered it was the first mosfet, so I replaced. Now, the device will power up only if the battery is NOT connected. As soon as I connect the battery, it shuts off. If I connected the battery while the device is off, it simply will not respond to the power button. I replaced the battery, and while I suppose the new battery could be faulty, I'm assuming it is not. I'm having the same behavior with the new battery. I measure .2v at the charging coil. Manually applying power to the + and - at the battery header, there is no charging happening....
                        06-25-2025, 12:20 PM
                      • beogeek
                        820-2915-A Wont power on with battery connected
                        by beogeek
                        Ok so this doing my head in and hopefully someone more knowledgeable will be able to assist.
                        I've got a MacBook Pro 820-2915-A it will power on without the battery connected, but when the battery is connected it will do a 2,3-second fan spin when pressing the power button and then nothing.
                        After measuring and probing around I found that R7051 was bad, reading high instead of 2.2Ω so I replaced it. Still the same issue, I have the green light on the charger but it won't power on or charge the battery.
                        So to cut the long story short I've replaced U7000,...
                        02-26-2022, 01:29 AM
                      • muhuruu
                        PS5 too many USB devices connected
                        by muhuruu
                        Hello. I have a problem with a PS5 console that I bought to learn electronics repair. The auction description indicated that the console had been dropped. The HDMI port and USB ports were damaged. The HDMI port was replaced by the previous owner, and after his repair, the console worked for 2 days and then became dead. After receiving the console, I replaced all the USB ports. After replacing them, the console started to turn on. On the logo screen, it displays "too many USB devices connected". My further attempts to fix the error involved replacing the Southbridge, 4 TPS2001D chips,...
                        05-19-2025, 07:14 AM
                      • versionlab
                        Weird problem, laptop stays on when connected to another pc
                        by versionlab
                        Hi, I want to ask for advice about an interesting issue I've been having with a sony vaio laptop.
                        Client came and said that "a desklamp touched the back of the lid while laptop was operating normally and it caused the office's circuit breaker to trip. Laptop had never turned on since".
                        After taking the laptop apart (checked dc adapter everythin ok), I found a faulty MOSFET on the motherboard which I replaced. Laptop managed to turn on. However, while booting it shut down. Nothing else seemed faulty and thermals were ok. Shutting down was coming at random...
                        10-26-2022, 03:43 AM
                      • wraster
                        Laptop stays on for only ~10sec when battery is connected, fine otherwise (Lenovo ThinkBook 15 G4 AMD)
                        by wraster
                        I have a Lenovo ThinkBook 15 G4 AMD (HLXB5 LA-M062P) that, when the battery is connected, starts up and shuts off in about 10 seconds, even when connected to power supply via USB-C charger. When the battery is disconnected, the computer stays on as in normal/expected operation (powered by USB-C charger input). I bought a new battery and see the exact same thing. My conclusion is it is not the battery itself but maybe some circuit or component involved in battery/DC-in crosstalk. I found a schematic but not boardview (request link below - sorry for the formatting, I'm not sure how to make an inline...
                        Hi, I have a TB 15 Gen 4 that has an issue with the battery circuits. I believe the schematic is the same as this one: https://www.badcaps.net/forum/troubleshooting-hardware-devices-and-electronics-theory/troubleshooting-laptops-tablets-and-mobile-devices/schematic-requests-only/3522169-lenovo-thinkbook-14s-yoga-gen2-la-m062p
                        02-25-2025, 11:33 PM
