Re: Found a brand new Comp USA PSU
I had an ATX that may have originally been an AT design because its 5Vsb was on a separate circuit board. PC Power & Cooling featured it in a magazine ad to show how bad a PSU could be.
Here's a Leadman identical to Pentium4's CompUSA unit, right down to the April 13, 2001 production date, only the +3.3V has a choke in its output, and the heatsinks are different.
Not yet! I just got it that dayLeave a comment:
Absolutely it isIt needs your 5VSB mod!!!
If they are present… It clearly has *some* impact if the THD is such problem, right?Leave a comment:
There is basically zero energy beyond a few kilohertz. It's all shunted to ground by the Y- and X-caps anyway.Leave a comment:
Masuring the current may not be that easy if the drain is realized by harmonics spikes with base at say several tens of kHz and than many more ending somewhere in MHz range.Leave a comment:
I'm not sure what you mean. Measuring power factor is easy. Simply measure current using a high speed ADC, use a DSP to compute RMS current and multiply by RMS voltage (in the same way) which gives you reactive power in VA. Then measure power by integrating voltage and current, and divide the two to get PF.
If you use a cheap meter you're going to get poor results but that's how some of the equipment that the company I work at makes, does it.Last edited by tom66; 07-11-2013, 04:19 PM.Leave a comment:
My meter shows that but I won't put my hand into fire for the accuracy. Especially when we are talking about harmonic distortion, not phase shifting.Leave a comment:
A good power meter can measure down to 0.01 PF. Actual power factor of a standby circuit is typically 0.3 to 0.5PF.Leave a comment:
Sure but still there are loses.
There is also possibility of very inaccurate measurement of drawed power because of low power factor (usually <0,1), but much more ppl than me have the same results so statistically…Leave a comment:
Rectifier draws only power as required by standby circuit and losses are very low at the 10's of mA drawn by the standby circuit. The X capacitor draws reactive power, which is not included in real power calculations. The bulk capacitor has negligible leakage current. 99% goes to standby power circuit.Leave a comment:
Input filtering is not active? Rectifier, PFC and capacitor is not active? Only inactive thing in there are switching transistors, everything else works. These days almost only Champion Micro's PFC+PWM combo chips are used and PFC part of them is active, just the PWM not.Leave a comment:
What do you mean whole primary side? The only thing active would be bleed resistors and small leakage currents.Leave a comment:
I am talking about +5 V SB, my own load tests. I have never seen 80 % efficiency on that. Remember that you have the whole primary side to feed even if just the +5 V SB rail is operating.
Will have another 80 PLUS Platinum PSU in next days reviewed and later some 80 PLUS Gold ones in next weeks (Fortron Aurum should arrive). Anyone wanna bet on crossing the 80% barrier?Leave a comment:
Do you have any real numbers or you are just making it out? I have never achieved even 80 % with 80+ Platinum Power Supplies with the best PWM combo chips, best result with Fractal Design Newton R3 600 W was 73,9 % on overload.
Two transistor usualy barely achieves 65 %. It burns insane power, mostly on the rectifying diode which, if not enough sized and/or superfast used, is sometimes capable of baking itself and everything around. They don't usually even count with 60+ % long-term output on these things so if that happenes, it won't survive that for long.
You have to remember with those tests involving the 5VSB in an integrated design is the 5VSB transformer often powers the TL494 or similar chip on a separate rail plus other control logic. As I said it's possible to make them efficient, but more costly than a good TNY- single chip design.Last edited by tom66; 07-11-2013, 10:25 AM.Leave a comment:
I believe on one of JG's reviews, an el cheapo he reviewed was something crazy like 59% efficiency in stand by with a 2 transistor design, maybe even lower
Edit: Found it, look at that, it was 41% at some point! http://www.jonnyguru.com/modules.php...tory3&reid=324Last edited by Pentium4; 07-11-2013, 10:08 AM.Leave a comment:
5VSB transistor usually dissipates no more than 1W with 5V, 3A load. Two-transistor 5VSB is actually pretty efficient, around 75% to 80% (which is good for a small, low cost flyback.) And it's possible to make it without the killer cap, but you may as well use a controller IC because all of the tweaks will likely cost more than a cheap TNY-type switcher.
Two transistor usualy barely achieves 65 %. It burns insane power, mostly on the rectifying diode which, if not enough sized and/or superfast used, is sometimes capable of baking itself and everything around. They don't usually even count with 60+ % long-term output on these things so if that happenes, it won't survive that for long.Last edited by Behemot; 07-11-2013, 06:27 AM.Leave a comment:
by прямоSo I have a cheap non working ATX PSU that I was learning to repair a decade ago. At the time, it blew the main fuse, bridger rectifier, NTC, and primary 9A 900V MOSFET. Replaced all except the MOSFET. 5VSB came back online. Then I poked around in it so much, measuring components one by one to a point I accidentally made the 5VSB circuit primary side went bang. Blown the AP8022 (Viper22A) PWM chip, along with a low resistance resistor and the PC817 opto isolator. I replaced them all.
In the process of poking around, I also lost a zener diode that stabilize the voltage coming from...3 Photos -
Finally replaced all of the shorted 4148's and resistors and an blown tl431 on my FSP300-60GTF after 5VSB going crazy and destroying it self. Those components also made the secondary transistors appear shorted (while in reality they weren't).
Powered it on through my dim bulb tester and they (bulbs) only flash once meaning primary caps are getting charged, but that's it. No 5VSB, PS_ON voltages.
I am sure I have replaced the components correctly and that there weren't any shorted/blown traces left.
Any ideas where to go next? -
by mrcliemHello...
I got my self a dead CM V700 PSU, with nothing on +5vsb
I have tried to fix it for the past 2 week, and I'm stuck... so i guess i post it here to get some pointer before i scrap it..
As you can see in photo, the psu still pretty clean, no visible damage or bulging cap.. when i got it, it still has CM seal on it
The +5vsb system use ICE2QR4765, I have trace and measure the voltage on ICE2QR4765 and the only voltage reading i got is in VCC 4.8v, Drain 310v and FB 3v.
I have read the datasheet and and still can not... -
by socketaRescued this one
Started it up in the computer case, and noticed that it would shut down after about 10s in the BIOS
Took it out, connected to hard drive and it loses all power on all rails (except for 5VSB) after about 40s or so. (the same result happens without a hard drive connected)
The 5VSB drops to 2.5V when it 'shuts down'
And the voltage across the primary cap falls from 335V to 330V at the same moment
I think that the 5VSB is regulated by an A6069H PWM chip (which was initially dropping to 2.5V even before the the PS-ON was grounded - but it now stays at... -
by hobostoveHey there guys. I've got a Corsair power supply that's come across my bench dead. I usually don't mess with power supplies, but it's a slow week so I'm giving it a whirl.
Taking it apart I heard a screw rattling around inside, and when I got it apart I found a couple blown components near what I think is the 5VSB area.
There's a 22ohm resistor that's melted and open, but it still has the bands.
The other part is a zener diode and it's top went to jesus, so I can't read the marking.
It looks like the diode connects the source and drain of a TNY284... - Loading...
