Most effective way to get rid of all the glue in PSU's?
  • Pentium4
    CapXon Be Gone
    • Sep 2011
    • 3741
    I'm wondering if you guys have an effective way. I usually just use pliers and my thumb nail to do what I can...
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    • Romania
    Re: Most effective way to get rid of all the glue in PSU's?
    A heat gun set to low to accompany those pliers.
    A working TV? How boring!
    • TELVM
      • Oct 2012
      • 547
      • Spain
      Exactly why do they poor that messy glue on some PSU components? Electronic noise? Vibration?
      • mariushm
        • May 2011
        • 3799
        Vibrations and to hold them in place when they go on the line to be flow soldered
        See how they move a bit when solder goes under:
        http://www.youtube.com/watch?v=8-uJ05k9Yl4
        http://www.youtube.com/watch?v=quLlGHKemRs
        And you have to keep in mind some of the manufacturers simply move the boards around on a big line with lots of employees simply taking a psu off the line, putting several parts on the board then putting the boards back on the line. A bunch of women take care of a part of the parts, so taking out, putting back, putting the board on the desk in front of them, all these can cause parts to pop out, if the leads are pre-cut.
        For example see Gigabyte's factory tour, from about 5:30 in the video below:
        http://www.youtube.com/watch?v=5vWrEmpRX_Q
        The motherboards have more mass than a power supply board, so it vibrates less when going over the rollers and the liquid solder so the solder doesn't push the board around and won't make the parts get out of the holes as easily.
        later edit: another gigabyte factory tour vid: http://www.youtube.com/watch?v=QdGW1xE6d_k where you can see in more detail the quality control process and stuff that's not in the previous video.
        even later edit: oh, sometimes (rare cases) glue is also used as a mark for the human part placers to know to put parts there. same model but for asian market may not have an inductor, the european miodel may have it. It's easier to just put a drop of glue with an automatic machine than to re-train the women placing parts on board (or to do two separate batches)
        • TELVM
          • Oct 2012
          • 547
          • Spain
          Very interesting videos, thanks . That high-speed chip-placer is worth seeing .
          Apart from the mess, one problem I see with the glue is that some components can end literally jacketed in glue, and that's not good for cooling.
          • Behemot
            • 4845
            • CZ
            Think that Enermax or who started using plastic forms some time ago to keep all components on their places. You can re-use the forms so you save money in long-term for the glue.
            I personaly use pliers and also this:
            Bet you know that from dentist's Very handy thing for perforing mount-holes full of solder and many other things! Suggest getting one
            • Pentium4
              CapXon Be Gone
              • Sep 2011
              • 3741
              Thanks for all the replies!
                master hoarder
                • May 2008
                • 12170
                • Bulgaria
                I only have a paint stripping heat gun, but I will definitely try that next time.
                I usually don't remove the glue, unless it's that tan/brown glue that goes conductive. I've noticed that some variants are more aggressive than others. For example, the type that Bestec uses usually not only becomes conductive but also corrodes component leads and PCB traces. The tan/brown glue in the PSUs of those HP DC5000 SFF computers I'm working on is even worse - besides corroding component leads, it also strips the paint off of capacitor sleeves.
                If I was a power supply, I would despise coming in for repair in your "office".
                • mitsu2k
                  The Real Dangers of conductive glue.
                  by mitsu2k
                  I know many folks on this forum warn against conductive glue and suggest removing it immediately upon site. I'm here to vouch and say these people know what they are talking about. To be more accurate, the glue isn't intended to be and doesn't actually start out conductive. It gets conductive as it is heated by components that get hot. The glue starts out to be a light tan color but as it is exposed to heat, it gets darker and darker until it is a dark brown. I have found that it becomes conductive at the point that it reaches a light brown color on darker.
                  Here is an experience I...
                  04-16-2023, 06:29 PM
                • acedogblast
                  by acedogblast
                  11-02-2024, 05:13 PM
                • AJ847.63e
                  Testing ATX PSUs under load - Does loading the ATX 24 pin also load EPS & PCIE?
                  by AJ847.63e
                  Hi Folks,
                  Just wanted to clear up a misunderstanding of mine (or what I expect is one). Isn't the 12V rail from the 24 pin, EPS and PCIE separated? IE if I put a power resistor on the ATX 12V pin that is not going to load, thus tell me if the EPS or PCIE rails are fine?
                  I was recently watching ArIs from Hardware Busters video on how to properly test ATX PSUs without using 5 figure Croma substations.
                  The PCB adapter he used breaks out the 12, 5 and 3.3V pins from the 24 pin and gives you banana plugs to connect to. That is a bit useless is it not? Aren't...
                  05-06-2025, 10:37 PM
                • digtalhd
                  Remove IC glue
                  by digtalhd
                  Hi!
                  Anybody help me. Remove IC glue on mainboard.
                  Thank you....
                  11-08-2024, 02:25 AM
                • Al-Umar
                  Need Help to dissolve glue
                  by Al-Umar
                  Please can someone tell me the chemical that can be apply to dissolve glue that used to hold the type C chip and SSD storage chip MacBook 2017 touchbar on the board.
                  Please i need a prescription of that chemical. i will be very glad if someone can help me out on that
                  05-04-2024, 07:46 AM
