Is KT808AM compatible to 2SD867 ?
  • caspian
    • Oct 2015
    • 1591
    • Laptop
    Dear members,
    I have a linear Desk variable power supply that has an old Russian Transistor with model KT808AM. It cannot be found any more.
    Is it right if I replace KT808AM by 2SD867 ?
    Are these two transistors fully compatible according to their specifications and properties?
    Regards
  • PeteS in CA
    • Aug 2005
    • 3581
    • USA, Unsure of Planet
    They look compatible, if the package is the same:
    https://alltransistors.com/transisto...ansistor=39155
    https://html.alldatasheet.com/html-p.../1/2SD867.html
    PeteS in CA
    • NotEnough
      Dell G15 5515 RGB Keyboard Not Detected (Compatible Keyboard, Possible BIOS/EC Issue?)
      by NotEnough
      I'm working on a Dell G15 5515 (Ryzen 7 5800H, RTX 3050 Ti) and recently installed a compatible 4-zone RGB keyboard and controller (for Dell G15 5510/5511/5515 models). While the keyboard functions for typing, the RGB lighting is not detected by Alienware Command Center (AWCC), which displays “No AlienFX devices found.”
      What I've Tried So Far:
      • Reseated the cables.
      • Reinstalled AWCC and AlienFX services.
      • Attempted BIOS downgrade but no improvement.
      • Inspected ribbon cables for damage.
      • Explored the possibility of BIOS or
      10-19-2024, 01:34 AM
    • davidebeatrici
      Asus X541UV Windows update KB5063060 deleting BootOrder EFI environment variable? bios fix
      by davidebeatrici
      I had 3 people contact me in a week because Windows suddenly didn't boot:
      As you can see, all 3 are ASUS computers, but I believe the common factor is the BIOS being American Megatrends (AMIBIOS/APTIO).
      The first two recovered just fine after a restart, but the third one didn't and was brought to me. The model is F541UV (X541UV).
      Setup allows to add a boot option manually and the operating system boots just fine from both bootx64.efi and bootmgr.efi. However, there is no way whatsoever to save the option(s): upon a reboot the machine goes straight...
      06-17-2025, 12:59 PM
    • Deby
      List of compatible laptop motherboards
      by Deby
      This is a list of compatible laptop motherboard information that I have been collecting for some time.
      And it's still ongoing.
      Every time I come across information that a board is compatible with another, I write it down.
      Anyone who wants to, can continue to expand the list.
      Packed in the rar, is an excel table that has additional information.
      Motherboards.rar...
      05-31-2024, 04:34 AM
    • zwect
      RTX 4060 Gigabyte Aero / FBVDDQ not switching on despite compatible IC swapping
      by zwect
      I got this Gigabyte Aero RTX 4060 where it initially wouldn't get detected, after disassembly i found that U504 (12v to 5v) was corroded at pin 1 together with it's ADJ resistors, i swapped them for close enough ones (it goes to a 1.02k resistor > 340ohm then 0hm > GND), i installed a 1k and 300ohm one and got 5v properly, fans would spin fine but card still wouldn't get detected, i've measured PEX present then found out that FBVDDQ was missing entirely, analyzing further, U15 was shorted at it's VCC pin (7), at the time i didn't have another exact model but got a TPS51211 instead, i checked...
      07-21-2025, 05:53 PM
    • Ady2017
      Any good references for variable capacitor design?
      by Ady2017
      I have recently decided to put together a 1930's style crystal radio as a father-son project to get him started in electronics. The lack of availability of now-obsolete variable capacitors is causing a big headache. From what I have seen on the internet, a number of people have resorted to making their own variable capacitors but have not given any details about how they designed them. Does anybody have any old references for the design of variable capacitors which includes details such as plate spacing, plate size, number of plates, best materials to use, etc.
      07-24-2022, 04:35 AM
