5v Wall Charger
  • mscott03
    • Aug 2010
    • 16
    5v Wall Charger
    I'm trying to create this for a home project but have a few concerns. I simply want to take the 110v from a wall socket and take it down to 5v for a cell phone charger and understand so far:
    110v > Stepdown transformer (12v) > Rectifier > Cap for stabilization > 7805 Regulator > +5V...
    Only thing is, I've opened up a plug in wall charger and there is a lot more to it than that! Not to mention, the transformer inside these are tiny, and I can't seem to understand what is going on in these wall chargers, it seems a lot more in depth than the instruction I've got so far..
    Is it that simple to make? And will it be very small?
    Re: 5v Wall Charger
    The first question is, why? A wall charger is a cheap, inexpensive device. If you are doing this to learn, then there are much better and safer projects to attempt...
    The majority of wall chargers use switch mode power supplies to reduce the cost of that transformer. A smaller transformer can be used by using a higher frequency than 50/60Hz mains would otherwise allow. However, the component complexity is much greater and reliability isn't usually as good -- but it's a cost compromise.
    • mariushm
      • May 2011
      • 3799
      Re: 5v Wall Charger
      What you plan to do is a linear power supply, which sounds good the way you explain it.
      Only you wouldn't need a 12v stepdown transformer, the 7805 only needs about 8V to output stable 5v. So a 9V transformer would do, it would be cheaper.
      And if you want to save even more money on transformer, you could opt for a 6v transformer and use a linear regulator that needs much less voltage drop to output smooth voltage.
      7805 needs 1.5-2v to output 1-1.5A, but a chip like MIC2940 only needs about 0.5v above 5v to output 5v at up to 1.25A:
      http://uk.farnell.com/micrel-semicon...-0v/dp/1556712
      Wall chargers are switching power supplies. They can use smaller transformers because they work differently compared to power supplies.
      They use a chip to switch on and off the input voltage at a very high frequency (50k+ times a second) sending pulses of electricity through the transformer and then smooth out the output using the capacitors.
      This high frequency allows smaller transformers - your linear design would run at the main AC frequency ... 50-60Hz, so it has to make up for the lower frequency by using bigger transformer (with more metal and magnetic field).
      Nowadays, you'd have a hard time making one of those wall chargers cheaper than they're available commercially, they buy components in big volume while your components would be more expensive.
      If you're really interested into learning about switching power supplies, you'd have to read about it.. There's application notes for various switching power supply controllers which explain how they work and the datasheets for various controllers.
      For example look up the Viper series of controllers: https://cdn.badcaps-static.com/pdfs/...1394dd41e8.pdf
      Or the TNY chips : https://cdn.badcaps-static.com/pdfs/...4b65260377.pdf
      They're highly integrated chips which use a small transformer to output 5v or whatever you want.
      And if you're interested in general about switching power supplies, there's good books which explain how to make one, such as these :
      http://www.amazon.com/Switching-Powe...er+supply+book
      • flat-earther
        ASUS X54H laptop thinks it's always charging even with charger unplugged
        by flat-earther
        The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
        Windows also shows ''Plugged in'' when charger is not connected.
        This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
        Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
        If I let battery run out and say it has 3% Windows will...
        06-24-2025, 09:32 AM
        NVDC charger configuration...
        11-05-2024, 03:28 PM
      • Phil289
        Battery Charger - Transformer advice
        by Phil289
        Hi
        (not sure if this is the right place to post this but couldnt see anywhere else)
        I Have a very old battery charger which was given to me - it is 6v/12v 10amp.
        It is in like new condition and even in the origonal box - it works fine but is very noisey (buzzing)
        It buzzes as soon as its turned on even with no load on it.
        It appears to be the transformer thats making the noise.
        Can anything be done apart from find a new transformer?
        (Have attached a picture and a small video of the noise)
        Thanks...
        08-01-2022, 01:43 PM
        ISL6257HRZ ISL6257HRZ-T Laptop Battery Charger Datasheet
        Highly Integrated Narrow VDC Battery Charger for Notebook Computers
        The ISL6257HRZ ISL6257HRZ-T is a highly integrated battery charger controller
        for Li-Ion/Li-Ion polymer batteries. ISL6257 is designed for
        Narrow VDC applications where the system power source is
        either the battery pack or the regulated output of the charger.
        This makes the max voltage to the system equal to the max
        battery voltage instead of the max adapter voltage. Operating
        at lower system voltage can improve...
        11-05-2024, 04:43 PM
      • exerion5000
        DELL Alienware 17 R3 (LA-C912P) only work with 120w charger in mode low CPU clock
        by exerion5000
        Hello, I received this laptop with the following condition: When I turn it on, it shows the ALIENWARE light and the Alien button lights up, then it does not show an image and it restarts constantly, as the customer had already informed me that the battery was dead, I connected an original charger that I had it for testing, the machine turned on normally and I was able to enter Windows without problems, after a while of testing I noticed that it is very slow (like a Cyrix 425...), and after performing a CPU test the frequency is
        below normal, as if it were operating in an extreme energy...
        10-15-2023, 02:12 PM
