I killed my VC04 Pro and need help
This topic has been answered.
  • Dukenukemx
    • Nov 2012
    • 43
    Was trying to find a short on my motherboard and it started to smell. I left it alone and now the display always shows 4.095 like there's a constant short. Took it apart and something that was toast to the point that I don't know what it was. I assume resistor since it says R28 next to it. Anyone know what this resistor value is suppose to be? Has anyone else ran into this issue with this tool? Still says 4.095 even though I removed the resistor.
  • Answer selected by Dukenukemx at 01-17-2024, 01:21 AM.
    temyth
    • Jan 2024
    • 45
    • Brazil
    Originally posted by Dukenukemx
    I think it's a 0hm resistor. Short it with a screwdriver and it works normal. `Makes sense since not many resistors have that many zeros. I wonder if I should replace it with another zero ohm resistor just put in a fuse? I might try 100, 200, 300, and etc to see if there's a different reaction from the device. It's funny because nothing in here makes use of the heatsink looking giant metal casing.
    Click image for larger version Name:	IMG_20240116_000052024.jpg Views:	0 Size:	5.83 MB ID:	3179430
    it is a fusistor. you can just jump it but you would have no protection. just replace for another 0ohm fusistor or something close to 0
    • Dukenukemx
      • Nov 2012
      • 43
      • temyth
        • Jan 2024
        • 45
        • Brazil
        • Dukenukemx
          • Nov 2012
          • 43
          Thanks, I'm going to put in a 0ohm resistor. Kinda stupid that shorting a device meant to be shorted would damage it.
          • gaelican
            Asus ROG ga401IV motherboard - AC Short Protection resistor getting hot
            by gaelican
            I am working on an Asus ROG laptop repair. I was able to find that there is a short on the motherboard, and the 20 volts from the charger only gets to the first mosfet before disappearing.
            When looking around with a thermal camera, I noticed the chip marked "14C" in the picture was getting warm. Nothing else was receiving heat.
            I found a boardview diagram and schematic for a motherboard that looks nearly identical, that has the same component. This appears to be marked as "AC Short Protection" with a value of 13.7KOhms.
            02-21-2025, 01:51 PM
          • CapLeaker
            Happened again. Resistor go short!
            by CapLeaker
            That's now the second time in my repair career that a through hole resistor go short!
            it was a Vishay CPF124K900FHB14 1W resistor measuring new 24.9kohm. <- notice the KILO ohm. Well now it measures 28.1 Ohm! See picture and PDF attached. This is something very rare happening, but apparently it does happen!...
            07-07-2025, 03:20 PM
          • DynaxSC
            Extreme High Current & Low Voltage Short Killer ??
            by DynaxSC
            Hi Folks
            I'm looking for a extreme high current short killer solution for a reasonable cost.
            I have an LGA1700 motherboard (ASUS PRIME Z790-P WiFi) where I exchanged the LGA socket already 3 times, and every time after the socket exchange I get a short of power supply lines VCORE (V variable) and VCCIN_AUX (1.8V).
            After taking off the socket, the shorts dissappear again.
            The soldermask on the socket is already partially demaged from the heat, so I have reconstructed the soldermask by manually painting the missing soldermask parts with a very small top of a...
            10-15-2024, 10:13 AM
          • jinu_j
            by jinu_j
            Hi
            05-03-2025, 10:51 PM
          • mikey5791
            by mikey5791
            Hi to all forum members,
            12-26-2024, 04:55 AM
