Watts vs. heat
  • CAD4466HK
    • Sep 2006
    • 43
    Watts vs. heat
    Am I worried about nothing?Or do I have reasons to fear? Lets star by saying that in 2003, I purchased Antec Truepower 430 v2.0 12+@26. The reason that I bought it was my AG-520 refused to boot my rig at the time after adding a fan controler with LCD,and another hard drive.The Antec worked without a hitch.The load it was running was massive at the time.Colorful 600 series case,5 led 80mm fans and 1 80mm that wasent,1 120mm I took out of a Dell Poweredge 600,MSI 875P-Neo, P4 3.2E Pressy oc 3.4,Tt Volcano 7+,2gb KVR,Leadtec A400GT(6800GT)oc 420/1115 v mod 1.45 bios mod,2x80gb WD RAID 0,3x300gb Maxtor Diamond Max 16,one of them being sata,1x 200gb Maxtor Diamond Max Ultra 8 sata,1x Hitachi Deathstar 120gb
    ,no name fan controler wit lcd,lite-on combo,lite-on dvd burner,floppy,Sil RAID PATA controller,Sil sata RAID controller,SB Audigy 2,2xcold cathode tubes,while playing all the newest games at the max settings thst I could get my shit to go! It barley put out any heat,and I could Never hear it over all the other fans,but the Volcano was the loudest thing in there.Being the worry wart that I am,I went out and purchased the Neopower 480,thinking could kill that As soon as I got my prescious home,I hooked her up and started to game,everything was good for about an hour,then it would just shut down.It got plenty hot alright,so I stuck a 80mm fan on the rear of it,problem solved!Im still worried about the Trupower.It now resides in my file server,where the conditions might be better.Same motherboard,same pata and sata controllers,one burner,on board sound,eVGA 5700LE,5x80mm fans,3 are led,floppy,1gb KVR(2 sticks)4x300gb Maxtor DM 16,1 being sata,1xMaxtor DM U8 200gb,1xMaxtor DM16 500GB,1x Maxtor DM Slimline 8 30gb,XP Pro sp2.
    now am I walking on a ice pond here?It runs 24/7.My daughter and son watch movies and listen to music with it from their own Pc's as do I and my wife,mabey Im just lucky,but that is one hell of a old PSU!
    MSI K8N Diamond Plus SLIx16
    3700+ Sandy E4 245x11@2695 1.47v
    Zalman 7000bcu w/AS5
    2GB KHX PC-4000 3-4-4-8-1T
    eVGA 7900GT KO 600/1600 (3RD RMA)
    2xWD SATA1 80GB RAID 0 16KB/16KB
    Lite-On SOHC-5232K
    Lite-On SOHW-1693S
    SB X-FI 9000 Extream Gamer 64mb
    Antec Neopower 480 v2.0 (with sleaved cables 18&18@36amps
    Antec P180
  • CAD4466HK
    • Sep 2006
    • 43
    Re: Watts vs. heat
    So should I be worried about the Antec? My case temps are 32C,Im pulling about 600 watts on a 430!we'll see!
    Lite-On SOHC-5232K
    Lite-On SOHW-1693S
    Antec P180
    • 999999999
      • Sep 2006
      • 774
      Re: Watts vs. heat
      Carrage returns are your friend. I will take some aspirin to get over that paragraph.
      3 years is not an old PSU, unless it was really bad junk. Every OEM system out there (on average) runs several more years on their PSU, most systems do unless there's a system (cooling?) fault or PSU fault.
      Having to add another fan could be a sign that your chassis cooling isn't good enough for the system thermal load, and might be improved by opening up chassis intake area or adding pusher intake fans in the front of the case. OR, you could just do what you did, put the fan directly on the PSU though it doesn't always take care of the other system parts' heat as well, tends to just divert more exhaust from the rear case fan to the PSU exhaust.
      You do have a good rear case exhaust too?
      Anyway, the load you described should run off a PSU with 26A, if that's an accurate rating.
      If you can't stop worrying then open it up, blow off the dust and inspect it. If it then looks ok, no system problems anymore, use it as long as you can and so long as voltages are ok.
        Mounting and Handling Guidelines for TO220 TO220F TO247 Cases / Packages
        The TO220, TO220F and TO247 are the popular packages for power devices because of their versatility and ability to dissipate moderate amounts of heat. This application note describes the basic guidelines for handling power MOSFETs in TO220, TO220 and TO247 packages shown in Figure 1. Please note that only mechanical and soldering guidelines are covered here. Additional precautions are required for isolating high voltage rated devices to meet safety regulations.
        Securing a good thermal interface between...
        10-07-2024, 04:35 AM
      • harp
        detecting heat with IR LED receiver
        by harp
        I have some dark IR led, and want to know if it is be situable to detect pure heat (not visable glow ir radiation) in well lighted desk?
        So, if I put hand over it in near distance like few centimeters, that detect rising heat, not covering it from light.
        Something like termal camera, but in one spot, any simple circuit?...
        09-06-2023, 06:03 PM
      • ludovik
        Moto G84 short after heat
        by ludovik
        i was reballing the power manger of a moto g84, after applying heat i tried to power on and it wouldn’t.
        i injected 1.5v to some capacitor that seem in short because both side beep if tested.
        when i inject i feel the cpu burning;
        since the cpu is exactly on the other side of the board, is that possible that the heat from the reballing damaged the cpu? do you know where i can find schematics or what can i do?
        i know this is not enough to explain the situation so if you need any other info ask me please!
        Thank you very much in advance
        11-08-2024, 02:13 PM
      • jm1234
        Solder joints on heat sinks matter?
        by jm1234
        solder joints on heat sinks - how much do they matter? Could poor joints on heat sink cause issues if they are not properly joining to hot ground?
        I'm looking at power source module of Panasonic plasma TV and I see many of these having visually poor quality, but could they matter? In general I would guess no, but I saw a video where someone was stressing out the importance of tightening the screws when fastening the power source board specifically for the ground to be connected properly.
        04-28-2024, 04:38 AM
      • myth77
        direct heat stencil,where do you get it? and how to prevent warping?
        by myth77
        So, lately i found that for smaller chips like pch it is very difficult to reball with nondirect heat stencil. So i decided to try direct heat stencils...and while i am waithing some stencils to arrive i have a few questions:
        1. From who do you buy a quality direct heat stencils? i am reading that they can vary in quality and make a big difference...Any trusted sellers?
        2. I am reading also the problem of warping (curving) direct heat stencils...Is it because of quality of the stencils? or/and because some preheating is also required? and help and advice here?
        01-17-2022, 05:06 AM
