Philips HTS3020 5.1 DVD Player No Power Power Supply Damage?
  • Gilera001
    • Jul 2013
    • 75
    • Deutschland
    I have a Philips HTS3020 5.1 system when I connect it to the power nothing happens, no LED or buzzing or other. The fuse is ok I measured when I am directly measure current Connector I have there 0.4 V or 0V complete I then changed the cable but still no bessrerung
    Does anyone have an idea? where I should start looking? or what it could be?
    Thank you in advance in advance and hope to help!
  • Khron
    • Sep 2006
    • 1350
    • Finland
    Re: Philips HTS3020 5.1 DVD Player No Power Power Supply Damage?
    I see some darkening of the board in the area of that 8-pin chip, next to the smaller transformer. What does it say on that chip?
    Also, what brand / series are the two electrolytic capacitors below ("south" of) the chip?
    Khron's Cave - Electronics - Audio - Teardowns - Mods - Repairs - Projects - Music - Rants - Shenanigans
    • Gilera001
      • Jul 2013
      • 75
      • Deutschland
      Hello, I have a photo taken by chip I get no power, even at the beginning of the ac input 0V I've already changed the cable and the fuse is ok
      • Khron
        • Sep 2006
        • 1350
        • Finland
        So, you have 0V DC at the terminals of the big black capacitor?
        • Gilera001
          • Jul 2013
          • 75
          • Deutschland
          I took a picture, I have here 0.05 V I do not understand it, but there must be something broken before the fuse or?
          • lti
            • May 2011
            • 2550
            Where is the black lead from your multimeter connected? It looks like it is just hanging off the edge of the table and not connected to anything.
            • Gilera001
              • Jul 2013
              • 75
              • Deutschland
              Yes it was my Mistake, i have 225V at The Power Connector but Nothing happens
              • Khron
                • Sep 2006
                • 1350
                • Finland
                Ok, so the AC is indeed getting in.
                What DC voltage do you have at the terminals of the big black primary capacitor?
                  by sam_sam_sam
                  03-31-2024, 02:12 PM
                  by sam_sam_sam
                  07-01-2024, 06:34 AM
                • JimBanville
                  Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
                  by JimBanville
                  The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
                  Opened it up and discovered the power supply is making a faint clicking or ticking sound.
                  I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
                  I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
                  09-13-2023, 07:21 AM
                • caspian
                  Can Ammeter damage Power Supply?
                  by caspian
                  Dear Members,
                  My DC linear Lab Power Supply does not display the current and voltage correctly. Thus, I am going to connect an Ammeter/Voltmeter Module to the DC output of the power supply. Then, a load will be connected the takes about 1-5volts with 0.1-1.5Amps.
                  But I heard If I connect an Ammeter to the output of the power supply, then the Ammeter module is not isolated from the power supply so that the Ammeter can damage the power supply.
                  Is this true?
                  I have attached the photo of a sample Ammeter module that I am going to buy....
                  06-05-2022, 01:42 AM
