Power supply voltages go down after shorting.
  • DJduck
    • Dec 2012
    • 229
    • Estonia
    Hi, i have an old power supply that i think is from an old Olivetti machine. I want to use it for burning some stuff, but whenever the output is shorted, the 12v goes down to 4v and 5v goes down to 2v. I looked inside, and there is no PWM or protection chips. If i turn it off for 5-7 seconds and turn it back on, then the voltages are right again. Is there a way to short that thing without voltage dropping? I can provide pictures of it if needed It is built like a tank, huge caps, all nichicon and panny. I think that the voltage drop is a protection?
    I can put text here?!
    Re: Power supply voltages go down after shorting.
    No, it's probably just unable to supply that.
    Let's work out the current at 4V:
    Zero ohm short, current = infinity. And the power required = 4V * infinity = infinity. (You have successfully incinerated us all as infinite power = infinite heat.)
    OK, realistically, the wire will have some resistance, maybe 0.1 ohms. Current will be limited, to around 30~40A, simply by the design and topology. So the supply is probably hitting an internal limit (transformer saturation, coupling capacitor, primary drop-out, etc.)
    If you want a supply you can short, I have used two 12V 98A power supplies in parallel and managed to drive that into a piece of AWG26. It did not last long at all. The power supplies did not break a sweat.
    • DJduck
      • Dec 2012
      • 229
      • Estonia
      Thanks for the info dude! Is there a way to remove SCP from a pc psu? I have an old Dell psu that i use for burning crap, but it shuts down after aout 2 seconds of short circuit. Or is it the same tihing?
      • PeteS in CA
        • Aug 2005
        • 3586
        • USA, Unsure of Planet
        Wow! Some folks are well in touch with their Inner Pyro! (Hope that joke works for our Esteemed Estonian Friend)
        It sounds like DJd is using a multi-O/P P/S, using one O/P for his pyro purposes and measuring the voltage on another O/P. If shorting the high current O/P trips the current limit protection and the supply either folds back or is of the shutdown-and-retry type, some voltage will appear on the unloaded O/P. If you know what the current limit circuit is you may be able to defeat it, BUT you will probably hear a loud noise, see a bright flash and smell a bad smell the next time you short an O/P.
        AWG #26 is good for an amp or two. Even one 98A supply would have sufficed to melt the wire, though the burnt PVC smell and glow might have lasted a little longer. An engineer I worked with liked to connect AWG #18 magnet wire across the O/P of a 300A switcher he was developing. Burnt magnet wire varnish doesn't smell too good.
        PeteS in CA
