New ATX for old computer: 20 pin, no SATA
  • mathog
    • Mar 2010
    • 2655
    The PC Power & Cooling 300 ATX PS on a computer at work died. I had an equally ancient spare laying around, and that is what it is using for now, but I want to buy a new one so that I can get my spare back.
    Problem is, I'm having a really hard time finding a similar power supply that isn't no name junk. The dead one has a pretty standard configuration for an 8 year old PS, but the better manufacturers just don't seem to make them like that any more.
    The current one has these specs:
    300W (nominal), single 80mm fan next to power cord plug, +5V@30A, +12V@12A, -5V@0.3A, -12V@0.8A, +3.3V@14A, +5VSB@2.0A
    1 20 pin mobo connecter
    1 4 pin mobo connector
    6 4 pin Molex connectors
    2 Floppy connectors
    (and that's it - no SATA or anything else. If I remember correctly it uses both mobo connectors, 3 of the molex, and one of the floppy connectors.)
    Suggestions?
    Thanks.
  • shovenose
    Send Doge Memes
    • Aug 2010
    • 6575
    Re: New ATX for old computer: 20 pin, no SATA
    How about an Antec 380W? price of shipping!
    • mathog
      • Mar 2010
      • 2655
      The Antec Basiq 350 might work. It has the needed 4 pin ATX12V connector:
      http://www.antec.com/connectors.php?ProdID=23350
      The EA380D, does not have that 4 pin connector. Instead it has some odd 4+4 connector I have never seen before. Even if it has the right voltages it might not fit:
      http://www.antec.com/connectors.php?ProdID=27384
      • shovenose
        Send Doge Memes
        • Aug 2010
        • 6575
        Look at the one on my ebay store just google shovenose555 I was thinking of that one.
        • c_hegge
          • Sep 2009
          • 5219
          Just split the 4+4 pin and it will fit. The 8 pin is basically just two 4 pin connectors side by side and is used on lots of modern boards. The 380D is a MUCH better PSU than the Basiq, so if you can get one for the price of shipping, I wouldn't even consider the basiq.
          • mathog
            • Mar 2010
            • 2655
            That's a winning argument. It doesn't look like there is room to leave half the EPS12V hanging off the side of the ATX12V socket, and I don't want to modify this PS in any way, so splitting the EPS12V is out. We will use an adapter cable to plug that part in.
            Thanks.
            • dmill89
              • Dec 2011
              • 2531
              Thanks.
              It is designed to be split that's why it is labeled as a 4 + 4 pin. The connector is just held together by plastic tabs (same as a 6/8 pin PCI-Express connector).
              • Behemot
                • 4845
                • CZ
                Just don't plug PCIe in there…
                • mathog
                  • Mar 2010
                  • 2655
                  When we opened the box it was already split. There was no flashing or other signs that the two pieces were ever attached.
                  • ben7
                    Capaholic
                    • Jan 2011
                    • 4059
                    Why don't you try to fix the PCP&C PSU?
                    Muh-soggy-knee
                    • DynaxSC
                      GIGABYTE X299 AORUS ULTRA GAMING - SATA PORTS 4-7 NOT WORKING ???
                      by DynaxSC
                      I have the above mentioned bord after repair, which was related to a lot of missing smd devices on the back of the board.
                      There were almost 20 devices missing, caps, resistors and some diodes/mosfets.
                      The board is generally working now, all PCIe ports are working, Windows installs normally.
                      However I have a problem with SATA ports 4-7 (the board has 8 SATA ports) - disks are not beeing recognized by the BIOS neither by Windows (which is usually normal in case BIOS does not recognize them).
                      The SATA 4-7 driver network is quite simple chipset<->buffers/drivers<->SATA...
                      03-10-2025, 12:27 PM
                      HP Z2 G4 + 3TB SATA 6Gb/s 7200 HDD i7-8700K Specification for Upgrade or Repair
                      This specification for the HP Z2 G4 + 3TB SATA 6Gb/s 7200 HDD can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Z2 G4 + 3TB SATA 6Gb/s 7200 HDD boardview and Z2 G4 + 3TB SATA 6Gb/s 7200 HDD schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                      09-12-2024, 03:28 PM
                      KDMPower MIPC MI-X8775CD [PCB WF-C rev:E]
                      by momaka
                      Remember that cheap $15 PSU that dmill89 posted a while back here?
                      https://www.badcaps.net/forum/showthread.php?t=72229
                      So I was randomly browsing on eBay (as always) and saw a listing for supposedly the same “775 Watt” PSU with starting bid at $1. Description stated “for part or repair”, with the owner/seller mentioning the PSU had blown/shorted. Surely I could spend a few $$ more and get the same PSU as dmill89 right from Amazon brand new and (probably) working… but where is the fun in that?!
                      So I got this one instead...
                      11-17-2020, 12:03 AM
                    • clabr
                      Lenovo 11e problems (any sata hdds are not recognized, sleep battery drain)
                      by clabr
                      Need help to solve some problems with this laptop.
                      After working in bed with it one night and heating up too much (probably the cause of this problems) the sata HDD OS windows froze
                      After restart the original Sata HDD was not recognized anymore (but works fine in other laptops or PCs)
                      Tried connecting other good Sata 2.5 HDDs but not one is working in this laptop anymore (not the original nor others)
                      Before this had happened I observed some other problems:
                      When I tried replacing original mecanical HDD with a SSD HDD could not get them...
                      12-02-2021, 08:09 AM
                    • CapLeaker
                      Crimping CAT7 connectors high failure rates
                      by CapLeaker
                      I’ve had and got a few projects using quality CAT6 and CAT7 23awg solid copper, shielded, direct burial cable. Each time I use CAT7 connectors, most of them fail making good connections to the 4 wire pairs after crimping. I tied a couple of crimping tools, thinking my crimper is bad. Also used different CAT7 RJ45 connector manufacturers. Same thing. I kinda calculate 6 connectors to make one cable!
                      Get this: I use CAT5 or CAT6 connectors, no problem. Very rare I have a miss crimp with those. So what gives?! ...
                      11-09-2024, 04:11 PM
