Cap replacement advice
  • tld
    • Sep 2012
    • Norway
    Sorry if this has been covered well elsewhere, I've searched around for a bit (here and on google), finding various bits of thoughts, but would really appreciate some feedback from you guys.
    Long story short; There are lots of guides on recapping, but a lot of them sum up the actual dirty work as "Now replace the capacitors", or similar.
    Well, that's not always as easy as it might sound.
    In the power-supply I'm looking at now, I've got at least two Teapo bad caps. First thing would be to get them out of there (noting polarity offcourse). In this case, positive side is mounted between a coil, and cable hookup. Both of those are sinking heat away from the cap like mad. Negative side is attached to ground-plane, again with a lot of cables.
    I've got a Hakko-clone for a soldering-station, about 50-60W or so. Here though, it's hard to get anywhere. It's hard to simply heat the joint and (gently) push out the cap, it's hard to get to the legs to cut them, and so on.
    I could take a 120W soldering-gun to the wires, removing them first, wanting with reattaching them until later (if the PSU is successfully revived).
    Anyone have any good advice?
    Front side:
    http://static.inky.ws/image/2874/image.jpg
    Back side:
    http://static.inky.ws/image/2875/image.jpg
    Terje
  • mariushm
    • May 2011
    • 3799
    Re: Cap replacement advice
    Get a hair dryer ..
    Use the hair dryer to heat up the back of the pcb in that area for a few minutes until it's nice and warm.
    Put your solder iron on the leads of the capacitor and add some leaded solder ... make blobs of solder on the capacitor holes.
    Now carefully put your finger on the capacitor on the other side, lay your solder iron as flat as possible on both blobs of solder. Wiggle the capacitor with your finger, one of the leads should pop out of the hole on the other side (usually the + side as the ground tab is sinking heat faster)
    Now as you wigle the cap, put the solder iron on that other lead and pull out the capacitor.
    60w should be enough.
    When you want to plug the new capacitor, warm the blobs and slowly push the lead inside ... you don't want to force them because you don't want the copper to break off the pcb.
    You could also try to use some solder wick to "suck" the solder from the holes after capacitor is removed, but I found it easier with such boards to just put the capacitor in... the holes are big enough in diameter that the solder doesn't get stuck in the hole.
    ps. you should replace all those 3 teapo on the secondary side, not just the two slightly swollen.
    • tld
      • Sep 2012
      • Norway
      Originally posted by mariushm
      Get a hair dryer ..
      That could perhaps do the trick, and sounds less evil than soldering gun.
      Almost tempting to do a setup with peltiers to keep temperature of coil and friends high, while soldering...
      I'll give the hairdrier a spin, and see if I can tackle this beast. Thank you very much.
      I was thinking about holding off with the last few caps (there's one or two more, that doesn't show in the photo), until I've changed the bulging ones, making sure I could get this done properly, and seeing if the PSU can be rescued, then replacing the rest if there's hope.
      Thinking behind that is to not waste good caps if this is a loosing project anyway, and getting a feel for how hard it'd be to replace the last few caps. If I have to fight all the way through this, risking the board, maybe it'd be better to leave in the last few for now?
      Note that the board came from a home-server, and I'm not looking to place it back into active service there, so won't be critical if it'll break at a later point.
      Again, thanks for your advice and help.
      Terje
      • acedogblast
        by acedogblast
        11-02-2024, 05:13 PM
      • Glaval
        Sony OLED XBR-65A8G 4 flashes
        by Glaval
        Hello, my Aunt recently gave me her broken Sony XBR-65A8G OLED after getting a replacement. It had a 4x led flash error, a replacement T-con didn't fix the error but with helpful info from this forum I found one of the smd ceramic caps on the panel pcb (C575/C378) on a 24v line was shorted to ground. I removed that cap and the tv turned on without error. It still had a black screen with the original t-con back in it, once I put the replacement t-con in it finally had a picture. After doing a panel refresh it had a very good picture but with a few vertical lines for some scenes. For owners with...
        01-23-2025, 04:04 PM
      • bussincaps
        MacBook Pro Mid-2014 A1398 Retina LED Controller Connector [First Repair (Disaster)]
        by bussincaps
        Hello All,
        tl;dr: minimal electronics experience and my first repair, lifted 8 pads off the laptop display LED controller board when attempting a connector replacement, options are attempting pad repair or jump wiring.
        Laptop Model: MacBook Pro 15 Mid-2014 Retina, A1398 MGXA2LL/A
        eDP Display: Samsung LSN154YL01-A02, assembly sold as Apple part 661-8310
        Soldering Equipment: Hakko FX-888D w/ T-18 tips (Chisel, Conical, Bevel types)
        I needed to replace the 30-pin I-PEX Cabline connector (labeled J8300 in the Apple 820-3662 mainboard schematics),...
        08-03-2023, 12:57 PM
      • AJ847.63e
        LGA 1700 Socket Replacement Tips & Tricks
        by AJ847.63e
        Hi All,
        Just wanted to see if I can get some advice on techniques and equipment I should use to try replace the socket on a Gigabyte H610M h v2ddr4 I have.
        I was planning on using a heat mat I have that's used for phone, tablet screens, as a base heater than use hot air with a square nozzle on top. Yes I should get a proper preheater but I'm not in the position to go spend 300+ bucks on something I will use every 6 months if I'm lucky. Next expense I need to get is a decent programmer like the RT809H but again it would get used infrequently so hard to justify.
        07-24-2025, 06:57 PM
      • ttmi100x
        HANNSG Hi221 -- 2 secs to black feat. CCFL flicker & "burn" marks on power board
        by ttmi100x
        Greetings everyone,
        I have a HANNSG Hi221 monitor that exhibits two seconds to black issues (backlight goes off, display is still on as confirmed by shining a flashlight on it) with some additional oddities...
        The monitor failed on me with a standard "2 seconds to black" some time ago prompting me to initially replace most of the electrolytic capacitors (some of them were bulging/leaking).
        Things kinda sorta worked for a night, then the problem returned along with some flickering and "buzzing" noises.
        Upon closer inspection...
        07-31-2024, 06:36 PM
