Why does recapped PSU leak to ground?
  • ic32
    • Nov 2006
    I recapped the Antec TruePower from my Antec Sonata case not long ago, and I now get what seems to be leakage current of about .05V even when the PSU is turned off with the switch on the PSU case. I will double check all these facts when I get home, but I think that it also leaks the same amount for at least several minutes when unplugged from the wall. Since I never thought to check this before, I don't know whether this is normal. I can't remember whether this is from the 5V or 12V line to ground (either case or straight to wall ground, which I have personally newly wired and verified all the way into the ground beneath the house)
    A summary of my recap: I replaced all but three capacitors with Panasonic and Nichicon caps from Mouser. I also desoldered a number of wires from the harness so that I could remove unused Molex connectors and make the PC and PCU cases easier to cool/maintain. I did not replace the two large AC filter caps for lack of better replacements. I did not ultimately replace the single non-polarized capacitor—I didn't have one handy. My first power-up resulted in the blowout of one of the smaller capacitors (don't have the specs on hand). This prompted me to conduct another very careful reexamination of things, during which I found that I had replaced the non-polarized capacitor with something polarized, though this was not the cap which blew. I'm fairly sure that I didn't reverse the polarity of the blown capacitor, but I figure that could be the result of either the use of a polarized cap instead of non-polarized, or that the desoldering of a small capacitor with a RadioShack desoldering iron/pump combo and then reuse once I realized I had no comparable part.
    All voltages seem to be very stable at all Molex connectors, the machine has run for several weeks of 24x7 uptime and frequent recording of analog and over-the-air high definition TV. I haven't rushed to do some Prime95 burn-in testing, in part because I wondered whether this apparent leakage current was explainable.
  • Per Hansson
    • Jul 2005
    • 5895
    • Sweden
    Re: Why does recapped PSU leak to ground?
    The main caps discharges to ground for safety reasons
    That's the way I think it works anyway (so you can open up the PSU without being killed by those 400v caps...)
    • mkdj
      Acer TravelMate P214 - N19Q7 main power rail shorted to ground
      by mkdj
      Dear all,
      I have taken out the motherboard of a Acer TravelMate P214. There is a short to ground on the main power rail (19V). I don't have the schematics or boardview for this board (DAZ8IMB1AA0 REVA). But I have found 4 MOSFETS close to the main power rail : 2 N-Channel and 2 P-Channel.
      I have checked resistance across each of the 4 MOSFETS. I have the following readings:
      Both N-Channel Mosfets: nothing odd
      P-Channel MOSFET number 1:
      source - drain : 117 kOhm
      source - gate: 96 Ohm
      gate - drain: 117 kOhm
      P-Channel MOSFET...
      08-20-2025, 06:08 AM
    • barry101
      Apple 820-3662 VCore shorted to ground.
      by barry101
      Hi, Would appreciate some help.
      I have an Apple Late 2013 15" A1398 MacBook Pro with Logic Board 820-3662.
      Get charger light but no fan spin or chime. No liquid damage.
      Found PPBUS and VCORE both shorted to ground. Other rails were ok.
      Removed VCORE MOSFETS U7310, U7320 and U7330. Found U7330 was in fact shorted.
      With the 3 MOSFETS removed, get PPBUS and fan spin. VCORE is still hard shorted to ground (0 ohms).
      Attempted voltage insertion on VCORE to locate short using bench supply set at 1.0 VDC and 4.95 Amps (max current for my...
      06-24-2025, 07:34 AM
    • Chaks
      Ground Plane For 5dBi ISM Band 865-870Mhz Embedded Ceramic Antenna
      by Chaks
      TAOGLAS ANTENNA MODEL: ISPC.86A.09.0092E
      The specs says ...
      High antenna efficiency 868MHz ISM Band
      5dBi Peak (when placed on 30cm x30cm ground plane) - Broadside to Zenith Radiation Pattern
      The antenna is 50x50 mm square and How do I fix it on the Ground Plane of 300 x 300 mm (aluminium sheet 3mm thick).
      1. Should I Fix it with a glue.
      2. Should I fix it with a double side adhesive tape
      3. Should I fix it with Screws (the screw head may just clamp the antenna to the aluminium...
      12-09-2024, 11:06 AM
    • Rolin
      Dell Laptop - over 14V between Chassis Ground and Circuit Ground?
      by Rolin
      Someone brought me a Dell laptop that had a loose power jack inside (power jack on a cable, not soldered to motherboard). Once disassembled found one of the wires was broken off the power jack. I replaced the jack and it won't turn on, but the metal shell of the jack inadvertently touched the metal hinge and suddenly it got power. I checked voltage from the metal chassis ground and the circuit ground and I get over 14V ? Has anyone seen this before? Typically is it some kind of filter cap that shorted? Very strange...
      10-30-2022, 10:18 PM
    • Leefreeman97
      Diagnosing short to ground issue. pcb from an e scooter
      by Leefreeman97
      Hello, I have a pcb from an e scooter which had a faulty diode but even after removing it from circuit, it still has a short to ground on the three components circled. I have removed every cap on the board and tested one by one and the short is still there and all the caps test ok. Could this be because I haven’t put a diode back on it yet or where do I go next please?
      09-19-2025, 03:33 PM
