Delta/HP PSU 3.3v short
  • pentium
    • Mar 2006
    • 2778
    I'm literally about to run out of the shop for th night but I have an HP system with problems. You plug it in and the front panel controller for the system comes up and behaves normally but both pressing the power button or telling the controller to power up does nothing.
    Pulled out the PSU (HP part 0950-3418) and shorting ON/OFF to ground doesn't seem to bring up the PSU like a normal ATX supply would but I noticed that while the 5 and 12v rails are good the 3.3v rail seems to have a 18 ohm short to ground which I suspect might be crowbarring the PSU. visually I saw nothing wrong and all caps appeared good but does anyone here have a clue what might be suspect? I'll start poking around tomorrow.
    Find Nedry!
    Check the Vending machines!!
    <----Computer says I need more beer.
  • PeteS in CA
    • Aug 2005
    • 3586
    • USA, Unsure of Planet
    Re: Delta/HP PSU 3.3v short
    Are you sure that 18 ohms isn't a pre-load resistor? It would not be enough to trip current or power limit, as the current would be a little over 1/10A, and the power about 3.5W.
    PeteS in CA
    • pentium
      • Mar 2006
      • 2778
      Ah, yes, there appears to be a 18 ohm resistor hidden away under a coil.
      Okay, well then that rules a short there out. :/
      Well after blowing the PSU out I find no blown caps (it's all Rubycon and Nichicon), no burned components, no damaged components and nothing improperly attached. It looks really good. The ON/OFF line by the way has 4.1v on it as well when plugged in and under all conditions.
      Find Nedry!
      • pentium
        • Mar 2006
        • 2778
        Anyone? I cannot source a repalcement PSU.
        Find Nedry!
        • LDSisHere
          • May 2012
          • 727
          • U.S.A.
          Can you post some good pictures of the supply? Also what are the exact voltages it is putting out on 5vsb, 12V, 5V and 3.3V lines?
          • pentium
            • Mar 2006
            • 2778
            Here's your pics.
            As said, the PSU is doing something. The system controller comes up however the instant the system is expected to turn on it dies and resets as if it switches over to another voltage rail which has not come up.
            +5sb is 5.11v
            +12, +5 and +3.3v are dead, which make sense because the PSU isn't on.
            Find Nedry!
            • LDSisHere
              • May 2012
              • 727
              • U.S.A.
              I noticed in your first post that grounding PS_ON would not start the supply. Would it twitch the fans at all?
              If yes, then I would check the voltage on each rail while grounding the PS_ON wire. If you have a Fluke meter with a Min/Max function this would be a good time to use Max.
              The next step would be to identify the supervisor IC. This should be the chip that is giving you the PS_ON voltage, this chip should also be connected to the Power Good wire which is normally grey.
              The idea is to see if the supervisor chip is sending a signal to the primary side to start up. Determining this should allow you to tell if you problem lies on the primary side or secondary side and where you should focus your attention.
              Out of curiosity how old is this computer? The date code on the supply reads 9851. Could that possibly be the 51st week of 1998?
              • pentium
                • Mar 2006
                • 2778
                It's a dual PIII Xeon system so it is in that timeframe.
                To make the fans twitch, first you must short ON/OFF to ground, then you have to short the FANS lead. It has to be done in that order or else nothing happens.
                Find Nedry!
                • playit
                  450watt power supply 5v, 3.3v short to ground wire,in output rail ,connectors
                  by playit
                  hello everyone , working zebronics power suply 450 watts , 5v ,3.3v givin short to ground black wire, also in circuit at output, resistor was charred but shows right values , after removing resistors 39ohms, 51 ohms, there was no short , no continuity beeps with ground , but after replacing new resistors (now i am not switching it on) ,again short still exists . when i put bigger ohm resistor like 100k ohm , no short beeping sound comes , lower ohm resistor gives continuity beeps ,other big ones donest , as its a working psu , i am confused what to remove now or how to go further now .
                  09-02-2023, 02:43 AM
                  MSI Delta DELTA 15 A5EFK-008 Notebook 15 Specification for Upgrade or Repair
                  This specification for the MSI Delta DELTA 15 A5EFK-008 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the DELTA 15 A5EFK-008 boardview and DELTA 15 A5EFK-008 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                  09-07-2024, 03:40 AM
                • Leefreeman97
                  Diagnosing short to ground issue. pcb from an e scooter
                  by Leefreeman97
                  Hello, I have a pcb from an e scooter which had a faulty diode but even after removing it from circuit, it still has a short to ground on the three components circled. I have removed every cap on the board and tested one by one and the short is still there and all the caps test ok. Could this be because I haven’t put a diode back on it yet or where do I go next please?
                  09-19-2025, 03:33 PM
                • MisterAIL
                  820-00840 / No boot / PP3V3_G3H Short to ground
                  by MisterAIL
                  Firstly sorry for my english, french guy inside.
                  I brought a macbook pro A1708 - 820-00840 logic board, wasn't powering on.
                  History is a day, nothing happened when opening the laptop.
                  Nothing special inside, no corrosion, no liquid damage, never opened.
                  First, with the logicboard alone on the desk, mesures are :
                  5v017 and 0.000 amp. nothing else.
                  Finding a short on the PP3V3_G3H_VR, but not on the PP3V3_G3H (0.540 on diode mode), PPDCIN_G3H_CHGR_R present (5,1 volts) PPVIN_G3H_P3V3G3H around 4.1 volts. PM_EN_P3V3_G3H...
                  10-13-2021, 11:42 AM
                • kjchatman
                  820-02020 a2338 motherboard has a ppbus short to ground
                  by kjchatman
                  this machine came to me as DOA and immediately found the issue as a 12v short to ground. Is it okay to inject voltage into that rail or does it have a potential path to the cpu or something?
                  08-21-2025, 12:13 PM
