Connect 3 psu's in series?
  • Makalu
    • Jun 2006
    • 10
    Well I bought an 80w 16.1vmax peltier to see how effective they are at cooling the air in a case (ala Channel Well IceCube psu or Sytrin Nextherm case) and the answer is erm not very well...at 12ish volts. I don't want to buy a 16vDC power supply for something i may not even use, but i do have 3 working ATX psu's and I was wondering if i can connect the 5v outputs in series for a 15v source? If so, can someone explain in layman terms or diagram how to do this? How would I disconnect/connect the grounds is the part i'm most uncomfortable with. Thanks in advance.
  • Shroomie
    • Apr 2006
    • 356
    Re: Connect 3 psu's in series?
    Well, you can get up to 24v from a regular ATX PSU. I don't know how much power the Peltier uses (in amps) though. It's accomplished by wiring the +12v into the -5 (for 17) or -12 (for 24v). I haven't messed with it much, myself, so I'd wait for someone else to explain better.
    You know there's something wrong when you open up a PSU and are glad to find Teapos.
    Why I don't buy cheap cases!
    • jonnyGURU
      • Feb 2006
      • 244
      Wire them up in series and you're only going to trip the protection circuit.
      Wire up the +12 and -12V and you're only going to be able to move whatever amperage the -12V is rated for (typically 1A or less.)
      Rest in peace BFG. You were... a job...
      • Makalu
        • Jun 2006
        • 10
        oh yeah the circuit protection wouldn't like that...what about the old AT power supplies? Do they have that? Just curious I guess since I only have one of those and in either case it'd be too cumbersome to keep...43 bucks for a Meanwell 15v 10a unit...decisions decisions
        • gonzo0815
          • Feb 2006
          • 1600
          No, there are no voltage >12v in any AT or ATX psu i know. But those little wallpluggs from laptop`s does have often some 19V /3,5A. Duno if that will rost your peltier or it will trip the OCP circuit.
          Probably the cheapest spource for that voltage and power will be some car battery charger. Those are very cheap and mwill deliver something between 13 and 17v. Adding some high capacity (about 4700 to 10000uf) capacitor will increase the voltage.
          • gonzo0815
            • Feb 2006
            • 1600
            Theoretically you can couple those 3 psu`s, as the outputs are galvanically isolated. But i duno if this will do like with linear psu`S.
            In any way, it is up to you to try that .
            To contect some PSU`S in series, you have to conect the black wire from PSU 1 to the red wire of psu 2 and the black of psu2 to the red wire of psu3.
            Between RED on PSu1 and Black on PSU3 you should messure the added voltages e.g between 13,5 and 15,5v. But keep in mind that you need for many psu`S some minimal ballast that they can operate properly. May be you should ensure that with 3 power resistors or some light bulbs for every psu (betwen the 5v o/P and the corosponding black - wire).
            IOn any way. as stated abovve, i duno if the regulation of thos smps psu'S can handle that kind of operation or if they are afeckted from it. In theory i think it should work.
            EDIT: some crude getto style drawing.
            • Makalu
              • Jun 2006
              • 10
              yeah i looked at a bunch of laptop bricks and found some that put out about what i need (16v @ 8a) but the price was higher than the Mean Well units. My car battery charger is only 3 amps, but I'm going to check the prices on those because I think you're right about that being the cheapest way to go. Thank you very much for the wiring description and diagram because I'm gonna try that too this weekend and I'll let you know what happens. Been using a couple of old optical drives to bump up the 12v rail but i'm not sure how i'll try and bump the 5v rail on 3 units but guess i'll see if it works first. cheers
              • Makalu
                • Jun 2006
                • 10
                it works great 15.49v (18amps I assume since that's the lowest output of the three) TYVM!
                • jonnyGURU
                  • Feb 2006
                  • 244
                  Wow! You got 15V out of it? Did you have to use the resistors? Does all of the 5V leads on the last PSU put out 15V?
                  I just would've thought the PWM would've freaked out and tripped the PSU.
                  • gonzo0815
                    • Feb 2006
                    • 1600
                    The pwm should theoretically work, as every PSU does only see his own voltage, e.g. the own 5v. Of course, the current and the voltage from the other PSU'S are running through the transfomer of each single psu, but as the input current is equall to the outputcurrent, the regulation shouldn`t be affeckted IMHO (the currents eliminate itself)
                    But for shure, i was sceptical too
                    Congrats to your succes
                    Well, it depends wich ground you are using. If you conect something only to the molex from any PSU, there is always the voltage from the particular unit, as it would be the ground from this psu, not from the others. At least this is what i expect. The 15 or higher voltage will only be there between the 5v of the first and the ground of the last psu or vice versa.
                    • gonzo0815
                      • Feb 2006
                      • 1600
                      Look at the drawing, you will see the 5v marking between each geound and 5v o/p of every psu. The molex, conected only to one psu, is in parralel with that marking.
                      • Makalu
                        • Jun 2006
                        • 10
                        yeah it reads 15+v across any 5v lead on PSU1 in the diagram and any ground on PSU3. I didn't have to add any resistors since they all put out over 5v just powered on alone but PSU2 is an old Astec AT style and it wouldn't power up without a load and attaching an old cd-rom drive worked.
                        I thought that I'd have to insulate the common ground on like 2 of them but apparently not or maybe I got lucky and they aren't wired that way.
                        • gonzo0815
                          • Feb 2006
                          • 1600
                          What you are meaning with "common ground"?
                          Do you mean the earth ground (e.g insulating the 110/220v ground or neutral?
                          AFAIk this could be the only ground, wich could be isolated. But for the secondary o/p voltages this ground is not realy something to wich there would be any potential. Due to the galvanic isolation of the transformer, there is no connection.
                          • Makalu
                            • Jun 2006
                            • 10
                            oh sorry DC common ground to earth is what i meant. Thanks for clearing that up
                              ASUS Pro Series D310MT-0G32500650 Pro Series G3250 Specification for Upgrade or Repair
                              This specification for the ASUS Pro Series D310MT-0G32500650 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pro Series D310MT-0G32500650 boardview and Pro Series D310MT-0G32500650 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                              09-12-2024, 03:28 PM
                              ASUS Pro Series D320MT-I564001774 Pro Series i5-6400 Specification for Upgrade or Repair
                              This specification for the ASUS Pro Series D320MT-I564001774 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pro Series D320MT-I564001774 boardview and Pro Series D320MT-I564001774 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                              ASUS Pro Series D320MT-I564000234 Pro Series i5-6400 Specification for Upgrade or Repair
                              This specification for the ASUS Pro Series D320MT-I564000234 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pro Series D320MT-I564000234 boardview and Pro Series D320MT-I564000234 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                              ASUS Pro Series D320MT-TR362D Pro Series i3-6100 Specification for Upgrade or Repair
                              This specification for the ASUS Pro Series D320MT-TR362D can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pro Series D320MT-TR362D boardview and Pro Series D320MT-TR362D schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                              ASUS Pro Series D320SF-I564000134 Pro Series i5-6400 Specification for Upgrade or Repair
                              This specification for the ASUS Pro Series D320SF-I564000134 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pro Series D320SF-I564000134 boardview and Pro Series D320SF-I564000134 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
