Codegen 350XA supply
  • milesy
    • Aug 2012
    • 34
    Re: Codegen 350XA supply
    Ok so if the assumption is correct i should be able to hook the Cro up to the anode of the regulating diodes and see a trace basically the same but alternate polarity on each anode??
    • rievax_60
      • May 2012
      • 897
      • australia
      With the power supply lightly loaded, on the diode anodes there should be a stepped square wave. It alternately pulses negative and positive with zero volt dead times in between.
      It should look exactly the same on each anode, but 180 degrees out of phase.
      If both diodes are working, there should be a square wave of double the frequency at the common cathodes(middle pin). The bottom of this square wave should not go more than about a volt negative.
      • Escort Eagle
        • Jul 2012
        • 110
        OK. It generally happens when the Output caps are gone Bad or when Caps Pins soldering with PCB gone bad . I hope you have no output Badcaps and Bad soldering because you have tried those method already .
        Now you connect the Power supply with Motherboad and tell me is there any Display in Monitor ?? If I am not wrong, then the power supply has no display . Please ensure me this power supply has display or not .
        • b700029
          Banned
          • Sep 2010
          • 640
          Escort Eagle, he's not going to get anything to work with the 12V rail at half its nominal voltage.
          Originally posted by c_hegge
          Diodes on a bracket!!
          Replace the two diode-bracket with a proper rectifier. one of them could be toast
          You mean diode on a bracket
          ...The possibly only advantage of building it this way is so you only need to replace one diode instead of a 2-diode pack...
          • c_hegge
            • Sep 2009
            • 5219
            The single diode is for the 5vsb. I was referring to the 12V rail before. Admittedly, putting the 5vsb diode on the heatsink is a much more sensible option than Bestec and Delta putting it next to the 5vsb input cap. Who would have thought that Codegen could do better than Bestec and Delta?
            • kaboom
              "Oh, Grouchy!"
              • Jan 2011
              • 2507
              While you're at it, replace the small ceramics in the RC snubbers on the secondary side.
              Had one of these junkers where on of the 10 ohm resistors in a snubber was totally incinerated.
              It was under some unburned dust, so I think the ceramic cap shorted shortly after the supply was first used, with the dust building up over the (short?) life of the system.
              "pokemon go... to hell!"
              EOL it...
              All style and no substance.
              guilty,guilty,guilty,guilty!
              guilty of being cheap-made!
              • Escort Eagle
                • Jul 2012
                • 110
                12V is dropping to 6V at loaded condition . At normal state it is showing 11V . Now First I need to know - Is the Display is showing or not . This Display's presence or absence will separate the problem of voltage dropping . This Display's presence or absence will tell you - why the voltage is dropping - Is it for Primary side or Secondary side . Display's presence or absence will identify that . This is why - I need to know Display's presence or absence First .
                • milesy
                  • Aug 2012
                  • 34
                  hi guys sorry for the late reply back to this.....Escort Eagle i havent been able to connect a monitor to the MB but i would suggest that there is not action from the board anyway.
                  i got out the cro and checked the trace on the rectifying diodes for the 12v line (two diodes to a bracket from above) and this is what i get
                  IMGP9565.jpg by Adrian Miles Photography, on Flickr
                  so it looks to me like im missing half of the trace - from well before the rectifying diodes...i have checked both of the switching transistors at the front end and they appear to be fine........next???
                  • Escort Eagle
                    • Jul 2012
                    • 110
                    OK . There is another option . Check the Voltage on PG supply . PG is Gray Cable . What voltage present in PG Cable ?? Before measuring PG Voltage, You must turn on the Power supply .
                    • milesy
                      • Aug 2012
                      • 34
                      hi escort - with the supply loaded the grey wire measures 0.06 vDC - so essentially zero with the yellow wire sitting at 6v
                      • milesy
                        • Aug 2012
                        • 34
                        can anyone confirm for me that the trace shown on the cro above is NOT the correct shape??
                          Where is your ground on the screen, the centerline?
                          • milesy
                            • Aug 2012
                            • 34
                            yep centreline
                            • rievax_60
                              • May 2012
                              • 897
                              • australia
                              #34
                              Im not certain why your waveform looks unstable. It might be something wrong with your CRO.
                              I took some waveforms from a 350XA that I found here.
                              Notice the cathode waveform is double the frequency of the anodes' waveform. This tells me that both diodes are passing the positive half cycles from the transformer.
