Beefing up the HP-550
  • WeStSiDePLaYa
    • Mar 2006
    • 63
    Well I recently won the Mushkin HP-550 psu from XS a while back. its an amazing looking unit, but its built by top power and is lacking in perfomance.
    It has all "asia X" brand capacitors, which I will be replacing with(thanks to arrangement with Trodas ) with
    UCC
    10v 3900uF KZE
    16v 3900uF KZE
    200v 1200uF SMQ (x2)
    1. any comments on cap selection?
    i picked them due to their relatively low ESR and highest ripple current while still being decently priced.
    2. This psu also seems to lack good AC filtering, so I have added a RFI filter i got from a psu i had scrapped. but there is more i can do. i was wondering if i should add a dual choke on the input AC like i have on my antec. (what effect does it have mostly though?)
    3. What other componets can i upgrade? i have a bunch of psu's and monitors that have spare parts, i was looking at adding the missing componet that can be seen in the photo.(photo was borrowed from jonnyguru's review of the psu, link is further down.)
    4. what exactly is it and what would its effects be?
    picture courtesy of jonnyguru, used only since im lacking digi cam atm
    5. does anyone know what the VR's on the railfusion pcb would be for? they dont seem to adjust voltage.
    6. the psu has no voltage feedback on any of the rails, so is there a way i can mod the psu to raise the rails?
    im planning on powering 6 hdds, highly overclocked and vmodded x800pro, highly overclocked a64(vcore at 1.9v)
    all fans and pumps run off 2nd psu.
    i figure if my antec truecontrol 1.0 can handle it, this psu once its beefed up should be able to handle it. not to mention my antec has 3+ years under its belt at almost always 24/7 useage(fujiyhu caps still good though)
    http://www.jonnyguru.com/PSU/HP-550/
    Specs
    DFI AM2 LANPARTY UT NF590 SLI-M2R/G
    X2 3800+EE AM2
    2x1GB OCZ PC2-6400 Platinum XTC
    XFX 7900GS
    Maxtor 6L250S0
    Maxtor 6V300F0
    Western Digital WD2500JS
    Mushkin HP-550(Cap/Filter Modded)
    Cooling
    Swiftech Apogee
    Swiftech MCW-60
    Swiftech MCP-600
    HardwareLabes Black Ice Extreme 2
  • Oklahoma Wolf
    • Dec 2005
    • 353
    Re: Beefing up the HP-550
    Probably supposed to sense when the LED on the back is to turn on. Rail Fusion so far seems to be nothing more than the lack of independant protection for each 12v rail.
    Or do you mean variable resistors? Not sure to that one.
    • WeStSiDePLaYa
      • Mar 2006
      • 63
      sorry, they are variable resistors. two small single turn pots, im unsure of the resistance.
      and yes, it seems this "rail fusion" thing is all BS. there is only one 12v rail until it hits that little pcb you see mounted to the heatsink, and then it splits them there.
      EDIT: where abouts in SK are you? i used to live way down south about 10 minutes from the usa border in a small small town of willowbunch, and then coronach.
      Specs
      X2 3800+EE AM2
      XFX 7900GS
      Maxtor 6L250S0
      Maxtor 6V300F0
      Cooling
      Swiftech Apogee
      Swiftech MCW-60
      Swiftech MCP-600
      • PeteS in CA
        • Aug 2005
        • 3581
        • USA, Unsure of Planet
        The pots may adjust an over-voltage or over-current protection threshold.
        PeteS in CA
        • WeStSiDePLaYa
          • Mar 2006
          • 63
          yeah, im starting to think they are for when railfusion kicks in. this thing will need some tweaking.
          Specs
          X2 3800+EE AM2
          XFX 7900GS
          Maxtor 6L250S0
          Maxtor 6V300F0
          Cooling
          Swiftech Apogee
          Swiftech MCW-60
          Swiftech MCP-600
          • WeStSiDePLaYa
            • Mar 2006
            • 63
            i really need ANY info you guys can provide for question number 4
            Specs
            X2 3800+EE AM2
            XFX 7900GS
            Maxtor 6L250S0
            Maxtor 6V300F0
            Cooling
            Swiftech Apogee
            Swiftech MCW-60
            Swiftech MCP-600
            • sirpsychol
              Antec Earthwatts EA-380 smd element type/value
              by sirpsychol
              While recaping Antec Earthwatts EA-380 I've broke one side of unknown smd element, it have no print, it's flatter and darker than smd capacitors on this board, shaped more like resistor but it's not resistor ofc. Unfortunetly the printed description was under it and element was glued to the board so I cant read/tell the letter before element number too. Have anyone any idea what it is? Maybe is there any diagram of this PSU?
              09-03-2023, 07:58 PM
            • CWEastwood
              Antec Smart Power SL300S capacitor replacement.
              by CWEastwood
              I'm currentlly in the process of trying my first power supply repair (really my first soldering project) and have some questions with regard to which capacitors to replace the bad ones.
              The power supply is an Antec Smart Power SL300S ATX12V 300 watt.
              I have successfully desoldered every capacitor from the board without destroying anything (I think) and I am currently in the process of choosing which caps to order. This is where I'd like a little community wisdom.
              Now the capacitors inside are mostly Fuhjyyus (a forum favorite) with 1...
              03-25-2023, 12:18 PM
            • s_henya
              Antec VP-600P and NE550M dead
              by s_henya
              Got in these 2 nice PSUs, both died after power surge.
              Both seems to be suffering from the same fault.
              Blown main fuse
              Shorted N mosfet 550v
              VP-600P: 5R280CE short between GDS
              NE550M: MDF18N50 short between GDS
              In terns of board layout these seems pretty identical.
              From past knowledge, once gate get shorted, most likely the for the driver to go bad as well.
              I never tried to salvage blown fuse PSU with shorted Mosfet due to that.
              Is it worth to try and replace the mosfets? is there a chance that the...
              12-03-2024, 10:00 PM
            • ajdrenter
              Picking caps for Antec SU-380
              by ajdrenter
              In my search for a proper 5v heavy ATX power supply, I selected an old Antec SU-380 that I've had in storage for a long time. Opening the power supply reveals a couple bulged capacitors. I removed all the caps and made a map for myself. I found the datasheet for the PCE TUR series in this thread:
              https://www.badcaps.net/forum/showthread.php?t=14159
              It says these are general purpose, so I assume I can replace them with any general purpose capacitors, but I don't really know anything about power supply circuits or reading capacitor datasheets. Despite this, I've been shopping for replacements:...
              05-13-2023, 10:40 AM
            • GnatGoSplat
              Antec BP500U APFC Coil
              by GnatGoSplat
              Antec BP500U PSU fried in my wife's gaming PC. I smelled something unpleasant last night, so I had a hunch something might be amiss. Woke up this morning to a popped breaker and immediately assumed the APFC cap must have blown. I last fixed it sometime in 2011, there's a thread about it here someplace. APFC and secondary caps that time. Replaced them with Panasonic caps. 10+yrs is probably a good run. It's been running 24/7 the last 3yrs, eth mining with a 1070ti and AFK fishing in Black Desert Online, lol.
              Anyway, cracked it open this morning, expecting it to just be the APFC cap...
              11-02-2021, 09:22 AM
