Need help on this lenovon Power supply
  • ivtec
    replied
    Re: Need help on this lenovon Power supply
    Originally posted by selldoor
    Well done - try just hitting "enter"?
    thanks: when i hit enter upon starting up it goes to bios and PC setup and start up safe mode i tried to change admin pass word but no avail,still asking for password i went to the person that gave the PC and for my surprise they told me to look for a Computer shop to format the disc and reinstall windows,what a great help,thanks but no thanks i don´t want to spend any money on this, i have plenty of computers in the house,if i can get this to work fine if not keep it for parts,.
  • selldoor
    replied
    Originally posted by ivtec
    but now that the pc is working it asks me for name and password
  • ivtec
    replied
    QUOTE=selldoor;260704]Not all PSU's are the same - you might want to read this and see if it helps
    https://www.badcaps.net/forum/showth...rey#post222842
    I think your diodes are ok - pictures of the backs are no use for troubleshooting
    - use daylight - no flash.[/QUOTE]
    Thanks; i made it work don't ask me how but i just replaced those two rectifiers that i took out ,i also res soldered the third one and had also to make the connection on one of the lines that broke when i had to bend the hit sink in order to remove the rectifiers,ha and also had removed a cap that in circuit looked short but it was good out of circuit,i
  • selldoor
    replied
  • ivtec
    replied
    Originally posted by Mad_Professor
    You did it wrong.
    green jumper ground/black *PSU should come on
    black probe on ground/black *doesn't have to be same as the jumper wire, any black will do.
    red probe to test RED 5v, ORANGE 3.3v, YELLOW 12v.
    Quickest way to test is get one of those cheap PSU testers. If all voltages are there, just recap the PSU.
    Well i did test it correctly,and only have the 5v,i can say it's bad cause i have two other working pc power sup,and jumped those and i can see them working also can test voltages and they are their ,the problem is cannot use them cause they are bigger the plugs are smaller and do not fit
    i took out those Schottky Rectifiers that i posted in the previous post but i don't know for sure they're ok.what other components should i look for?
    thanks in advance.
  • Mad_Professor
    replied
    Hi guys; i removed 2 of the STPS2045 and made some measurements with my Fluke on diode side and came up with this,see pic attachments below best i could get,
    also disconnected the power supply from the PC and checked voltages red probe on green wire(PS-on) and black probe on most of the colored wires all i got was .05.00 volts so no 0.3,or 12vols
    You did it wrong.
  • ivtec
    replied
  • selldoor
    replied
    Pictures are not big enough/clear enough for troubleshooting - if you mean the middle of the three transistors yes it does look burnt. Perhaps under too much pressure from rippling caps
  • Mad_Professor
    replied
    Did you check to see if it's supply 3.3, 5, 12v? You may have to short it to get the PSU on, get a DMM and check yellow 12v, orange 3.3v and red 5v for voltage, if you do and they are within 10% of the expected voltage then your problem may be as simple as dried/bad caps.
  • ivtec
    started a topic Need help on this lenovon Power supply
    Hi guys,i was given this Lenovo Desktop but it´s dead now i'm trying to figure out what's wrong with the power supply,took some pic,i suspect this
    http://www.alldatasheet.com/view.jsp?Searchword=2045CT
    http://www.neweggbusiness.com/Produc...82E16883205400
    by sam_sam_sam
    03-31-2024, 02:12 PM
    by sam_sam_sam
    07-01-2024, 06:34 AM
  • JimBanville
    Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
    by JimBanville
    The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
    Opened it up and discovered the power supply is making a faint clicking or ticking sound.
    I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
    I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
    09-13-2023, 07:21 AM
  • CMCM
    Russound CA4 Power Supply Repair
    by CMCM
    Hello Everybody,
    Trying to repair a power supply from a Russound CA4 Multizone Controller (picture attached)
    Russound no longer supports it but were kind enough to provide a schematic of the power supply (pdf attached).
    The outputs marked 12v and 20v are all measuring only 1v.
    The board is clicking, which I think means it is in something called hiccup mode when the flyback transformers switches because of an internal problem or something else on the board Overloading it.
    The capacitors physically look clean (no bludgesor leaks) and...
    07-03-2025, 01:12 PM
