HEC-250LR-T ATX Computer psu
  • joshnz
    • Feb 2011
    • 969
    • New Zealand
    Hello my power supply for my old pc went pop during a power dip when ups kicked in.
    Found the 5vstb controller a TOP222Y has failed 42ohms drain to source,
    and a resistor that I can't identify it's color code is "yellow violet gold gold" that is what made the pop sound.
    My pc
    CPU : AMD PHENOM II x4 @ 3.5Ghz
    MB : ASUS M4A89TD PRO USB3
    RAM : Kingston ValueRAM 16gb DDR3
    PSU : Cooler Master 850W Silent Pro
    GPU : ATI Radeon HD 6850
  • Pentium4
    CapXon Be Gone
    • Sep 2011
    • 3741
    Re: HEC-250LR-T ATX Computer psu
    Guessing no MOV's in there? Pictures?
    • joshnz
      • Feb 2011
      • 969
      • New Zealand
      Not much too see does have mov's
      My pc
      • Escort Eagle
        • Jul 2012
        • 110
        I think the resistor value should be 47K, but I am not sure . Can you draw a schematic for 5VSB Primary Section only . And have you any datasheet of TOP222Y Mosfet ?
        • TELVM
          • Oct 2012
          • 547
          • Spain
          There are two MOVs between the primary caps:
          • joshnz
            • Feb 2011
            • 969
            • New Zealand
            Here is circuit same as in data sheet.
            My pc
            • joshnz
              • Feb 2011
              • 969
              • New Zealand
              All i need to know is resistor value to replace and replace TOP222Y.
              And hope no high voltage pulse went out the secondary.
              My pc
              • Escort Eagle
                • Jul 2012
                • 110
                Then It should be a fusing Resistor of 4.7Ω/1W . Use a 100W series bulb tester at test condition for avoiding damage .
                • joshnz
                  • Feb 2011
                  • 969
                  • New Zealand
                  It is a 1/4watt or less I know that much by its size.
                  It will be a over a month for replacement top222y to arrive.
                  My pc
                  • Pentium4
                    CapXon Be Gone
                    • Sep 2011
                    • 3741
                    Since this thing is pushing 14 years old and you've already got it torn apart, you should replace the lytics. Looks really well built for its age and wattage.
                    • joshnz
                      • Feb 2011
                      • 969
                      • New Zealand
                      Will do.
                      It's full of CapXon.
                      My pc
                      • Pentium4
                        CapXon Be Gone
                        • Sep 2011
                        • 3741
                        Wow those are all CapXon? They held up pretty well! I wonder if they're still in spec.
                        • joshnz
                          • Feb 2011
                          • 969
                          • New Zealand
                          I don't have a esr meter or a captance meter that goes over 200uf so won't know
                          My pc
                          • everell
                            • Jan 2009
                            • 1514
                            I would argue that the resistor value should be 0.47 ohm.
                            Old proverb say.........If you shoot at nothing, you will hit nothing (George Henry 10-14-11)
                            • joshnz
                              • Feb 2011
                              • 969
                              • New Zealand
                              That is what I was thinking due to it been smaller than a 1/4 resister.
                              My pc
                              • kc8adu
                                • Nov 2003
                                • 8832
                                • U.S.A!
                                that 3rd band could be silver...
                                it looks different than the 4th.
                                which is gold.
                                • Agent24
                                  I see dead caps
                                  • Oct 2007
                                  • 5016
                                  • New Zealand
                                  I have one of these HEC-250LR-T v1.1 sitting here, also dead. As long as the same resistor isn't blown I can tell you what yours is supposed to be, tomorrow.
                                  What's the refdes of your dead resistor?
                                  -David VanHorn
                                  • Agent24
                                    I see dead caps
                                    • Oct 2007
                                    • 5016
                                    • New Zealand
                                    Well, that's interesting. R011 is OC on mine too. But I can confirm it's Yellow-Violet-Gold-Gold, so assuming they used a normal code then it's 4.7 Ohms, 5%.
                                    My TOP222Y though measures 30 Megohm G-S (both directions)
                                    Also there is a missing component near the comparator, looks like R41. Is that same component missing on yours? (see approximate center of photo)
                                    A first I thought it might have vaporised since there are leads but no body, but there are no burn marks or carbon so maybe that's not the case. Very strange.
                                    -David VanHorn
                                    • joshnz
                                      • Feb 2011
                                      • 969
                                      • New Zealand
                                      Ok agent I seen your thread on this psu I'll have a look at mine when I get home.
                                      They top222y is not a mosfet it is a ic with a mosfet built in.
                                      It has pins
                                      Drain negative of transformer
                                      Source DC -
                                      Control VCC and Feedback
                                      What is the reading between Drain and Source.
                                      My pc
                                      • Agent24
                                        I see dead caps
                                        • Oct 2007
                                        • 5016
                                        • New Zealand
                                        Sorry, where I said "gate to source" should have been "drain to source"
                                        Or in other words, the two right-most legs on the package when viewed from the front.
                                        -David VanHorn
                                          Acer Swift SF114-34-P2H0 + Pack Gold Acer 14'' Notebook 1 Specification for Upgrade or Repair
                                          This specification for the Acer Swift SF114-34-P2H0 + Pack Gold Acer 14'' Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SF114-34-P2H0 + Pack Gold Acer 14'' boardview and SF114-34-P2H0 + Pack Gold Acer 14'' schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...
                                          09-07-2024, 03:10 AM
                                          Acer Swift SF114-34-P25P + Pack Gold Acer 14'' Notebook 1 Specification for Upgrade or Repair
                                          This specification for the Acer Swift SF114-34-P25P + Pack Gold Acer 14'' Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SF114-34-P25P + Pack Gold Acer 14'' boardview and SF114-34-P25P + Pack Gold Acer 14'' schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...
                                          Acer Swift SF114-34-P25P + Pack Gold Notebook 1 Specification for Upgrade or Repair
                                          This specification for the Acer Swift SF114-34-P25P + Pack Gold Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SF114-34-P25P + Pack Gold boardview and SF114-34-P25P + Pack Gold schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any...
                                          09-07-2024, 02:20 AM
                                          Acer Swift SF114-34-P2H0 + Pack Gold Notebook 1 Specification for Upgrade or Repair
                                          This specification for the Acer Swift SF114-34-P2H0 + Pack Gold Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SF114-34-P2H0 + Pack Gold boardview and SF114-34-P2H0 + Pack Gold schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any...
                                          ASUS 14.0 FHD 1920x1080 Pentium Gold 7505 4GB 128GB with M365 1 Year Notebook Specification for Upgrade or Repair
                                          This specification for the ASUS 14.0 FHD 1920x1080 Pentium Gold 7505 4GB 128GB with M365 1 Year Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 14.0 FHD 1920x1080 Pentium Gold 7505 4GB 128GB with M365 1 Year boardview and 14.0 FHD 1920x1080 Pentium Gold 7505 4GB 128GB with M365 1 Year schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional...
                                          09-07-2024, 01:30 AM
