Can you trick a dual redundant supply?
  • Logistics
    • Apr 2007
    • 721
    My dual xeon case uses dual 500w redundant supplies. But being for home use it isn't critical that there be a backup supply. However, obviously the alarm goes off when one of the supplies is not present or powered up.
    Can I trick it so I can run a single supply with no alarm?
  • rogfanther
    • Jul 2006
    • 458
    • Brazil
    Re: Can you trick a dual redundant supply?
    Isn“t there an option for disablin in bios or through jumper in the motherboard ?
    • Logistics
      • Apr 2007
      • 721
      Nothing in the bios, and nothing obvious in the chassis itself.
      • severach
        • Aug 2007
        • 1055
        Redundant supplies for old cases are often dirt cheap. Buy one.
        De-bark it by removing the speaker.
        sig files are for morons
        • Tynan Dill
          by Tynan Dill
          Assuming...
          11-22-2024, 01:46 PM
          07-01-2024, 06:34 AM
        • shamsudeen
          Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
          by shamsudeen
          Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
          I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
          i know that in linear power supply the noise will be very low comparing to SMPS supply....
          07-19-2025, 07:14 AM
        • CMCM
          Russound CA4 Power Supply Repair
          by CMCM
          Hello Everybody,
          Trying to repair a power supply from a Russound CA4 Multizone Controller (picture attached)
          Russound no longer supports it but were kind enough to provide a schematic of the power supply (pdf attached).
          The outputs marked 12v and 20v are all measuring only 1v.
          The board is clicking, which I think means it is in something called hiccup mode when the flyback transformers switches because of an internal problem or something else on the board Overloading it.
          The capacitors physically look clean (no bludgesor leaks) and...
          07-03-2025, 01:12 PM
        • JimBanville
          Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
          by JimBanville
          The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
          I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
          09-13-2023, 07:21 AM
