HP Pavilion 6305 PSU
  • stevo1210
    • Oct 2006
    • 4156
    Hello All,
    I have a "retired" HP Pavilion 6305 Desktop PC with a wierd shaped PSU. It uses the 20PIN ATX connector, but it just doesnt boot!.
    I tested the fuse and it is fine. When i plug it into the wall, nothing happens, no boot, nothing. It just died one day when it was left on for a while.
    Anyone got any ideas? It still works with a standard PSU though.
    Don't find love, let love find you. That's why its called falling in love, because you don't force yourself to fall, you just fall. - Anonymous
  • linuxguru
    • Apr 2005
    • 1564
    Re: HP Pavilion 6305 PSU
    If it's a Bestec ATX-100 or similar, it can probably be revived by recapping all secondary caps. The key caps are 12.5 mm, which makes it easier. These PSUs were often found in the HP "Piglet" (small, fat, grey mini-tower with rounded edges) Pavillions and Brios.
    • stevo1210
      • Oct 2006
      • 4156
      Thanks Linuxguru for the advice, but it's not a Bestec power supply.
      It is a Delta electronics DPS-110MB A REV:00, HP P/N 0950-2800.
      I inspected inside it and it appears to have KZG chemicon caps, and none are bulging at all. The fuse is still intact actually. And yes, it's one of those small grey piglet tower ones.
      There seems to be a lot of dust in it though. Most likely because it's been in a mechanic workshop and left on 24hours a day. It even smells like car oil !!!! everytime i touch around in there, my fingers even go black because of the oil dust in the air!!.
      Could the dirty nonsense be the cause?
      Thanks.
      • Tom41
        • Oct 2005
        • 336
        • England
        Are you using the PSU in the same PC it came with? Sometimes you get PSUs that use the ATX-style connector, but the pinout is completely different. Plug it into a board with a standard ATX connector, or plug a 'normal' PSU into that board, and it won't work - or may even cause smoke!
        Also check that the fuse in your mains plug hasn't blown; check that you are getting a proper 120v/240v AC supply through to the PSU. It may also be that the power button has become disconnected from the motherboard (or is faulty), so you can't turn it on. Try shorting the relevant pins on the ATX connector and see if it turns on.
        You know there's something wrong when you open your PC and it has vented Rubycons...
        • stevo1210
          • Oct 2006
          • 4156
          Thanks Tom41, yes im trying to use the original "thinner" PSU with this HP computer, but unfortunately it is dead.
          So for now im temporarily using a standard ATX PSU outside the case, and the HP seems to fire up well. I also tried this PSU in another PC, but it wouldnt budge.
          The previous owner had left the computer on 24x7 and one day came to work to see it had "Died".
          • kc8adu
            • Nov 2003
            • 8832
            • U.S.A!
            there are 2 470k resistors in it that go open.
            one on the edge of the stand up board and the other nearby on main board.
            this is the startup source for the pwm chip.
            very common.
            i use 1/2w in place of stock 1/4w
            • PeteS in CA
              • Aug 2005
              • 3581
              • USA, Unsure of Planet
              very common.
              That's an understatement, . I'll bet a start-up scheme like that is in the TI-Unitrode datasheet and app notes for the UC384X family PWMs. Also check the (typically) 47uF-100uF cap in series with those resistors, and possibly, a zener may be across that cap.
              Beyond that, do you have +5V Stby? If not, that's where the problem is.
              PeteS in CA
              • stevo1210
                • Oct 2006
                • 4156
                Ok, i got some images, i hope this helps....
                Thanks.
                • bobcaygeon
                  • Feb 2005
                  • 18
                  If you opt to not repair it yourself, you can try buying this P/S: http://www.newegg.com/Product/Produc...82E16817104112. I've bought two of these for two different HP Pavillions over the course of a year and they're still running fine. I do recall though, when I took a peek inside the ventholes before installing them, they did not have the best choice of caps.
                  • PeteS in CA
                    • Aug 2005
                    • 3581
                    Wow, that was made in May of 1998.
                    PeteS in CA
                      HP Pavilion Pavilion Desktop - 570-p056 Pavilion 570 i7-7700 Specification for Upgrade or Repair
                      This specification for the HP Pavilion Pavilion Desktop - 570-p056 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Pavilion Desktop - 570-p056 boardview and Pavilion Pavilion Desktop - 570-p056 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
                      09-12-2024, 03:44 PM
                      HP Pavilion Pavilion Desktop - 570-a079w Pavilion 570 J4205 Specification for Upgrade or Repair
                      This specification for the HP Pavilion Pavilion Desktop - 570-a079w can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Pavilion Desktop - 570-a079w boardview and Pavilion Pavilion Desktop - 570-a079w schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
                      HP Pavilion Pavilion Wave Desktop - 600-a059na Pavilion i5-6400T Specification for Upgrade or Repair
                      This specification for the HP Pavilion Pavilion Wave Desktop - 600-a059na can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Pavilion Wave Desktop - 600-a059na boardview and Pavilion Pavilion Wave Desktop - 600-a059na schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                      HP Pavilion Pavilion Desktop - 570-p030na Pavilion 570 i3-7100 Specification for Upgrade or Repair
                      This specification for the HP Pavilion Pavilion Desktop - 570-p030na can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Pavilion Desktop - 570-p030na boardview and Pavilion Pavilion Desktop - 570-p030na schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
                      HP Pavilion Pavilion Desktop - 550-257na (ENERGY STAR) Pavilion 550 i5-6400 Specification for Upgrade or Repair
                      This specification for the HP Pavilion Pavilion Desktop - 550-257na (ENERGY STAR) can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Pavilion Desktop - 550-257na (ENERGY STAR) boardview and Pavilion Pavilion Desktop - 550-257na (ENERGY STAR) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...
