Newb Question: What is that white compound?
  • Greensold
    • Sep 2006
    I recently opened up a PSU from a "popular computer manufacturer" because the fan had gone bad.
    I noticed that most (maybe all) of the caps had a hard white compound on top of them. It looked like epoxy to me, but one of my coworkers said it keeps the caps cool.
    I find that hard to believe since I've never seen it before, and in one spot the top of a transistor (mounted sideways) was connected to the side of a large cap with the stuff. That was the only spot where the compound wasn't just a standalone glob on top of a cap.
    If it does keep the caps cool, why isn't every cap covered with the stuff?
    Enlighten me please.
  • Galvanized
    • Mar 2006
    • 468
    Re: Newb Question: What is that white compound?
    It's silicone and it's used to stabilize the bits during handling and shipment.
    Welcome to badcaps. Please do look around. The PSU pics thread will show most all units use the goop.
    • gonzo0815
      • Feb 2006
      • 1600
      It avoids noise too, thus most mfk do a lot in.
      • UraBahn
        Scrapheap Hound
        • Nov 2004
        • 165
        But it certainly won't keep the caps cool. In fact, having too much of that glue (that's the white goop) in the PSU will restrict airflow and cause things to heat up considerably. I'm not saying that glue is a bad thing in PSU (far from it actually) but having too much can't be good.
        I'd personally be concerned if I opened up my PSU and found the insides smothered with glue. I'd take that as a sign that the manufacturer used cheap or underrated parts, and compensated for the resulting heavy component/coil vibration by dumping lbs of glue into it.
        Of course I'm wrong on so many things... Damn the conspiracy theorist in me.
        Last edited by UraBahn; 09-09-2006, 10:00 AM. Reason: ahem... 'almost clogged with glue?' what was i smokin?
        The ever-amazing (and ever-affordable) KY, Chemi-con's best kept secret.
        I'll probably be the only person going to SteamOS once it gets out of beta (ha ha.)
        • PeteS in CA
          • Aug 2005
          • 3581
          • USA, Unsure of Planet
          The goop is used to stabilized taller and heavier components against shock and vibration. If the caps or inductor cores are being worked really hard, the insulating effect of the goop would make me nervous.
          PeteS in CA
          • jonnyGURU
            • Feb 2006
            • 244
            It must have been a PSU used in a porno.
            Rest in peace BFG. You were... a job...
            • Tom41
              • Oct 2005
              • 336
              • England
              I've seen PSUs where the cap tops are covered with glue. This begs the question, what would happen if the caps were to vent? It's as bad as gluing the vents shut, and could cause the caps to fail from the bottom or even the sides!
              One failed PSU I saw had the caps covered with glue. The internal temperature was so high that the glue had turned back into a semi-solid substance, and at the same time the cap underneath had vented - leaving a large bubble in the glue (which then hardened again)!
              You know there's something wrong when you open your PC and it has vented Rubycons...
              • Greensold
                • Sep 2006
                Thanks for the replies everyone. It was very informative.
                Sounds like the silicone doesn't do much for the heat in the caps, so it's probably good that we're deciding to get a replacement PSU (We didn't have a replacement fan of that size anyway). The fan had gone bad and the computer was shutting down from overheating (and there's no temp sensor inside the PSU), so I imagine the caps were getting pretty hot.
                • larrymoencurly
                  • Oct 2004
                  • 960
                  If it's glossy and white, it's silicone rubber, but if it's semi-glossy or flat white, like the stuff found in Delta and Newton PSUs, it's something else that dissolves with lacquer thinner or carburetor spray.
                  Why do Channel Well Antecs have that yellow sealer/glue that turns brown and brittle in a matter of months. CWT knows it's bad because they use silicone rubber on some of the caps.
                    MSI Prestige P65 8RF-456NL Creator White Notebook P Specification for Upgrade or Repair
                    This specification for the MSI Prestige P65 8RF-456NL Creator White Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the P65 8RF-456NL Creator White boardview and P65 8RF-456NL Creator White schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                    09-06-2024, 07:46 AM
                    MSI Prestige P65 8RF-442 Creator White Notebook P Specification for Upgrade or Repair
                    This specification for the MSI Prestige P65 8RF-442 Creator White Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the P65 8RF-442 Creator White boardview and P65 8RF-442 Creator White schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any...
                    09-06-2024, 07:29 AM
                    MSI Prestige P65 8RF-445ES Creator White Notebook P Specification for Upgrade or Repair
                    This specification for the MSI Prestige P65 8RF-445ES Creator White Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the P65 8RF-445ES Creator White boardview and P65 8RF-445ES Creator White schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                    09-06-2024, 07:25 AM
                    MSI Prestige P65 8RF Creator White Notebook P Specification for Upgrade or Repair
                    This specification for the MSI Prestige P65 8RF Creator White Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the P65 8RF Creator White boardview and P65 8RF Creator White schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                    MSI Prestige P65 8RF-457BE Creator White Notebook P Specification for Upgrade or Repair
                    This specification for the MSI Prestige P65 8RF-457BE Creator White Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the P65 8RF-457BE Creator White boardview and P65 8RF-457BE Creator White schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
