Bad caps replaced, but how to start the PSU?
  • LinPack
    • Sep 2006
    Hi all
    My cheap, "generic" PSU suddenly died, so i replaced it with a new one and take the dead one to do some experiments.
    First, i opened the cover and found it filled with bad caps, so i replaced them all.
    Plug the power cord on, nothing happened
    Then i decided to check all the transistors and rectifier diodes: They're in good condition.
    I stuck here for 2 weeks, then finally i thought that maybe the PSU need some power to kick off.
    Immediately i grabbed my bench supply and bump 12volt into the yellow wire of the dead one.
    It works
    But now i still cannot figure out how to start it independently. I cannt find the start-up resistor, there's no high ohmic resistor between the 340Volt and the control circuit, just a opto-coupling
    Please, explain me more about methods to start a switching PSU.
    Thanks alot.
  • elbrute
    • Jul 2006
    • 24
    Re: Bad caps replaced, but how to start the PSU?
    Is it an ATX type?
    If so you need to jumper the green power-on wire to a ground.
    • yanz
      • Nov 2004
      • 910
      Yes, exactly like what elbrute said.
      example:
      See also:
      Your PSU is "LIVE", but not "On" :
      http://www.jonnyguru.com/atx/index.html
      Well, the psu will really be dead if it has no +5v on its purple (+5v standby) wire. Measure it on the atx connector with your multimeter.
      Please be careful not to touch the inner side of psu when it gets live connection to the main plug.
        by momaka
        03-12-2025, 03:42 PM
        by momaka
        03-15-2023, 10:17 PM
      • esqmooo
        HP Elitebook 845 G8 dead, only caps lock flashing 7 times. Charging light always on
        by esqmooo
        Hello everyone.
        This is my development machine. I've been using it since two years and half without any problem except sometimes it wouldn't wake up from sleep.
        Lately the issue became more frequent and powering it up would take few seconds to show the POST screen.
        Then the computer refuses to power on at all. Now only the caps lock button flashes 7 times then stops. The charging light is always on whenever a power source is connected (battery or charger).
        I tried long pressing on the power button, after several seconds it would go off then when the button is released...
        03-11-2025, 03:57 PM
      • bcstedt
        LG 42LB5D, 42LB5DF-UL, 2008-01, Power On Issue, Replaced PS Caps
        by bcstedt
        LG 42LB5D (42LB5DF-UL) from 2008-01, unit is in good shape and no obvious heat damage or cracked solder on the boards.
        Problem:
        On first power-up the power LED flashes green about 18x and then stays solid. No backlight or image is present. Click power button, wait 10s for a click and the LED turns red. Wait 1-2s and hit power again and maybe it'll power up fully after 6 green flashes. If it doesn't light up on the sixth flash then the cycle repeats.
        It seems that if the mainboard power is left on for a few minutes (solid green power, no backlight, no image)...
        01-18-2024, 01:03 PM
      • eryjus
        by eryjus
        05-10-2023, 11:21 AM
