My PowMax finally had badcaps...
  • UraBahn
    Scrapheap Hound
    • Nov 2004
    • 165
    Big surprise
    One day I turn my trusty homemade Pentium III server on, and it freezes while loading a webpage. Pressed reset and then it wouldn't recognize the hard drive. Hmmm, this is weird I thought. After powering down and powering up, it worked just fine. Uh oh, I knew what that meant...
    Took a good long look at the caps on my Jetway 993AN. All the Rubycon MBZ/YXG and the six remaining GSC general-purpose caps look fine. (Did I mention that I replaced all the low-ESR caps and several of the GP caps on the board with Rubycon MBZ and YXG low-ESR caps?) Then I remembered that I was using a PowMax power supply. So...
    Found two dead JEE 2200uf 10v caps, so I went to work recapping till 12:45 in the night. So far I've replaced all but one major cap on the PSU board with Nichicon PL, Rubycon YXG, Chemi-Con LXJ, Samyoung KME and even a few JPce-tur, but now the last cap I need is a 2200uf 10v, and all I've got left is a 2200uf 6.3v Chemi-Con LXJ. My question is, would it be OK if I put the 6.3v cap in place of the 10v one?
    Thanks for any help you can offer,
    urabahn
    (P.S. Yes, I do plan on getting rid of the PowMax soon. I just can't do it right now because I'm flat broke!)
    The ever-amazing (and ever-affordable) KY, Chemi-con's best kept secret.
    I'll probably be the only person going to SteamOS once it gets out of beta (ha ha.)
  • Shroomie
    • Apr 2006
    • 356
    Re: My PowMax finally had badcaps...
    If it's a 10v cap, it probably didn't handle 12v, so the 6.3 ought to cut it. The next lowest voltage is 5v after all. Don't take my word for it though, I'm assuming.
    You know there's something wrong when you open up a PSU and are glad to find Teapos.
    Why I don't buy cheap cases!
    • UraBahn
      Scrapheap Hound
      • Nov 2004
      • 165
      @Shroomie: OK, I'll try it out. I don't really have alot to lose other than a Tualeron 1.3 GHz testing rig I'm gonna test this supply with. Thanks for your help.
      BTW, I like your sig. That's why I prefer Delta, Astec and LiteOn... whenever I can find them. The only reason why I have this PowMax was because it came with a case I bought long before I knew about the Taiwanese capacitor problems. Apparently I got one of the older PowMax's, because mine feels relatively heavy and is packed with electronics, unlike the new ones which are more akin to Deer.
      • Shroomie
        • Apr 2006
        • 356
        Heh, thanks. Good luck with it, too.
        • dood
          Deputy dood
          • Mar 2004
          • 2462
          One thing to remember is that simply replacing the caps isn't going to cure the inherent bad design of a PowMax PSU. I'd replace it with something that has beefier circuitry. I don't even consider recapping a Powmax... I've seen far too many of them explode upon experiencing power anomalies.
          Ludicrous gibs!
          • UraBahn
            Scrapheap Hound
            • Nov 2004
            • 165
            Well I ran out of solder(!) before I could finish recapping the PowMax, so I just replaced it with an old 200W Hipro I got from Goodwill for $3. Peering inside the Hipro, I found two 470uf 200v Panasonic primary caps (which I replaced with 680uf Rubycons shortly after I got the supply), and Fuhjyyu TNR and Su'scon caps on the secondary side. Fortunately none of the caps look bad yet, but I know those Fuhjyyu TNRs are gonna go bad when I least expect them to.
            BTW there was nothing wrong with the two 470uf Pannys I removed. I just wanted better input filtering, because I live out in an area which is afflicted with minor power dips daily. In fact, anybody want two 470uf 200v Panasonics? I'll be glad to mail 'em off to anyone who needs them. (Check the For Sale / Trade post if interested.)
            • ChaosLegionnaire
              I finally got one too! a new monitor! and my first ips panel to boot!
              by ChaosLegionnaire
              after bigtroll managing to score a new video card in this thread, i thought i'd get a new monitor too, since my current one has a bubbly and blurry screen that i posted in this thread.
              i tried numerous local websites to get one but many required a mobile number to sign up which i dont own. i also had issues finding the right monitor that met my requirements. it was a nightmare finding one, spending weeks looking through g00gle.
              finally, i decided to try lazada, the singapore version of jack's aliexpress. it only required an email address for signup, but whenever i...
              10-12-2021, 02:07 AM
            • RukyCon
              ZUMAX Technology (Leadman Power) ZU400W (X1), Modifications & Life Test
              by RukyCon
              Hello Again, so i'm bringing back this Zumax PSU from the gutless thread and going to be doing some modifications, and also putting it into a PC i'm going to throw together out of spare parts to see how long it lasts.
              So the first thing i did was fill in the missing filtering, by replacing the cheap common mode choke with a real one and adding a 470nf X2 capacitor in the open capacitor spot, i then replaced the fake Y-class capacitors with real ones, i also swapped out the mismatched primary caps with a pair of Aishi WK 470uf 200v caps, both of which test around 520uf. I also swapped...
              04-15-2022, 11:20 PM
            • ajdrenter
              Picking caps for Antec SU-380
              by ajdrenter
              In my search for a proper 5v heavy ATX power supply, I selected an old Antec SU-380 that I've had in storage for a long time. Opening the power supply reveals a couple bulged capacitors. I removed all the caps and made a map for myself. I found the datasheet for the PCE TUR series in this thread:
              https://www.badcaps.net/forum/showthread.php?t=14159
              It says these are general purpose, so I assume I can replace them with any general purpose capacitors, but I don't really know anything about power supply circuits or reading capacitor datasheets. Despite this, I've been shopping for replacements:...
              05-13-2023, 10:40 AM
            • linuxguru
              Fatman iTube (aka Dared MP-5) tube-buffered gainclone upgrades
              by linuxguru
              The Fatman iTube (OEM Dared, which also sold its own-branded version, the Dared MP-5) is a tube-buffered gainclone first introduced c.2005, to target the iPod market with a bookshelf tube setup. It became a huge success over the next ~15 years, selling over ~100k units worldwide to a market where it was often their first introduction to vacuum-tube audio on a budget.
              http://www.enjoythemusic.com/magazin.../dared_mp5.htm
              One of the Fatman versions landed up for auditioning a few days ago, and I must say that I was impressed with its form-factor, pricing,...
              03-13-2021, 08:45 PM
            • bjs59
              Infamous Rubycon MFZ... Current recommended replacements???
              by bjs59
              What we have here today is an Intel DG33FB motherboard, circa 2007... I need to replace some of the caps on this board... From what I have found, one of these caps was sort of well known here back in the day as they were used in XBoxes and XBox 360s as well....They are the Rubycon MFZ series, in particular the 6.3 v 3300uf 10mm X 20mm... I have found a seller on Amazon, The Capacitor Store, that has them listed but I have a hard time believing these are genuine pieces... The original recommendation was to replace any bad ones with Nichicon HZ series since the Rubycon MFZ's were a custom product,...
              12-10-2020, 10:47 AM