                              What is the peak voltage of your waveform? Mine is 30v.
                              I have a 27Ω load on the 12v rail. The waveforms look very different without this load.
                              • milesy
                                • Aug 2012
                                • 34
                                ok thanks rievax ....well now im scratching my head....for sure on my unit the cathode is definatley double the anode so yes its passing both cycles however i thought that the flat section between each peak looks wrong......
                                rechecking my levels seem to be about the same as yours......30v peaks ...my photo may not give the right impression - taken with a digital cam on a slow exposure
                                so if the signals are the same as shown by rievax - where do i start looking now??
                                • rievax_60
                                  • May 2012
                                  • 897
                                  • australia
                                  #36
                                  It is becoming a puzzle. A few more checks you can do.
                                  You can measure the average voltage of the cathode waveform with a multimeter. The reading should be the same as the other side of the power choke winding, at the 12v output.
                                  Also look at the waveforms with the CRO set to a slower timebase. This might show if the power supply is running in busts rather than continuously as it should be.
                                  Also check the outputs for excessive ripple.
                                  • milesy
                                    • Aug 2012
                                    • 34
                                    thanks rievax.......i wish i could find a working one of these to compare it to...would make life a little simpler
                                    • Escort Eagle
                                      • Jul 2012
                                      • 110
                                      OK, milesy . I hope it is 0.06V without Load also . You are always busy for Secondary side and wave form . But this problem is raising not for secondary side . You are searching in wrong Side . This problem is raising for Primary Side .
                                      Just change the Primary main two Filter Capacitors 470mF200V . I know they are looking absolutely fine . But they have still problem . This problem is raising for these Primay Capacitors only, not for secondary Diodes or capacitors . Just Replace those capacitors and your power supply will be 100% OK .
                                      Such ratings capacitors are hardly found in the market . If you found you are lucky . Instead of new capacitors - you can use old capacitors from OLD power supply from the Junk . If OLD capacitor are 330mF 200V, you can use that . Most of the power supply use 330mF 200V ratings capacitors .
                                      Replace those capacitors and you are all done .
                                      • milesy
                                        • Aug 2012
                                        • 34
                                        so escort, ill give this a try later i have some 330uf 450v caps sitting around which should be ok to try with........BUT the question i have is why ??? why would those caps cause this fault, can you explain the theory
                                        thanks
                                        • rievax_60
                                          • May 2012
                                          • 897
                                          • australia
                                          #40
                                          Milesy, Just in case you do not know. It is not possible to safely reference your CRO to the live/primary side of the power supply without using an isolation transformer.
                                          One way to test for a faulty 330uf-200v capacitors is to measure the AC ripple with a multimeter. But only if you can safely position the PCB outside of the case.
                                            by sam_sam_sam
                                            03-31-2024, 02:12 PM
                                          • JimBanville
                                            Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
                                            by JimBanville
                                            The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
                                            Opened it up and discovered the power supply is making a faint clicking or ticking sound.
                                            I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
                                            I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
                                            09-13-2023, 07:21 AM
                                          • madan1
                                            555 based power supply getting too hot
                                            by madan1
                                            Good day.
                                            I have an AC/DC -> DC PWM (rectifier + 555 buck converter) power supply with MDF11n60, which is getting very hot.
                                            The input is AC from a transformer and the output powers a 24v dc fan. The power supply is used to regulate the speed of the fan.
                                            After several runs on the bench power supply I noticed that the mosfet is reaching 80+C*. The mosfet reads fine on component tester, the thermal paste is changed, the fan is cleaned and with freshly oiled bearings.
                                            When powered directly from the bench psu, the fan takes ~0.7A on 12V. The current consumption is similar...
                                            06-23-2025, 04:38 PM
                                          • playit
                                            450watt power supply 5v, 3.3v short to ground wire,in output rail ,connectors
                                            by playit
                                            hello everyone , working zebronics power suply 450 watts , 5v ,3.3v givin short to ground black wire, also in circuit at output, resistor was charred but shows right values , after removing resistors 39ohms, 51 ohms, there was no short , no continuity beeps with ground , but after replacing new resistors (now i am not switching it on) ,again short still exists . when i put bigger ohm resistor like 100k ohm , no short beeping sound comes , lower ohm resistor gives continuity beeps ,other big ones donest , as its a working psu , i am confused what to remove now or how to go further now .
                                            09-02-2023, 02:43 AM
