Schottky Diode IDT08S60C
  • Sevenqi
    • Jul 2011
    • 292
    Schottky Diode IDT08S60C open when I repaired the Samsung plasma HP-S5053 power supply board PSPF501A01A, this is a 600V 8A diode, hard to find the same part number. Any idea to replace with other diode ?
  • philliesfan30m
    • Aug 2013
    • 542
    Re: Schottky Diode IDT08S60C
    IDH08S60C they have them at newark here is the url
    http://www.newark.com/infineon/idh08...-to/dp/22T5136
    i checked mouser and they are out of stock and digikey wants you to order atleast 500! newark is the only 1 that i saw allows you to order just 1 but those are the only places i checked! here is the page for infineon of some of their discontinued products yours is in there you can check it out if you want here it is.
    https://cdn.badcaps-static.com/pdfs/...247b3ac15e.pdf
    discontinued
    IDT08S60C
    SP000080226
    PG-TO220-2-2
    600V
    new replacement
    IDH08S60C
    SP000657994
    PG-TO220-2-1
    600V
    • philliesfan30m
      • Aug 2013
      • 542
      datasheet is here
      http://www.alldatasheet.com/datashee...IDH08S60C.html
      • Baste
        MBR3045CT and SR3045LCT Schottky diode testing help.
        by Baste
        Hello experts,
        Can anyone educate me on how to test MBR3045CT and SR3045LCT Schottky diodes? I'm totally a newbie in electronics, so forgive me if I have cheap tools. In my effort to repair a Gigabyte PSU, I stumbled upon the two diodes, which I suspect are leaky. I tested this with my two cheap multimeters and the newly bought LCR-T4 MC328, and I got confusing results. Below are my test results.
        Aneng ST182 Meter.
        Diode mode.
        MBR3045CT:
        Diode mode
        Pin 2-1 - 0.150v
        Pin 2-3 - 0.150v ...
        10-21-2025, 06:14 AM
      • iyas132
        Corsair RM 750 blown schottky diode near ES1DF
        by iyas132
        Hi there, i am currently diagnosing my corsair rm750 that wont turn on, after a power trip.
        Before the power trip, previously i need to push power button on my pc case quite a bit in order to turn the pc (and power supply on), however after the power trip now i cannot turn the pc on at all and i opened the power supply, and found out some of the component(s) are blown. (picture attached)
        My current diagnostic is that the (schottky) diode marked "SF" in the 5Vsb circuit are blown and possibly the ES1DF diode too.
        Can anyone help me identify the component...
        12-30-2024, 01:34 AM
      • asr
        Finding replacement diode iPad Pro 3rd gen A1701
        by asr
        Hello, I am looking for help to replace a damaged diode. The tristar was replaced and a diode was damaged in the process. I have a picture of the diode but dont have an exact donor. I mostly have macbooks for donors and only a few ipad and iphone boards. Diode part number: DSF01S30SCAP
        Im not sure where to find the ipad board number. Anybody have an idea where else this diode is used on other boards? Thanks....
        07-09-2024, 06:24 PM
      • unimatrix93
        TV backlight zener diode
        by unimatrix93
        Hello everyone, I'm repairing an LG TV backlight and I noticed some strange behavior when I touching the backlight strip with a missing Zener diode.
        So I replaced the leds on the strips and they seemingly working fine, but soon as I touch the strip which has a missing Zener diode the whole backlight turns off for a few seconds and then turns back on.
        Is this caused by the missing diode? If so what kind of zener diode should I use to replace it?.
        The led strips has 9 6V leds.
        02-10-2025, 12:13 PM
      • NicRac
        monowheel repair,Is the diode the problem?
        by NicRac
        Hello everybody☺️ I am glad to be here and looking forward to a good discussion.
        First of all, I am new here. Therefore I will shortly introduce myself.
        I am Nico and currently I study Physics.
        In my freetime I like to build and repair stuff. Especially big battery's.
        A few years ago I got myself an electric unicycle, monowheel or however you call that.
        The battery bms was broken so I replaced and resolder that. Nothing big.
        I used this thing for some years and had a lot of fun. Unfortunately I used it last time in heavy rain. Usually everything...
        07-26-2024, 06:13 AM
